Question about Fuji FinePix S1 Pro Digital Camera
Faulty Latch Sensor
I've got a FinePix S1, and it seems that the little sensor that detects whether the cover of the compactflash/smartmedia slots is closed is broken. The camera behaves as if it were always open, displaying the "Err/full battery" message.. looking in there with a flashlight doesn't reveal any kind of switch for the plastic nib to depress. Is there any way to tell the camera to ignore this latch? Alternatively, is there any way I can fix this myself? I'd be comfortable opening up the camera back myself, but there's some sort of latch or catch in the upper right of the back that I can't figure out how to release.
In the bottom corner of the latch there is a little piece of plastic on the hinge that pushes a switch that tells the camera the latch is shut if thats broken off thatll be the problem id shove a piece of a matcher in to see if it does the trick and if so its a new latch or leave the matcher :) 5
Posted on Nov 03, 2006
My alarm keeps going off. Last year I had the hood latch repaired. And it worked for 1 yr, 1 mth. I would rather disarm the alarm than pay another $200 for another hood latch. Where is the fuse that...
I've had same problem. Dealer refused to replace hood latch under their extended warranty despite the Toyota Bulletin on the problem. I just DISCONNECTED the hood latch sensor. To get to the hood latch get under the plastic covering over the hood latch by removing the plastic retaining buttons attaching the cover to the frame. Do this by using a sharp edge to pull up the center piece of the retaining buttons, which then lets the outer button pop out. After you get under the plastic cover find the wire coming out of the latch assembly (not the latch release cable you used to open the hood). The sensor wire couples with other wires for the alarm right there. Just disconnect it. The dealer said I may not be able to lock by car as a result of disconnecting the hood latch sensor. But that hasn't happened, and the alarm hasn't gone off since.
Jun 06, 2011 | 2008 Toyota Highlander
Card not initialized
If the 'CARD NOT INITIALIZED' error appears:
First check that the SmartMedia is inserted in the correct direction. You can also try wiping the gold-colored contact area on the SmartMedia with a soft cloth.
Remove the batteries from the digital camera, leave them for at least an hour and then reload the batteries and check whether the camera recognizes the SmartMedia.
If the 'CARD NOT INITIALIZED' error still appears, contact the store where you purchased the camera or the nearest FUJIFILM authorized service center in your country.
Mar 13, 2011 | Fuji FinePix A400 Digital Camera
How to replace the oxygen sensor
Removal & Installation Upstream HO2 S1 To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the HO2 S1 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust manifold.
  1. If necessary remove the fuel injector cover.
  2. Disconnect the HO2 S1 sensor electrical connector.
  3. Using an oxygen sensor removal tool carefully remove the heated oxygen sensor.
To Install:
  1. Coat the threads of the oxygen sensor with anti-seize compound
  2. Install the HO2 S1 sensor. Tighten the HO2 S1 sensor to 30 ft lb (41 Nm).
  3. Connect the HO2 S1 sensor connector.
  4. If removed, install the fuel injector cover.
Downstream HO2 S2 To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the H02 S2 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust pipe.
  1. Raise and safely support the vehicle.
  2. Disconnect the H02 S2 electrical connector.
  3. Using an oxygen sensor tool carefully remove the H02 S2.
To Install:
  1. Coat the threads of the H02 S2 with anti-seize compound.
  2. Using an oxygen sensor tool install the H02 S2. Tighten the sensor to 30 ft lb (41 Nm).
  3. Connect the H02 S2 sensor electrical connector.
  4. Lower the vehicle.
Oct 07, 2010 | 2001 Buick Regal
My fujifilm finepix s5000 SN 4FL37025
This is the classic symptom of a failed CCD sensor. The only fix is to have the sensor replaced, but as the camera is around six to seven years old now any repairs will not be cost effective and you will likely have trouble sourcing the parts as Fuji stopped making their 3MP sensor many years ago. New, old stock sensors may also have degraded to the point where they are either faulty straight out of the box, or will develop the same fault within a few months of being powered up.
Sorry, but your camera has reached the end of it's useful lifespan: five years is pretty good going for any digital camera and six to seven is really exceptional. Digital cameras simply do not last anywhere near as long as many of the film cameras which they replaced.
Your only real choice is to buy a replacement, but if all you need is a similar technical specification to your current model then there are plenty of cameras for less than £100 (around $175 in OzDosh) which will do at least as good a job as your present camera. Just don't expect a sub £100 camera to last anywhere near even five years though.
One other advantage of an update is that you'll finally be ditching the expensive and highly inferior xD memory cards which were basically repackaged and slightly tweaked SmartMedia cards. If you buy a new Fuji then you'll find that they all take SDHC cards now (back compatible with SD cards) although they often still accept xD cards as well.
Sorry I can't be more positive, but I hope that I've still helped you. All that I ask in return is that you take a moment to rate my answer.
Jan 11, 2010 | Fuji FinePix S5000 Digital Camera
Seatbelt bell keeps ringing bell
It sounds like the sensor in the latch is faulty or the wiring leading to the latch is bad. The sensor will be located inside the latch assembly. You'll have to pry the cover off to get to it.
Oct 07, 2009 | 2004 Chrysler Sebring
I do not know where to put the memory card into epson rx 425
There is a little panel on the front left, you can download the user guide fro Epson here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=nKGrQtfEm6mIr17BBoUTdZr5V9BVmX64&tc=5#10
Loadable memory card
This product features three memory card slots.
The types of memory cards loadable for each slot are shown below.
Slot
Card
a
Memory Stick/MagicGate Memory Stick/Memory Stick Duo*/
Memory Stick PRO/Memory Stick PRO Duo*/SD Card/miniSD Card*/MultiMediaCard
b
SmartMedia/xD-Picture Card
c
CompactFlash/Microdrive
r_space.gif * An adapter is required.
Mar 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
How to erase pictures stored in my camera, finepix s1pro
one by one is dificult and time taking
just bring them on any pc thru cable select and keep them for future
now it better to format the card and then later on if u want u can copy them on the card the selected one's
compact flash u can format thru connecting ur cam to pc and then select ur removable drive from my computer and simply format it by right clicking the drive
Nov 20, 2008 | Fuji FinePix S1 Pro Digital Camera
What is the difference between the PC-AD, the PC- AD2, and the PC-AD3?
The PC-AD can only be used with 5V SmartMedia. The PC-AD2 is compatible with SmartMedia of 3.3V/5V, 2MB to 8MB. The PC-AD3 is compatible with SmartMedia of 3.3V/5V, 2MB to 32MB.
Aug 29, 2005 | Fuji FinePix S1 Pro Digital Camera
The batteries were drained in my FinePix S7000 camera whthe camera was not in use.
The CompactFlash card may have caused the batteries to drain. Some solid state CompactFlash cards consume power while inserted in the FinePix S7000 even if the camera is turned OFF. Fujifilm recommends removing the CompactFlash card when the camera is not in use. Microdrives and xD-Picture Cards do not exhibit this problem.
Aug 29, 2005 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S1 Pro Digital Camera Logo
140 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
