Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp AR-M165, maintenance led and developer replacement leds on
How do I reset the maintenace and developer replacement leds?
Also horizontal black lines on the printout. Could it be the developer?
Please help.
  • 2 more comments
  • fainis2003 Sep 02, 2008
    Thanx for the reply,
    The printout is not light, it is ok but there are several black horizontal lines.
    This copier had a tough life so I presume there could be scratches on some cilinders. I want to know what causes this problem so i can fix it, i`m afraid if i change the developer it won`t fix the black lines.
    Does anyone has a manual with problems and solutions (components that sould be changed and when)?
    Thank you very much, any reply would help
    Millions of thanx,
    Here cames a silly question.
    What exactly is the drum?
    The photo cilinder (the blue one)?
  • Anonymous Mar 22, 2014
    please i want the driver for the above photocopier which i can install in my win 7 pc.
  • Anonymous Mar 24, 2014
    there are lines on it when i make photocopy with it.
  • Sharp Master
  • 2,794 Answers
It's the drum thats causing the lines to happen. Youre going to have to get that replaced before you can reset the counters.
If you get light copies, then the developer should be replaced.
Posted on Sep 01, 2008
  • Tim Babcock
    Tim Babcock Sep 02, 2008
    I believe the cycle life on the drum is 50,000 copies.
  • Tim Babcock
    It should be the green round drum.
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
Coming with message on display maintenace required call for service
What is the error code that is being displayed? Is it displaying "Time for maintenance"? If there is no error code and the copier still works, it means the internal count has got to a factory set meter to have the drum & developer and possibly other part replaced at that time.
Oct 08, 2012 | Sharp AR-310NT Toner
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
I have just aquired a sharp AR- M165 and when you turn it one the man icon appears with a flower type icon ( I guess this mean toner) Sharp engineers are few and far between in west wales, is there any way...
You need to change the developer and reset the code, you could just reset the code but copy quality may begin to deteriorate, have you any experience with copiers?
Jun 27, 2011 | Sharp Office Equipment & Supplies
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
Turn off developer led
HII.best way is that u have to replace developer with new one .new developer will reset it automatically.for to reset in this condition
press clear key ,exposure mode key,clear key,exposure mode key,
copier will go dead .press 24 then start 06 start
developer counter will bi reset
do not forget to rate the solution
MIAN AKHLAQ
Mar 17, 2009 | Sharp Office Equipment & Supplies
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
1,231 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
