Question about HP OfficeJet 6110 All-In-One InkJet Printer
Possible software problem?
When i plug in the power the printer lights flash and all lights go out except the flashing light for the little camera in the left corner and the system shuts down
    Novelist:
    Scholar:
  • 111 Answers
I don't remember a little camera light on the control panel of my 6110 (though there is a little telephone light on the left side that usually indicates the fax/modem line is in use), but it sounds more like an electrical fault. I suppose you could try to replace the power cord and power supply, but my guess is that the fault is intermal. You're most likely looking at taking the printer in for service. Good luck.
Posted on Oct 17, 2008
Light does not flash when charging battery
Please try this:
1) Make sure camera is OFF.
2) Plug Charger into the wall (not into camera)
3) Last think plug charger into the camera
Oct 15, 2014 | Nikon Coolpix S3000 Digital Camera
Printer not turn off
It sounds like a driver problem. Unplug the printer from the power and computer. Uninstall the drivers completely and then use the original disc that came with the printer to reinstall everything. Leave on automatic updating.
Mar 05, 2014 | Canon Office Equipment & Supplies
My Canon digital camera will not flash outside. PLZ help!!
It is possible that you have the camera on an inappropriate setting. For example, if you are outside during the day and your camera is set to AUTO, there is little chance for the flash to go off because the camera doesn't need the extra light. If you want to force your camera to flash, set it to a mode other than AUTO and then turn on the flash. Good luck!
Nov 17, 2011 | Canon Cameras
Printer wont power up, 3 lights flashing on main panel when plugged in, including power button. photo,copy & the scan lights. How can i recover from this?
1. Check your wire for a possible short.
2. Reinstall your printers software.
3. Update your printers software.
4. Update your drivers
Check into the 4 of them first
Jul 26, 2010 | Dell 922 All-In-One InkJet Printer
How can I turn down the power on the FL50 to get more flashes. Can you turn down the power on the camera E510 with hte FL50 attatched?
the user manual is here http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/accessories/man_fl50_e.pdf
Have a look at page 46 TTL Auto mode - you can adjust the variable between power setting - + or - 3 stops Page 48 gives full details on adjusting this setting
Light intensity adjustment
  • The flash light intensity can be adjusted between +3 and –3.
  • The light intensity adjustment must be set to ON in the custom setup operation (page 61). • The indicator appears in the control panel.
  1. Turn dial B to select a light intensity adjustment value in the following steps. (This selection is also possible with dial A.)
  • 0 → +0.3 → +0.7→ +1.0 ... +3.0
  • 0 → –0.3 → –0.7→ –1.0 ... –3.0
  1. The display shows the light intensity adjustment value except when the value is 0, in which case the display does not show the light control range.
  2. If the camera’s flash adjustment mode is selected, the actual flash light intensity will be the total of the light intensity adjustment value set on the FL-50 and that set on the camera. The light intensity adjustment value displayed is that of the FL-50 only.
Apr 11, 2010 | Olympus FL-50 TTL Flash
Error code on my ix4000 reads 5C00
Canon has a decent trouble shooting guide for this model:
http://www.usa.canon.com/consumer/contro...
Click on the Step-by-Step Troubleshooting link under Tech Support
Unfortunately it does not give any possible solutions for blinking lights.
The user guide on the other hand does.
You can download this under Downloads -> Product / Software Manuals
Here is a summary of what the flashing lights could mean:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Six flashes: No print head installed
Install a print head.
Seven flashes: Print head is defective
Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
Ink used for cleaning is absorbed in the waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact the Customer Care Center as soon as possible. Once the waste ink absorber becomes completely full, printing will no longer be possible.
Nine flashes: Ink tank is not installed properly
Open the print head cover and press the button of the ink tank and reinstall the ink tank properly.
Ten flashes: Battery level is low
Charge the battery. For details on how to charge the battery, refer to the manual supplied with the battery.
Eleven flashes: A specified period of time has lapsed without receiving a response from the digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Disconnect the camera cable, press the printer's RESUME/CANCEL button and reconnect the cable.
If the error is still unresolved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this printer. Use digital cameras or digital video camcorders that are compatible with this printer.
POWER lamp flashes alternate green and orange:
An error that requires contacting the Customer Care Center may have occurred.
Disconnect the printer cable from the printer, and then turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on after leaving it about 10 minutes.
If the problem remains, contact the Customer Care Center.
Jun 19, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Officejet 6310 won't turn on.
Ok try unplugging the printer for about 15 minutes and plug it back in that will reset the printer and it should work fine.
Let me know how it works out
Dec 24, 2008 | HP Officejet 6310 All-In-One InkJet...
HP 3820 Deskjet Printer
1) take a flash light and inspect the paper path just to make sure there really is nothing there.
2) print a test page from the printer by pressing the big button ( I think) one of the buttons, can't remember I work on so many models
3) take out cart. turn off then on, install cart. and do step 2
what happens
Jan 04, 2008 | HP DeskJet 3820 InkJet Printer
Problem with printing
Sorry the manual doesn't help much either... this is what it says, "POWER lamp flashes alternate green and orange Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on. If the problem remains, contact a Canon service representative."
You could try the following reset code which works when reseting after emptying the waste ink tank:
Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Hope it helps
Oct 03, 2006 | Canon i80 InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
77 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
