Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Ice Tray Won't FIll with Water
Myice maker is not filling with water. When I pulled the fridge out, there is water leaking from the water line at the top of the back of the fridge where it enters to the ice maker. It appears there was some pressure as the wall is also wet. I did not notice any leaking though. Water is getting to the water dispenser on the front... any thoughts would be appreciated
  • Foss1 Sep 03, 2008
    Thanks, i removed the plastic line for filling water and the line was frozen. I melted all the ice in the line. Still not filling tray, not sure if temperature of freezer needs to lower to freezing temp to fill tray or if something else is also broken.
  • 89 Answers
Number one repair leak could be as simple as loose fitting most likely fitting needs replaced should solve problem if not once the leak is repaired pull out ice tray inside fridge in the rear you will see small outlet that fills the trays run a blow dryer full heat on it to clear it from freeze up which might be clogging your line good luck hope this helps
Posted on Sep 01, 2008
Jennair refrigerator jfc2089htb2
It is possible that the half side of your=> 67006531 Water Inlet Valve that controls water to ice maker is leaking like a dripping faucet and causing the problem. Can you see signs that water is flowing from the ice maker fill tube? The fill
JENN-Air JFC2089HT Water Inlet Valve Thanks John Tripp Appliance 911
Jan 23, 2014 | Refrigerators
Lg in door ice maker, water won't fill in ice tray
I had that problem and water was also leaking. I tossed the ice and kept the door open for about 20 minutes when the door open alarm started to go off. It's working again. The error code on the door was 1f
Feb 01, 2013 | LG LFX25960ST Stainless Steel French Door...
Water is frozen in fill cup inside the ice maker
Put your frozen food in a cold place.Unplug the fridge, leave the freezer door open for 12 hours. Dont mess with hair dryers
Jan 30, 2013 | GE GSS25LGM Side by Side Refrigerator
Water leaking from Icemaker fill tube near the back wall
It probably is not the water valve. More likely it is the ice maker itself. Nothing else in the machine controls the flow of water to the ice maker except the ice maker itself. It is recommended that both the ice maker and the water valve needs to be replaced when trouble such as this.
Dec 12, 2012 | Refrigerators
There isnt any water getting thru to the icemaker. i changed the watervalve and still no water i cannot locate the water filter even tho i removed the bottom grill, water is still getting to the water...
if you put a new water valve on the fridge then you either have a bad ice maker or the line is frozen where the water fills the ice maker,a bad water valve will make the line freeze,water keeps dripping through the valve and freezes the fill line behind the ice maker cup,you can remove the ice maker and check the fill line,if it's frozen get a hair dryer,shut down the fridge or unplug it and blow the hot air into the fill line until the ice melts,then get a piece of wire and after you reinstall the ice maker pop off the cover to the ice maker and jump it out with the wire,stick it in the t and h for 15 seconds and pull it out,if the ice maker is good it will start turning and when the arms get at like 11 oclock it should fill,also you can jump out the fill valve from the ice maker,stick it in v and L and if water fills the ice maker you know you have a bad ice maker if the fill line isn't frozen.hope this helps.next time you need help send the model number,on your machine look in the fridge section on the right hand wall up near the ceiling to find it,if it's older look down near the bottom hinge on the fridge door and you'll see a tag with the model number.good luck
Sep 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I pulled out the ice tray on our MSD2351HEB and now it won't make ice. I've moved the lever up and down, verified that the tray is ALL the way in to no avail.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Jul 07, 2009 | Maytag Refrigerators
Ice maker does not fill with water and will not make ice .
you have a bad water valve easy repair located in back left of fridge
pull fridge out slowly see if you have enough line
Apr 17, 2009 | Refrigerators
Icemaker not working.
I just had the same problem. I found a small amount of ice formed under the water inlet point in the ice maker tray. This ice prevented the rotation of the "ice cube ejection fingers" so it couldn't cycle and re-fill. I used a hair dryer to melt this ice and the fingers immediately began rotating. Once they cycled, the tray filled with water as it should. All seems well now.
Jan 18, 2009 | KitchenAid KSRS25IL Side by Side...
Water leaking
Tarena, it's been my experience with Amana that tells me you have a failed water inlet valve.
Here's how it works; Water comes from the wall into the fridge to the valve I'm talking about. Now this valve works like this... When you put a cup in the dispenser area to get cold water a switch sends 120 volts to the valve and it opens up allowing water to flow through it. When you remove the cup, power is shut off at the valve... the valve is supposed to close all the way, if it didn't there would be water dripping from the dispenser area, right? (Like a leaky faucet) If the valve is bad, it won't open at all. (Like a blown out light bulb)
The ice maker is similar. When it "harvests" ice and it drops into the ice bin, the IM will send 120 volts to the valve (for 5 seconds or so) to re-fill the ice mold so it can make another batch. Now when the power is removed from the valve, it's supposed to shut off all the way. If it didn't, there would be water dripping into the ice maker fill tube (in the freezer behind the ice maker). drip, drip drip... one after the other.
Let's assume that the ice maker valve didn't close all the way. What would happen then? As these drops of water enter the freezer compartment and are heading down the ice maker fill tube toward the ice maker, they don't make it all the way 'cause they FREEZE in the tube! One drop at a time, week after week. ('course you never notice it, 'cause it's in the freezer) Now... the ice maker is still trying to make ice, so every 45 minutes or so it sends 120 volts to the valve to get more water. But the water fill tube has ice in it because of the water drops that have accumulated there. This goes on over time and eventually the water fill tube becomes completely BLOCKED with ice due to those water drops.
Now what happens? The ice maker is still trying to make ice, but the fill tube is blocked... it can't get water through it. But when the water valve opens up to allow water to the ice maker, where does it go? Since the fill tube is blocked, all that water pressure builds up in the water line (tube) that feeds the ice maker and eventually it blows out! (you can verify this... pull the refrigerator out from the wall, look at the water line going to the ice maker. There's a connector back there for the tube to fit into. This is what's blown out.) Now the tube is just dangling there and not hooked up to the ice maker any longer. Since the ice maker is still running, every time it asks for water it sprays out and onto the wall and floor back there through this dangling tube.
The repair? Replace the valve. It's easy. The part number is 67005154 and it lists for about $21.00. You can find one at any appliance parts retailer. (you'll see where the valve is located... it's where the water line hooks up behind the fridge.) UNPLUG YOUR FRIDGE WHILE YOU WORK ON IT!!!
Just replacing the valve is only half the job. You'll still need to remove the ice build up in the ice maker fill tube. Do this by pulling it straight out the back of the refrigerator and putting it under warm running water. Then re-install it and hook the water tube back up to it.
On some models, you can not remove the fill tube. If you can't get it out the back, you'll have to do it from the freezer compartment behind the ice maker (a little more work, but still do-able). It's easiest by removing the ice maker.... pull the ice bin out and set it aside. Then remove the 3 screws holding the ice maker. You don't have to disconnect the wires, just try to get it out of your way the best you can. Now take a hair dryer and thaw out the fill tube until the ice slides out of there. Then rebuild it.
There ya go! Job time? about an hour. Part cost? about $21.00. Knowing that you fixed it yourself? Priceless.
Oct 14, 2007 | Amana ACD2232HR Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
137 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
