I have a LG LRA-750 dvd recorder. The unit no longer recognizes the discs I put in it. The laser/lens assembly was cleaned up and the laser does light up and tries to read the disc. My guess is I have to replace the entire drive unit. Where can I get the replacement part?
  • Anonymous Sep 01, 2008
    I have a LG dvd player HL 550 T modle
SOURCE: LG DR-4810 DVD Displays " PLEASE WAIT"
C113 10v 1000uF cap off an XFRMR in power supply board. Cooked and gone high esr. Replace with a 16v.
Posted on Nov 26, 2007
dankind38
  • 6 Answers
SOURCE: SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
Posted on Dec 30, 2007
SOURCE: Invalid disc reading
I have successfully made hundreds of play-able DVDs from my home video using this Liteon LVC9016G. Overall I like this machine although it is very quirky.
In my experience the only DVD that can work is SONY DVD+R 120min / 4.7GB. NOTHING ELSE WILL WORK RIGHT. I have used some DVD-R: You can record on it since everything appears to work. The got-ya is you cannot play it at all. I am sick of this because I have re-used some tape but ended up with useless DVDs! Take my word for it, I have tried many media like Maxwell or Verbatin. These "other brands" are fine on the computer but not on this machine. I don't know what this machine can detect and see the differences in the media. Give this media a try.
Posted on Jun 24, 2008
rhozel2010
  • 269 Answers
SOURCE: The dvd recorder will not recognize any discs. It
Hi! there are many reasons why a dvd is note reading. 1. dirty pick up lens, 2. defective spindle motor, 3. defective ribbon wire, 4. defective pick-up lens and defective mpeg board. but first things first try cleaning your pick-up lens with a cd lens cleaner.
Posted on Oct 16, 2009
SOURCE: jvc dvd player no disc error
Hello!
I did have a similar problem. It was solved by cleaning the laser lenses/prisma. You have to dismantle the whole pick-up the to see the laser lenses.
There is one lens which is held by couple wires and below there is prisma/mirror.
I did use ear-cleaner-stick and desinfection liquid (with alcohol) for cleaning. Now it works!
Posted on Nov 27, 2009
Pick up assembly
end of life or needs optic cleaning.
fiddling inside , will make it worse. RTM, the service manual.
did you contact LG for parts.
did you look in mCM electronics? they sell sub assembles.
Sep 29, 2013 | LG Computers & Internet
Doesn't recognize disks anymore
i would try lens cleaning cd 1st ok might be dirty lens just cant read it if not that try firmware update to the unit thx nick
Feb 04, 2008 | Lite On LVW-5005 DVD Recorder
My Avion dvd recorder model AV-DVR100 will not recognize any DVD's It will not recognize the dvd cleaning disc. Could it be hooked up wrong. Frank
It could be that the dirt on the lens is too bad. You might have to take the top off and clean the Lens with Servisol Video 40 or other lens cleaning fluid. However the lens can also be damaged by a tiny piece of grit hitting it a high speed. Only observation by a powerfull magnifying glass will confirm this.
Another problem could be damage to lens carriage unit, so it can't move to read the disc.
Jan 29, 2013 | Televison & Video
I have an DR275 LG DVD recorder. For some reason it stopped playing DVD discs. But it will play anything else you put in it I have cleaned the heads switch it of by the power as well. What could...
The laser mechanism has a number of optical components, not just the lens. There also additional fixed lenses and mirrors inside the laser unit which are very difficult to access. If sufficient dirt builds up on these components then the dvd laser may not work properly. Unfortunately it is very difficult (or even impossible) to clean these parts.
Another possible fault is that the CD laser is usually separate to the DVD laser and the DVD laser is no longer working properly, while the CD laser is still OK. In this case, the unit is definately not repairable without replacing the whole laser unit (not a readily available item and not likely to be cheap).
If the unit is out of warranty, your cheapest option is to buy a new DVD recorder.
Jun 16, 2011 | LG DR275 Recorder
Will play cd video, but will not play dvds
The Laser Pickup Assembly is defective and must be replaced, the dvd discs require higher precision when it includes audio and video signals together, the only other possible way is attempt to clean the laser pickup lens with a Q-Tip and rubbing alcohol, but it is long shot.
Jan 03, 2011 | LG RH177 DVD Recorder/HDD Recorder
Returns error message :Unknown Disc. Please Check Disc Again" The DVD disc plays on other DVD players with no problem.
Problem may be reset needed, or lens need cleaning, or dvd recoreder worn out. Reset is pull the plug from the wall for 5 minutes. Turn it back on after reset to load firmware again, may work after that.. TDK makes lens cleaner. LG uses fan so, dirt can get into dvd recorder lens. If the tray moves out wiggly, laser assembly may move wiggly too. Replace dvd recorder which is a dvd+-rw regular ide unit from computers.
Aug 20, 2010 | LG RC-197 DVD Recorder/VCR
Dr787t won't play disc. Player won't recognize
You can try to stop this by dis-assembling the unit to gain access to the laser and you can clean the laser using a cotton bud or cue tip, if that doesnt solve the issue, what you can do is with the case off, put in a dvd and see if it spins, and also note if the laser is lighting up, if it isnt lighting up or if the disc isnt spinning you may need to replace the dvd loader of the unit.
If the laser doesnt light up and the disc doesnt spin its possible you may need to replace the MPEG Printed Circuit Board which you will fing attatched to to the dvd loader via small ribbon cables, be carefull when removing these if you need to remove them or a seriens of small plugs. I hope this helps. Good Luck.
Dec 06, 2009 | LG DR787T DVD Recorder
Have LRY-517 dvd recorder and have used it maybe half a dozen times. Now it will not let me initialize any discs. Gives me " Unknown disc, check disc again" error everytime.. Cleaning the unit inside and...
Normally, I'd advise cleaning the IR lens with a disc-based lens cleaner, but at only six uses, the problem could be controller board or misaligned laser/lens assembly.
Could be something worked loose or skew disc jammed in drive.
Have you tried DVD's from just one pack, one type, or other types?
Why I ask - I had this problem on my PC's DVD-writer.
It turned out that a full (new) pack of DVD's was faulty.
As a test, try initialize same (suspect) disks on another recorder?
Oct 05, 2017 | LG LRY-517
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
Electro Med Services...
