You have an ice block if the fridge is not cooling and freezer somewhat is. There are a few options you have. First off the bi-metal defrost thermostat has to be replaced. This may be your only problem. The other two things you can check one it your heater. Once you remove the ice to can test the heater for continuity. The other is your defrost timer. Unfortunately you have a computer board that is your timer. You cant test this but you can see if it is working. If the box shuts everything down the fans in freezer and the compressor for 8-30 minutes than kicks everything back on chances are your board is fine. Now to fix your problem.
Option 1 only use if you have a backup fridge to put everything in. Transfer all your food to backup fridge. Unplug fridge for 48-72 hrs with doors cracked open and have towels surrounding the fridge for all the water. Remove back panel in freezer to check for ice block. **Remove back access panel and at the top of coils is your bi-metal. It has two wires going to it. Replace. Now to test the heater you will see the wires to the heater if you have a glass heats there is a pink and blue wire that run down your coils to the heater. Remove the heater and test for continuity. If you have a bar heater you will see two wires running up along the side of coils. You have a bar heater on this icebox. Chances are the heater will still be good. Now once everything is back together than give it a couple hours for temp to get back down before moving your food back.** If you have not heard the box shutdown. Dont put you food back yet give it three days and than check for ice buildup. If I block is forming again replace defrost board if not than it was just your bi-metal.
Option 2: If you dont have a backup fridge. Follow most of steps above once Ice is melted. Get a couple bath towels and a hair dryer. Now remove freezer access panel and with box unplugged start melting all the ice and letting a mojority of the water fall onto the towels. Now once all the ice is melted Take flashlight and look between all the coils. Ice can be hideing and your will have problems again. Now do everything between aristcrats above. Now if you have not hear the box shutdwon your board maybe out. Hopefully its just your bi-metal.
If you have a more question or need further assistance please reply.
SOURCE: coils freezing up on my maytag msd2656dew refrigerator
Replace the thermostat...I had the same problem...I checked the fan, defrost heater and Adaptive Frost control and could not find anything wrong. Replaced the thermostat and the problem went away.
SOURCE: refrigerator not cooling
see if the compressor motor is running
The
compressor is a football-sized case with no apparent moving parts. It's
on the outside of the refrigerator at the back near the bottom. If it
is humming or making a continuous noise and your refrigerator is still
not cooling, there may be a more serious problem with one or more of
several different components, we recommend contacting a qualified
appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
SOURCE: cooling sometimes, freezer leaking water when it stops freezing
That is a indication of a deefrost problem. Not sure if your model has circuit board, or defrost timer.I will do some checking on the Kitchenaid type refrigerator but there are many models. So please locate your model number and we will go from there.
Look at following areas for the model number
SOURCE: Coils freeze up,refridgerator and freezer stops working
The defrost cycle is not working properly, there are three things involved in system. #1 Defrost timer in refrigerator #2 Thermostat on coils to tell if unit is frozen #3 heater element located under coils thaws coils when frozen. the defrost timer if it is manual < located at the front of light assembly panel in top of refrigerator there will be a hole with a plastic piece that resembles a screw strait screw head> it turns and every 8hrs aprox. it stops operations and starts defrost cycle by allowing voltage to the thermostat and if thermostat is frozen it allows power to element for thawing coils. If defrost timer is manual look for direction it is facing and mark edge to see if timer is turning< very slow turning and is easiest way> if you can get an ohm meter ohm the element on high setting< if it has continuity element is operable> check wiring just to be sure not problem. If you find the timer does turn and doesn't stay in one position over 40 minutes then the thermostat is bad.If element fails tesing then the element is bad and if timer stays in one position then it is bad. If unit is equiped with electronic defrost timer and element is good in would replace timer and thermostat to guaranty that resolved problem
SOURCE: freezer won't freeze, but refrigerator section
one problem i had was the condensor fan had stopped working because it was clogged up with ice buildup, check and make sure the fan is not iced up, once a year i have to unclog ice from the condensor fan which located behing the white panel, which you unscrew and you can get a visual on this fan. my freezer would stop working but the fridge part was fine. something as small as that was causing this problem for me.
