Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printing problem Kodak will not print Black when printing documents only colors show up. functions properly when copying
  • bajasi Sep 01, 2008
    kodak 5300 AiO prints colors OK but has problems printing black. Usually too dim to read. Windows test printer page prints black fine but then I print a document and it is dim. Have changed to new cartridges several times and done maintenance alignment and cleaning several times.
  • 21 Answers
Most likely your print head is clogged, there are 2,00 some nozzle's in it. If the printer is not used for a moderate amount of time the ink can dry up and cause a clog in those nozzle's. You can try doing a printhead clean from the main menu, or homecenter->?->maintenance. Then after that do a calibration, print a demo sheet to see if there is any improvment. The printhead clean pushes ink through the nozzles to try to clear clogs. The calibration scans those nozzles to see which are avalible to use, and makes sure that all the avalible nozzles are being used. If this does not fix the problem you most likely need a printhead but you will have to call kodak; as they are not avalible in stores.
Posted on Sep 02, 2008
How to remove printhead
Alignment shows black & streaky, only covers 3/4's of a line, color is good. The printer copies a document no problem; but only copies color (no black) from the computer. If the document is black print, I get a blank page. Do not know how to remove printhead
Jun 29, 2013 | Dell V313w AllInOne InkJet Printer
WE HAVE A KODAK ESP-3 AND HAVE PUT IN NEW INK (BLACK) AND IT WON'T PRINT. THE COLOR SHOWS EMPTY BUT IT'S ALSO NEW. ONLY WANT TO PRINT BLACK BUT IT WON'T PRINT EITHER JUST SHOWS LOW INK ETC.
First: you need both ink cartridges for the printer to function properly.
Second: You may have a bad printhead, do the following:
Clean the print head then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Contact Kodak:
All-in-One Printer Phone Support Live telephone support is available in English and Spanish at 1-800-421-6699, 9 A.M. to midnight, Eastern Time, 7 days a week. The expected wait time for phone support is 15 minutes.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 27, 2011 | Office Equipment & Supplies
Our printer will use the copier and scanner function fine but when we try to print some thing out it will not use any ink. we replaced both ink cartage black and color. All colors work when we copy or scan...
Do give the ink some time to come through, gravity will do the rest.
You could clean the ink heads to get the ink to come through quicker.
When printing the document, go through the settings and see if you see anything to do with the darkness of the print.
damnor01
Jan 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My printer will not print black from a program on my Pc. I can copy or scan and it will print in black.The color is fine.
The problem is with the Program not the Printer. adjust the settings while printing from that program in printing preferences. try to print any microsoft word document.also, Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning.this should solve the issue keep me posted.
Jun 25, 2009 | Kodak ESP 5 Printer
Kodax Eps-5 Printer want print with one cartridge
No you need functioning colour cart for black to work.
Apr 28, 2009 | Kodak ESP 5 Printer
I have a Kodak easyshare all in one printer 5100
You need to clean the printhead of the printer to solve that
issue. Because everytime you print, excessive inks are going
to the printhead that's the reason why it's clogging the
system up. That's because Kodak printers is using
"pigments" as inks that's why Kodak printers are producing
high quality prints unlike other printers - a photo printed from
kodak could actually last for about 100 years. Now back to
your issue, you need to clean the printhead from the printer
but not manually. You could clean it by going to the
software of the printer namely the KODAK HOME
CENTER SOFTWARE. You need to click the "?" mark
icon on the upper right corner of the software window then
under the General Links select Maintenance then choose
Clean Printhead. Do it at least twice and then try making
prints. If that still doesn't work try calling Kodak Technical
Support Representative: 1-800-421-6699
I hope I have been some of help. ^_^
Nov 10, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Scanned Items or Copies all print in Solid Black
I assume that you mean color images are being produced in black and white. If that's the case, there's a document on the HP web site that shows you what to look for and provides solutions:
Color Image Prints in Black and White
Good luck.
Sep 13, 2008 | HP PSC 1610 All-In-One InkJet Printer
Printing problem
Since it sounds like you've gone through all the steps to clean the print head, I would suggest trying a new black cartridge. There may be a problem with the one you have.
May 27, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
69 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
