Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Clutch am assembling the clutch for a 1997 dyna low rider and don't see what hold the last plate on
  • lonhansen Apr 05, 2009
    What is the proper clutch adjustment for a 1993 fxdl ?
    Genius:
  • 2,028 Answers
There is a retaining clip that holds the plates in the basket. The assembly will need to be depressed in order to get the retainer in place. You can get a diagram, or at least view the diagram for the assembly at the parts counter of your local HD dealer. The local dealer here has stopped printing out the diagrams for me, but will still let me view them. Generally that's all you need anyway, just to get the idea.
Posted on Sep 01, 2008
Removing the starter drive clutch on a 94 dyna
Hi Anonymous, for more information about your question please visit the website below. Good luck and have nice day.
2005 Harley Dyna FXDX starter replacement
Apr 20, 2013 | 2005 Harley Davidson FXDL - FXDLI Dyna Low...
Adjut clutch
Loosen adjuster on clutch cable completely.
Remove round cover on primary cover.
Loosen lock nut around screw in center of clutch plate.
Back off adjusting screw.
Tighten screw until it JUST touches.
Back off 1/4 turn.
Hold in place while tightening lock nut.
Adjust clutch cable adjuster until there's 1/16-1/8" free play at hand lever.
Feb 03, 2013 | 2001 Harley Davidson FXDL Dyna Low Rider
My 1997 Audi a3 is juddering when I change gears and it's low revs
Hi Kristopher, A shudder from the manual transmission is usually caused from a defective part in the clutch assembly. It could be caused by uneven wear of the pressure plate (clutch cover) or wear on the clutch plate boss (The center of the clutch plate with the springs or rubbers which absorb the torque when releasing the pedal) A shudder can be generated from a defective engine or gear box mount, worn CV joints or spiders or a loose bell housing. Start with the last suggestion and work backwards as the clutch replacement will require the most work. If the clutch assembly has been replaced recently, and the parts available are of the same quality we receive where I am, you will need to do the job over. Regards John
Oct 07, 2012 | Audi A3 Cars & Trucks
How do I replace my clutch cable on a 98 dyna low rider
You will have to replace the entire cable. Also buy a transmission side cover gasket because you have to take the cover off to replace the cable.
Aug 12, 2012 | Harley Davidson FXDL Dyna Low Rider...
What is the diameter of fork s on a 1997 FXDL
I do not have a repair manual in front of me but from what I recall the Dyna Low Rider forks where 35mm but later changed to 39mm.
Mar 02, 2011 | 2000 Harley Davidson FXDL Dyna Low Rider
2000 harley gets caught between gears, what's the problem?
Your low rider has forward controls on it. These controls are not as "positive" as the mid-mount controls. Now, if your clutch is not releasing as it should, this could be the cause of your missed shifts as well.
Or, it could simply be that you need to learn a different shifting technique. Regardless of what you and others may think, your low rider is not a high performance motorcycle. It's a cruiser and should be ridden like one. It has large heavy gears in the transmission because it's a large heavy motorcycle and it will not shift as fast as the lighter bike's transmissions do.
If your transmission does not shift as it should once you're sure your clutch is releasing properly, make sure your primary is not overfilled with oil. If you have too much oil in the primary, the clutch and the oil will act like the torque converter in an automatic transmission.
Stand your bike up straight and remove the derby cover. Look at the clutch assembly. It will look like shiney aluminum. Inside this, you'll see a darker colored "plate" of metal. This is the spring in your clutch. The oil level should be no higher than the lowest point of this spring.
If this does not resolve the problem with your transmission shifting, it will require going into the transmission to have a look at what's going on in there.
Good Luck
Steve Bentley
Feb 17, 2011 | 2000 Harley Davidson FXDL Dyna Low Rider
Just need to know how to change Engine, Transmission and Primary
There are two drain plugs on the bottom of the transmission. One is the engine oil and the other is the transmission. Drain the two oils from there. The primary oil drain is a small pipe plug underneath the lowest part of the primary drive cover.
The engine holds three quarts of oil, the transmission holds 20-24 ounces of oil, and the primary hold 36-42 ounces of oil. Fill the primary until the oil level is just to the bottom of the spring in the clutch assembly. If you get too much oil in the primary, the clutch will drag and you will be unable to find neutral with the engine running.
Good Luck
Steve
Aug 04, 2010 | 2001 Harley Davidson FXDL Dyna Low Rider
How do I find the oil plug in a 2005 Dyna Low Rider
Back lefthand corner of the what looks like oil pan,center plug is tranny, made to drain with the bike on its jiffy stand. (do not know who names that stuff)
Don
May 20, 2010 | 2005 Harley Davidson FXDL - FXDLI Dyna Low...
How to remove starter clutch on a 1998 Dyna Low Rider
The starter clutch is an integral part of the starter assembly itself. You must remove the starter and disassemble it to get the "overrunning clutch" out. First take the starter off the bike. Then, remove the two long bolts and take the starter motor off of the drive housing. Then remove the bolts that hold the drive housing together. The overrunning clutch will come out of the drive housing. You will probably have to take the bearings off the original clutch and reinstall them on the new part. Reassemble the starter and reinstall it on the bike.
Apr 06, 2010 | 2005 Harley Davidson FXDL - FXDLI Dyna Low...
Harley trouble selecting neutral while engine running
If the bike has sat and not been ridden at one time,the clutch plates,or some of them may have fused together.Its a common problem.They need to be taken apart,cleaned and put back together in exactly the same order.OR the clutch needs to be adjusted.Hope this helps
Dec 03, 2009 | 2000 Harley Davidson FXDL Dyna Low Rider
Lands Phones Logo
126 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
