Question about Dryers
Maytag Performa dryer venting
When we bout our Maytag Performa PYE3200AYW electric dryer years ago, it was modified at the appliance shop to route the vent out the bottom. The shop replaced the original internal rigid vent pipe with aluminum foil flex. I want to change it to vent out the back using a rigid vent pipe from the internal blower to the opening in the back. Which type of rigid vent pipe should I use, aluminum or steel? Steel seems to get hot. Will steel get too hot inside the cabinet?
My current internal vent runs out the side, I need to change it to the back but cannot find directions for it. I have the model Mdg6800aww.
Posted on Nov 23, 2013
    Guru:
  • 93 Answers
Absolutely Agree, Good Advice
For more information on Dryer Vent Safety follow the link below, very useful information
http://www.applianceoutletservice.com/ApplianceTips/dryer/Dryervent.htm
Posted on Oct 30, 2008
  • 706 Answers
You are always better off using steel on these kinds of conversions and do not worry about how hot it gets,..Aluminum will get hot too. Steel is more rigid and less likely to dimple in while installing or hooking up the external vent system... Hope this helps..
Posted on Sep 01, 2008
Maytag Performa Electric dryer timer is bad
Look up an appliance parts store in your area. If there is no appliance store, try www.searspartsdirect.com.
If it does not turn off during timed dry then it for sure has gone bad. If it takes a while on timed dry then it is most likely that your thermal fuse/ valve coils are going bad.
Jan 14, 2010 | Dryers
Thermal Fuse PYE3200AYW Maytag Elec Dryer
BEHIND THE UNIT U WILL SEE A VENT U CANT MISSE IT
Aug 19, 2009 | Maytag PYE2300AY Electric Dryer
Need ohm readings for Maytag Performa Model PYE 3200AYW
Go to this site for info on your dryer type, you may find what you need there...
http://www.applianceaid.com/ww-and-mc.html
Jan 14, 2009 | Maytag PYE2300AY Electric Dryer
Maytag performa dryer doesn't fully heat
A couple of suggestions. STOP, be sure the gas it turned off before disconnecting the line. Move it to an open area and check all venting. A good cleaning makes a huge difference. I believe your problem to be the heating coil is on it's way out, "works sometime". Write down the Make, Model, Seriel Number & Year of MFG...someone may ask for it..Check Your local appliance store for price & availablity Easy to replace on most model dryers.
When reattaching the gas line, be safe not to overtighten the coupler. A safe test for leaks is NOT a match... a drop or two of dishsoap around the fittings will bubble if it is not sealed. Good Luck
Jan 02, 2009 | Maytag Performa PAV3200
Maytag dryer starts to heat then it stops #pye3200ayw
There are a couple of things that could be causing this problem for you. First off check and make sure that you have good air flow coming from the vent outside the house. If it feels weak then that is probably your problem. If there isn't enough air getting out the thermostat will shut off the heating element for safety reasons. If the air flow feels good then the problem is probably with your thermal fuse. That is a nice cheap part running around 15 dollars at your local appliance repair shop. The thermal fuse is located on the heating element housing and has two small wires coming off of it. Make sure you unplug the dryer before working on it though. Let me know if you have any other questions and let me know if this was helpful for you. Good luck and I am glad I could help.
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
Maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Dec 01, 2008 | Maytag Performa PAV2200
Maytag performa dryer pye/g2200
hi .thanks for the question .no the element does not go bad a little at a time. but the venting gets clogged up a little at a time . remove the venting and clean to the outside wall . also if the dryer is noisy you could have a blower problem. if the dryer is noisy .but check the venting thanks the appliance doc
Oct 01, 2008 | Maytag PYE2300AY Electric Dryer
Maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Mar 18, 2008 | Maytag Performa PAV2200
Dryers Logo
237 people viewed this question
Top Dryers Experts
