Question about Whirlpool GEW9250 Electric Dryer
Whirlpool YGEW9250PW1 Electric dryer control locked problem
I have Whirpool YGEW9250PW1 Electric dryer and it has a control locked problem. Controil locked light always on and I can not use the dryer.
Can you tell me what is the problem and how can I solve it please?
  • 5 more comments
  • Burakcen Sep 01, 2008
    I have already tried End of cycle button but it does not work.
    It's been unpluged morden week. So I've just tried but still doesn't work.
    So, do you think the will require replacement?
    Tx
    Thanks for all
  • Burakcen Sep 08, 2008
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
    mso-para-margin:0cm;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    I have
    opened the top cover of dryer and checked the parts number. I saw there are 2
    control boards behind the front buttons and one board top left corner edge.
    I could
    find P/N 8559431 (behind the buttons) and P/N 8546219 on the top left
    corner edge on boards.
    Could you
    tell me which one is the control board that I need to get part number?
    Thank you
  • Burakcen Sep 10, 2008
    Normal
    0
    false
    false
    false
    font-size:10.0pt;
    I have
    control boards behind the front buttons(one big and one small) and one board top left corner edge.
    I could
    corner edge boards.
    Could you
    Thank you
  • GEEVITHAN Sep 13, 2008
    The "control lock" light is turned on and i can not use the dryer. Can you please assist me how to unlock the dryer?
  • aprvd123 May 14, 2009
    My problem started with the dryer locking out. Holding the end of cycle button worked at first but then didn't. Unplugging it overnight worked for a while too. Now I have 3 dim lights (Damp, Bulk items and Extra low). that stay on all the time. No other buttons respond. After unplugging off and on for over a week it worked for one cycle. Whirlpool sent a new board but it didn't work. Not sure if buying a new control board is the answer. Any ideas?
I had the same problem, but my husband, who is an engineer, figured out that if you pull out the light bulbs that are not reading the correct volts on his volt meter, the control lock light will shut off and the dryer will start working. If you do not know how to do this, you can always buy a new control panel. I know this sounds to simple to be true, but we have bought several new "brains" (control boards), tried unpluging the dryer for days at a time, had an certified whirpool technician come out (who recommended buying a new control board), and nothing worked.
Posted on Dec 15, 2008
    New Friend:
I have had the same problem with my dryer twice, and this is how it can be fixed. I have been an electronics technician for over 20 years. When this happens you will see one or some of the led lights dimly on, for a time the problem could be intermitent. If you pull out the front control panel and use your multimeter on the diode function you can test the individual led lights while in circuit. If you find one that doesn't light or reads strange you can cut it off the board or use a solder iron to heat at 700 Deg F the led leads. What I have found both times that this burns off whatever impurities that have developed in the PN junction and causing a partial short and restores the function of the led. When you get everything back together Your dryer should work again.
Posted on Nov 23, 2012
As mentioned above in one of the comments, pulling out the light bulbs that are not reading the correct volts solved the issue. Basically one of the bulbs on the PCB gone bad and caused the control unit to go into "Control Locked" mode.
Posted on Jul 31, 2010
  • 5,911 Answers
Try pressing and holding the "End of Cycle Signal" button for three seconds. The control lock should clear. This button is used to lock the controls so they cannot be manipulated. This is a safety feature designed by the manufacturer that prevents small children from being able to turn the washer on. If this does not work, the problem is more than likely a operator interface (control panel) malfunction. I hope this helps you. Let me know if you require additional assistance.
Posted on Sep 01, 2008
  • Jeff Rockwell
    Jeff Rockwell Sep 01, 2008
    Unplug your dryer for at least 30 minutes as recommended by the manufacturer. This will reset the computer. If this fails, you more than likely have a failed control panel, and it will require replacement. Hopefully, you just experienced a glitch in the system and will not require any replacement parts. Let me know what you find.
  • Jeff Rockwell
    More than likely you have a operator interface (control panel problem). I was hoping it wouldn't come to that even though it is a fairly simple repair job. The price, however, isn't cheap. A new user interface board will run you about $150 or more. Searspartsdirect.com carries the part. Just type in your model number and locate item number 19 under the "Top and Console Parts" heading. It is sold by color, that is why there are several listed. That's a lot for what may just be a stuck button on the board. But...these boards are not serviceable and require replacement when they go bad. I would attempt to remove the board, first and inspect it thoroughly before you purchase something you may not need. All you have to do is remove the top panel of the dryer first by removing the mounting screws that hold the panel in place in the rear of the dryer. With the top removed, there are a couple of mounting screws along the top bracket of the panel. Remove these screws and disconnect the wiring harness. The entire assembly should just lift straight up. Remove the control knob and the rest of the board is mounted from the inside of the exterior panel. Use care not to lose any of the small pieces/parts while disassembling. The two small push buttons (PAUSE/CANCEL & START) will fall out if you're not careful. Searspartsdirect.com has helpful illustrations to assist you with this. You still may get out of this by cleaning any exposed contacts on the board with a rubber eraser and some alcohol. Also look for any loose wires or connections. If not, I'm afraid you will have to replace it to correct the problem. I hope you find some of this helpful to you.
F25 error code
The "F25" error code means the control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box.
- The hi-limit thermostat kit Part number: AP3094323
Read more: http://forum.appliancepartspros.com/dryer-repair/54078-whirpool-duet-dryer-error-code-f25.html#ixzz2n2Rmgm7a
Dec 10, 2013 | Whirlpool WED9400S Electric Dryer
Whirlpool dryer awd60a manual
Hi
Click the following link to download the whirpool dryer awd60a manual.
I hope this helps.
Dec 10, 2011 | Whirlpool GEW9250 Electric Dryer
GEW9878LW Electric Dryer: Whirpool Dryer - Model # GEW9878PWO - Serial # MS4...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 18, 2010 | Whirlpool GEW9878LW Electric Dryer
Whirpool Duet Washer Model GHW9150PW1 Control Locked
I had the same exact problem, the answer is in the User's Manual for this model Dryer, also here: The Users Manual reads: "TO UNLOCK": Press and hold the END OF CYCLE button for 3 seconds to turn this feature off. I did this and it worked perfectly the first time! My first load is drying now after months of being without the dryer (too busy to investigate!). Good luck.
Oct 26, 2009 | Whirlpool Washing Machines
My whirlpool duet dryer after selecting andpressint the start button , it beeps twice and the time flashes repeatedly and it the time thats flashing not a code it the whirlpool duet model ygew9250pw1...
Try unplugging it and see if it will reset the control panel.I would have to say if that don't work it's a problem electrical and unfortunately you will have to call a repair man.
Most of these machines are under waranty for two years.
Oct 19, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer the control lock light on won't allow dryer
The following link explains how to correct a Control Lock problem on a Whirpool Duet:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If these procedures do not correct the error, you may have a more serious problem. If you need further assistance, please let me know. I hope this helps you.
Jul 28, 2009 | Whirlpool GEW9250 Electric Dryer
Whirpool duet dryer
Press/hold start for 5-10 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 12, 2009 | Whirlpool GEW9250 Electric Dryer
Whirpool GGw9250Pw3 no power on Control Panel Inside light works
In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
Dec 11, 2008 | Whirlpool GGW9250PL Gas Dryer
Whirlpool GEW9250 Electric Dryer Logo
1,078 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
