Window unit ac/heat
Freezing up and thermostat not cutting off
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Are the coils freezing up half way down or all the way up? Half-ways down means low on freon, all the way up, mean low air flow,due to dirty filter, and adjust the thermostat up a little higher, it could be going out also.
Posted on Sep 01, 2008
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: I have an LG AC/Heat
TO GET HEAT, SET MODE OR SELECTOR SWITCH ON "HEAT" AND ALSO TEMP+29
Posted on Dec 13, 2010
Ac unit will not heat
You need to check your model # a CP06 is a straight cooling window unit you may have an EP08G10 this is a heat cool unit. Double check your thermostat is turned to higher setting. If so you may have an issue with the heating element or the heat limit on the element.
Dec 08, 2013 | Friedrich CP06C10 Wall/Window Air...
Rv heat pump problems
Open circuit or out of range Freeze Sensor. Air conditioner mode of operation will be locked out. Furnace, heat strip, heat pump and fan mode of operation can continue to operate but displays the last temperature set-point. There is a sensor that detects evaporator freezing, it may be bad or your freezing because of low freon levels
Sep 30, 2013 | Dometic Rooftop RV Air Conditioner
I got a Dometic roof AC (2010) on my RV , the thermostat is givng me a E5 code, I changed 3 thermostats, opened the top and inside caps to check if there's any cut or burned wires and nothing that I...
E5 Open circuit or out of range Freeze Sensor. Air conditioner and dehumidification
operation will be locked out. Heat pump, furnace, heat strip and fan operation
Sounds like your freeze sensor is defective and since it is still under warranty, you would void it if you replace it yourself.
Aug 26, 2011 | Dometic Rooftop RV Air Conditioner
I have a 2005 Pilgram 27 foot 5th wheel. My Duo Therm AC unit makes a ticking sound from the ac unit itself when it's not running. Shutting off the Duo Therm analog thermostat does not stop the ticking...
It's obviously on the 12voltDC circuit of the AC unit. Sounds like thermostat, or a relay in control box is faulty or bad connection. If you remove cover on ceiling assy., you should be able to hear it in the control box. There should be a model number on the ceiling assy., get back to me with that number and I can better pinpoint which relay. Also, try moving all thermostat buttons and temperature controls back and forth quickly to see if it may clean off a dirty circuit in thermostat as well. Make sure your AC hydro breaker is off when working with ceiling assy. just to be safe.
Mar 26, 2010 | Dometic Rooftop RV Air Conditioner
Needs a thermostat
go to sears.com and put the model number and you might be able to order one from there.
Apr 25, 2009 | Heating & Cooling
Chronotherm III Thermostat Completely Blank Screen, No Heat
One of two things either the disply has gone out which is likely as it is a common failure for that thermostat or your heating unit is not sending control power. the older chronotherms were system (24volt ac) powered the new hardware/box store units are battery powered. Either way display should not be blank with fresh batteries. to get heat on remove the thermostat jumper or twist together the wire from the R terminal with the wire from the W terminal. note the color of each wire for later reference, heat up house disconnect wires from each other and go purchase a new thermostat
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
FREEZING :
check your thermostat, could be set to the coldest setting and it is not cutting off.
thermostat could be broken also( stuck close)
the evaporator coil could be clogged with dirt. have it clean.
tnx 4 using fixya,
drcool
Oct 16, 2008 | LG Electronic Window Air Conditioner
American Standard Heat/ac system
It has been suggested to us we change out the thermostat.Good idea considering if the ifs its reading colder than actually appears on readout the unit will freeze up. The unit is working right at this moment, but, when we change thermostats we will let you know the outcome.
Aug 02, 2008 | Heating & Cooling
Heating & Cooling Logo
171 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
