Userguide/manual for a hpkeyboard 5181
It's a hp keyboard 5181
I hit a key on my 5181 keyboard and now my comp shutdown. Did i hit the hibernate key? if so how do i get my comp back up? HELP
Posted on Nov 24, 2013
How do I turn on numlock in lenovo g550
G550 The keyboard has a separate numeric keypad. To enable or disable the numeric keypad, press the Num Lock key.
Reference user manual: http://download.lenovo.com/UserFiles/UserGuide/en/User's%20guides%20and%20manuals/G450-G550/Lenovo%20G450-G550%20User%20Guide%20V1.0.pdf
I do this for fun & 4 thumb feedback, not $$$$
Jim
Oct 04, 2011 | Lenovo G550-29583AU Notebook
Hi, I have somehow switched the blue numbers on the keyboard, the one at the letters: J; K;L;M;U;I;O and so on. And now instead of them when i type the numbers 1,2,3,4.... will come up instead of...
You have turned on the Number Lock. This enables the number keypad that is embedded in the main keyboard. There is set of three lights to the right of the power button; the middle one indicates when the Num Lock is on or off on the keyboard. To toggle this on or off press and together. The key is between the and the at the lower left of the keyboard.
The user's manual is here: http://static.compusa.com/pdf/Acer_Aspire_5920_Series_NotebookPC-UserGuide.pdf .
I hope this helps.
Dec 11, 2010 | Acer Aspire 5920-6727 Notebook
HP 2820 scanning steps
http://www.google.com.ph/search?q=how+to+use+scanner+in+HP+LaserJet+2820+Printer&ie=utf-8&oe=utf-8&aq=t&rls=com.yahoo:en-US:official&client=firefox
go to this link above, on the bottom you can see HP Color laserJet2820/2830/2840 userguide HP color Laser Jet, left click on this file and you can download the user manual of this printer.
Nov 27, 2010 | HP LaserJet 2820 Printer
LOOKING FOR MANUAL/INSRUCTIONS BOOK
The set upguide and the userguide can be found here http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=uk&product=3177562&lang=en&
Direct link to PDF - user guide http://h10032.www1.hp.com/ctg/Manual/c00901355.pdf
Direct link to PDF - Setup guide http://h10032.www1.hp.com/ctg/Manual/c00901207.pdf
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 30, 2010 | HP Deskjet F2180 All-In-One InkJet Printer
I need instructions for hp J3680 all in one printer
here is the manual for your HP J3680 all in one printer
user guide and setup guide
Click here to Download
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 24, 2010 | HP J3680 Officejet All In One Printer
Dell inspiron 8000 without operating system
First, if you are still running Vista on your desktop then you will need to buy a license for the laptop. Does the laptop have a WinXP on it now? If so, go here http://www.microsoft.com/windows/windows-vista/get/upgrade-advisor.aspx and run the Vista Upgrade Advisor. If not, determine the hardware specifications of your laptop and go here http://www.microsoft.com/windows/windows-vista/get/system-requirements.aspx Compare your laptops specs to those listed for the version of Vista you wish to install.
May 28, 2009 | Dell Inspiron 8000 Notebook
How do i format it
Process for Windows XP Re-installation
WINDOWS RE-INSTALLATION WILL WIPE OFF ALL THE DATA.
1. Insert Windows XP operating System Disk In The CD Drive.
2. Shut Down The system.
3. Disconnect Everything Except Mouse, Keyboard, Monitor And Power Cable i.e. something like internet, printer, USB PEN DRIVE or External Hard Drive.
4. Restart your system and start tapping F8 key on the keyboard until the DELL LOGO passes from the screen.
5. You will be seeing the BOOT DEVICE MENU.
6. Choose the option--> CD-ROM DEVICE or BOOT FROM CD-ROM.
7. When u highlight it and hit enter on it, the screen will show you PRESS ANY KEY TO BOOT FROM CD.
8. Hit enter Immediately on that screen without missing it otherwise all the step will be repeated back.
I'M ATTACHING FEW LINKS FOR YOU SO THAT YOU CAN DO THAT EASILY AND LEARN AS WELL SO THAT YOU MAY HELP OTHERS AS WELL. SO YOU JUST HAVE TO COPY AND PASTE THE LINKS GIVEN AFTER EVERY STEPS TO DO EVERYTHING SO EASILY.
9. Next screen will show --> WINDOWS SETUP, Set up is inspecting your hardware configuration AND THEN set up is loading files.
http://content.techrepublic.com.com/2346-10878_11-5181-1.html
10. When u see the WINDOWS XP PROFESSIONAL SETUP SCREEN.
http://content.techrepublic.com.com/2346-10878_11-5181-2.html
To set up WINDOWS XP now, press ENTER.
11. On the LICENSE AGREEMENT SCREEN hit F8 to accept the LICENSE AGREEMENT.
http://content.techrepublic.com.com/2346-10878_11-5181-3.html
12. Now the Screen will show u the EXISTING PARTITION on your computer so select one at a time and then hit D to DELETE the partition and if it askd for confirmation then hit ENTER to confirm DELETION of the partition. Delete all the EXISTING PARTITION until you see just UNPARTITIONED SPACE.
http://content.techrepublic.com.com/2346-10878_11-5181-4.html
13. When all the partition are deleted then HIT ENTER to INSTALL.
14. The next screen will ask u to CREATE PARTITIONS so its up to u how many partition u will create. Well i will strongly recommend 2 or maximum 3 partitions. So choose the size accordingly.
