Question about Kenmore 24 in. 17462 / 17464 / 17469 Built-in Dishwasher
Kenmore Elite 17469 wont start cycle but wil drain
I have a Kenmore Elite dishwasher 17469 type 577. It will drain, but wont start or respond to pressing a cycle.
  • ftldml Oct 12, 2008
    Dishwasher appears to fill, but does not do anything after that. Tried in all cycles and no luck. Steam comes out when opening.
  • 13 Answers
SOURCE: Kenmore Elite wont power on
Door switch. If the washer thinks the door is open, it won't run.
Posted on Aug 20, 2008
SOURCE: Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Posted on Nov 05, 2008
  • 338 Answers
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Posted on Nov 25, 2008
SOURCE: kenmore elite dishwasher stopped in middle of cycle
My Smeg (never buying brand again) dishwasher UKSTX1 has error message e9 not covered in manual
Posted on Jan 26, 2009
  • 686 Answers
SOURCE: Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Posted on Feb 20, 2009
Kenmore elite dishwasher manual
The cancel light is on because the cycle maybe paused or canceled. The lit red button should say Cancel/Drain. If you already tried to press start and if it won't finish the cycle then try pressing the Cancel/Drain to drain and start over.
Aug 15, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dishwasher wont finish any cycles
That blinking light is trying to tell you that there is something wrong with the dishwasher. You need to fix the problem or else that blinking light will come back. And the number of times it blinks (before it pauses and repeats) will tell you (or a technician) what is wrong. How many times does it blink?
Jul 04, 2014 | Kenmore Dishwashers
Got a used kenmore elite and I am looking for an instruction manual. I need more info on the washing cycles. Does it normally take 1 1/2 hrs to wash on the quick cycle mode? Model # 665.17483300 Type...
Here's a link to your model, showing exploded diagrams and parts lists, for future reference.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66517483300/0582/0130000?pathTaken=&prst=0&shdMod=66517483300
And your manual.
http://www.managemylife.com/mmh/owner_manuals/10240/KENMORE-Dishwasher-L0308215?brand_name_search=665.17483300
I found similar Kenmore dishwashers on Consumer Reports with around 135 to 145 minutes for a normal wash cycle and around 5 to 6 gallons per wash. A quick wash would take somewhat less, depending on the model. But not much less. I think you are OK. Because dishwashers are using less water these days, they count on longer wash times to produce the same effect.
Best regards, --W/D--
Mar 11, 2011 | Kenmore 24 in. 17483 Built-in Dishwasher
Won't turn on
If the dry light is flashing you will need a new keyboard, if the clean light is flashing try this key dance
normal, heated dry, normal, heated dry
wait for the lights to come on and then go off, press cancel and wait 2 minutes, try a cycle. If it works and fails again let me know we can dig deeper to find out the root cause
Apr 24, 2010 | Kenmore 24 in. 17462 / 17464 / 17469...
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Has become very noisy during sensing cycle.
Either the motor is failing to pump water or there is too much soap in the system. Add 1/4 cup veg oil and run again.
Sep 24, 2009 | Kenmore 24 in. 17462 / 17464 / 17469...
Kenmore Elite Not Draining Water Completely
Check this link. Multiple causes are possible yet most is how drain is hooked up to disposal and back pressure built up. Hose must be installed correctly.
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=water-wont-drain
Jul 22, 2009 | Siemens 24 in. SE64A630GB Built-In...
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
How long is too long?
I doubt it. If the unit has a mechanical timer, it is binding. If the shaft cannot be cleaned up, it will have to be replaced. Typical times are 40 minutes to an hour, depending on the cycle.
Feb 17, 2008 | Kenmore 24 in. 17462 / 17464 / 17469...
Open Questions:
Kenmore 24 in. 17462 / 17464 / 17469 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
