Question about HP iPAQ H2210 Pocket PC
HP Ipaq 2910 wont finish the boot
Hya my HP ipaq is stuck after freezing with TomTom 6. After soft restart it wont pass the boot screen just shuts down?
pls help and THX
  • 31 Answers
Hey :), I'd be happy to help. I honestly don't think that you've physcially damaged your Ipaq, so you should probally hard reset your Ipaq. To do this you must hold down the reset button and the power button at the same time for like 5 seconds. This will get rid of data on your pocket pc, but It might solve your Ipaq's problem. Thanks! and I hope this helps, if it doesn't I'd recommend for you call Hp where they will repair it or give you a new one :)
Posted on Oct 13, 2008
Hp rx4540.How to access the Boot loader mode?? .My ipaq just displays the hp logo on start up and then just freezes.Ive tried soft and hard reset.Help please
A factory reset erases all user-installed settings, programs, and data, and restores your HP iPAQ to factory settings.
CAUTION All user-installed settings, programs, and data are erased from memory with a factory reset.
To perform a factory reset and return your HP iPAQ to factory settings:
  1. Press and hold the OK and Rotate Screen buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
  3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ will now restart and power on.
If you have done the above and still no go. Then your main drive has probably failed.
Link below is a repair how to video
http://www.wonderhowto.com/how-to-repair-hp-ipaq-rx4200-rx4240-rx4500-rx4540-243534/view/
Mar 11, 2010 | HP iPAQ rx4240 Pocket PC
Hp ipaq rx5935 hangs at the end of the HP booting sequence
remove battery for 6 hr and reinstal and then hard reset.
bob.
Jun 20, 2009 | HP iPAQ rx5935 Travel Companion Pocket PC
HP ipaq hx2795 lose sound
Hi there.
Browse to your Windows directory and look for BtCoreIf.dll and BtSdkCE30.dll. Rename them both (for example: "BtCoreIf.old" "BtSdkCE30.old")
then do a soft reset, it should work.
Bye
Jan 20, 2009 | HP iPAQ HX2795 Pocket PC
Hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
Can't get soft reset screen on Ipaq travel companion rx5915
Try This:-
1. Press and hold the Quick Launch and Rotate Screen buttons.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button. The HP iPAQ restarts and powers on.
Mike @ compurepair.
Jul 23, 2008 | HP iPAQ rx5915
HW6515d Ipaq Sound with TomTom Sat NAv
The ipaq 6515 has a microswitch that will turn off the pda if the battery cover is removed. When you remove the cover and try to turn it on even with the external power supply plugged in, the red led will light up.
Jan 29, 2008 | HP iPAQ hw6515 Pocket PC
Frozen screen
hello :-) i just talked to another person who was having the same problem as you. And guess what?? the same problem happened to me on my IPAQ 4350. It turned out when I would hard reset my IPAQ it asked me to align the screen but it wouldn't move and it would freeze and not let me pass . But I later found out that my screen was damaged and I got a new touch screen installed and my IPAQ works perfect :-). I would recommend for you to do the same and call HP and see if they could install it for you. Thanks :-}
Nov 05, 2007 | HP iPAQ H2210 Pocket PC
IPAQ 2795 freezes during boot up.
I had the same problem. Contacted HP customer service chat, and got the following answer that
solved the problem:
1. Remove the battery for 30 minutes.
2. Insert it again in the iPAQ.
3. Perform a clean reset on the iPAQ and at the same time charge the iPAQ.
To perform a clean reset please follow these steps:
Press and hold the Calendar button, the Power button, and the Messaging button.
While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ.
The problem can also be solved by getting a new battery, and performing the clean reset while charging (using the portable charger, not the cradle).
Nov 16, 2006 | HP iPAQ HX2795 Pocket PC
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
3970 Stuck
Try this, take the ipaq off the cradle, turn the ipaq off (if you can), restart the desktop, put the ipaq back in thc cradle, turn the ipaq on, and restart ROM update again.
Sep 12, 2005 | Compaq iPAQ H3970 Pocket PC
HP iPAQ H2210 Pocket PC Logo
516 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