Create C PARTITION of 20480 MB.
http://content.techrepublic.com.com/2346-10878_11-5181-5.html
15. When u r done with creating partition then just hit ENTER on the NEXT SCREEN and make sure that the HIGHLIGHTED PARTITION IS C ON THE SCREEN.
http://content.techrepublic.com.com/2346-10878_11-5181-6.html
16. Now you will see the FORMAT PARTITION SCREEN so choose the option FORMAT THE PARTITION USING THE NTFS FILE SYSTEM.
http://content.techrepublic.com.com/2346-10878_11-5181-7.html
17. Now time to GET SOME TEA OR COFFEE DUDE because now you will see the SET UP IS FORMATTING THE PARTITIONS so we have to wait few minutes.
http://content.techrepublic.com.com/2346-10878_11-5181-8.html
18. Next Screen Will Show u that SET UP IS COPYING FILES with a moving yellow bar.
http://content.techrepublic.com.com/2346-10878_11-5181-9.html
19. Keep yourself busy with the COFFEE MUG DUDE.
http://content.techrepublic.com.com/2346-10878_11-5181-10.html
20. Now u juss have to sit and relax for next few minutes.
http://content.techrepublic.com.com/2346-10878_11-5181-11.html
21. Get one more coffee for yourself my friend.
http://content.techrepublic.com.com/2346-10878_11-5181-12.html
22. On the Regional and Language Options Screen you just have to click on the NEXT BUTTON on bottom right hand side.
http://content.techrepublic.com.com/2346-10878_11-5181-13.html
23. On the next screen you need to fill the required details as you would like my friend and then click next.
http://content.techrepublic.com.com/2346-10878_11-5181-14.html
24. The next step may or may not come in your screen which is to enter the PRODUCT KEY for the WINDOWS XP as we will use the OPERATING SYSTEM DISK which i believe u must have got from dell but in case you got this screen enter the PRODUCT KEY and click next. It would be located on the DISK COVER or on the BACK OF YOUR DELL DIMENSION 4600 on a WHITE BAR CODED STICKER AND IT WOULD BE OF 25 DIGIT ALPHANUMERIC.
http://content.techrepublic.com.com/2346-10878_11-5181-15.html
25. The next screen is of Computer Name and Administrator Password. You just have to enter the Computer Name and leave the Administrator Password Box blank and click next.
http://content.techrepublic.com.com/2346-10878_11-5181-16.html
26. The Date And Time Settings screen will come up so kindly choose the correct date and time settings with TIMEZONE.
http://content.techrepublic.com.com/2346-10878_11-5181-17.html
27. Now the time will come when you may go and have a burger because this process will take nearly half hour and will keep showing you its progress my friend.
http://content.techrepublic.com.com/2346-10878_11-5181-18.html
28. Network Settings Screen don't bother yourself and concentrate on the burger and click next.
http://content.techrepublic.com.com/2346-10878_11-5181-19.html
29. Workgroup and Computer Domain Screen so click next only.
http://content.techrepublic.com.com/2346-10878_11-5181-20.html
30. Display Settings or Resolution Screen.
http://content.techrepublic.com.com/2346-10878_11-5181-21.html
31. Don't even bother if these screen don't come up.
http://content.techrepublic.com.com/2346-10878_11-5181-22.html
32. Bill Gates Thanksgiving Screen. Click next.
http://content.techrepublic.com.com/2346-10878_11-5181-23.html
33. Windows Updates Screen. So choose first option.
http://content.techrepublic.com.com/2346-10878_11-5181-24.html
34. Click Next If u got this screen which most probably you will not.
http://content.techrepublic.com.com/2346-10878_11-5181-25.html
35. Internet Settings Screen. Choose the second option saying No this computer will connect directly to the internet and click next.
http://content.techrepublic.com.com/2346-10878_11-5181-26.html
36. User Account Screen. Please quickly create the user accounts.
http://content.techrepublic.com.com/2346-10878_11-5181-27.html
37. Thank You Screen.
http://content.techrepublic.com.com/2346-10878_11-5181-28.html
38. Welcome User name Screen. So choose your user name and log in.
http://content.techrepublic.com.com/2346-10878_11-5181-29.html
39. WINDOWS XP RE-INSTALLATION COMPLETED.
http://content.techrepublic.com.com/2346-10878_11-5181-30.html
SO NOW YOUR NEED TO INSTALL THE DRIVERS FOR AUDIO, VIDEO, CHIPSET AND NETWORK WITH THE DELL DIMENSION RESOURCE CD i.e. Drivers And Utilities CD. Or visit the following link from any other computer and DOWNLOAD the drivers and put it onto a USB PEN DRIVE OR A CD and then install it on to your DIMENSION 4600.
LINK FOR DRIVERS
CHIPSET DRIVER
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R58201&SystemID=DIM_P4_4600&servicetag=&os=WW1&osl=en&deviceid=3268&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=1&libid=27&fileid=70069
VIDEO DRIVER ( U NEED TO CHOOSE THE SPECIFIC VIDEO DRIVER)
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
NETWORK DRIVER FOR INTERNET
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R67150&SystemID=DIM_P4_4600&servicetag=&os=WW1&osl=en&deviceid=2834&devlib=0&typecnt=0&vercnt=2&catid=-1&impid=-1&formatcnt=1&libid=5&fileid=87106
AUDIO DRIVER
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R94481&SystemID=DIM_P4_4600&servicetag=&os=WW1&osl=en&deviceid=2430&devlib=0&typecnt=0&vercnt=4&catid=-1&impid=-1&formatcnt=1&libid=3&fileid=122481
May 25, 2009 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
514 people viewed this question
David Payne
David Payne
