Whirlpool gold What does the F3 code stand for?
It may have to do with the door.
Posted on Sep 02, 2008
What does the code f3 in the washer stand for
ARE YOU SURE ITS DISPLAYING F3 INSTEAD OF F35
Jan 21, 2015 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool gold oven message E1-F3-
whirlpool oven starts preheating then turns off and sends a message F-3
Nov 13, 2013 | Whirlpool Ovens
Error Code E4-F3 on Whirlpool Gold stove
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks
Oct 29, 2011 | Whirlpool Gold GW399LXU Gas Range
I have a gold catalyst gsx9885jq0. It has a code reading, F3. It won't do anything.
If I recall correctly, your F3 code has to do with the lid switch. You may need to replace it. Here is a link to the part you need.
http://www.appliancepartspros.com/part_details.aspx?part_id=3020600
Nov 21, 2010 | Whirlpool GSX9885J Top Load Washer
Our whirlpool dishwasher ADP 7408 is displaying a F3 fault and wont work. What is the problem?
F3 error fault code
The heating cycle is not working. The error is indicated after several electronic checks are done over a 25 minute period. Therefore if the heater heats too slowly or the heater is open circuit or indeed the electronic control PCB is defective, each of these will indicate F3. The twist is, if the NTC is fluctuating in its reading it also can indicate F3 and not F1.
Nov 14, 2010 | Whirlpool 33 in. ADP6830 Free-Standing...
What does error code F3 means?
error code f3 shows that there is a problem in the heating circuit of the dish washer. you may need to access the Heater or relay on the control board for any defect also check the wiring
Apr 05, 2010 | Whirlpool 24 in. ADP5962 Free-standing...
Whirlpool Gold Accubake Duo. ''E4 - F3'' or ''E0 - F3''
HI. These codes are an indication of oven temperature sensor failure. The sensor is damaged. This will not allow for proper operations. The affected part must be replaced, asap.
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner.It will look like a 4 inch long slender probe. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Dec 28, 2009 | Kitchen Ranges
I Have a Whirlpool Gold Glass top Range. The Most Recent error code reading from left to right is E2 F3.
Hello welcome
Error code E2 means to
Check door/latch switch
and
Replace door switch if defective
Thank you Huum
Please leave a rating before you leave
Dec 07, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Fault code F3, then F2
Well here's the details about those codes:
F2 :-
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
F3:-
Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor
Apr 04, 2008 | GE JGBP28 Gas Kitchen Range
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
