Question about Audio Technica AT-PL50 Turntable
Audio Technica AT-PL50 Stereo full automatic turntable system
The arm goes over the record, hovers, then returns to the cradle-- never making contact with the record.
  • Anonymous Dec 31, 2008
    arm plays until about 3/4s through record, then pulls back. wont let me play the last 1/4 of any record.
  • jalso Dec 31, 2008
    arm plays record until about 3/4s through, then pulls back and returns to cradle. wont let me play the last 1/4 of any records. help!
Try winding the turntable at least ten times clockwise per the instruction manual to reset the mechanism.
Posted on Jul 26, 2009
Try pushing the button on the far right. I had this same problem last night before I released the button was in the wrong position. It is called the "Lift" button and when depressed it lifts the needle up from the record- or keeps it raised and never lets it come down.
Posted on Jul 16, 2009
Akai fully automatic turntables tone arm not functioning properly
And when you tell us what it is doing and not doing we can consider a solution.
Jan 24, 2013 | Audio Technica AT-PL50 Turntable
When playing a record the needle gets stuck at the same place, near the end f the record evevry time. Does not matter what record. Happens with all of them.
I don't know the AT PL50 but I had a similar problem with another make of turntable.
The problem was caused by the rear end of the pick-up arm hitting the side of the perspex cover. The solution was a simple one - leave the lid in the raised position or lift the cover right off when playing records.
Jan 30, 2011 | Audio Technica AT-PL50 Turntable
I have an Audio-Technica turntable (AT-PL50). I recently moved and when I hooked my turntable back up, the sound is terrible. It sounds distorted, similar to the sound of blown-out speakers. But, I checked...
it sounds like your cartridge is shot and damaged.
this turntable has fixed cartridge and only the stylus can be changed.
check out this manual: http://www.audio-technica.com/cms/resource_library/literature/0fb01429606842cf/at_pl50_om.pdf
Jun 20, 2010 | Audio Technica AT-PL50 Turntable
Tone arm comes out and touches record, then goes back to cradle
See what kind of arm position sensing elements are used in your turntable (micro switches, optics or possibly other) and check if they work correctly - sometimes a microswitch can be damaged or have oxydized internal contacts or a badly soldered / broken wire and it will not function properly, causing the unit to stop automatically, the same might happen if the sensor is of optical type and there is some dust or broken wires or if the emmiter or sensor is damaged. Also, it could be a problem with the part that activates the switch / optics, it might be displaced or damaged.
If all sensors / switches seem to work well, then check the section which has wires going to those sensors / switches, it's the next probable location of the fault (it might be an electronic controller so there could be damage to some components, broken wires, dirty connectors or bad solder contacts).
It could as well be something else in the mechanisms, wiring or electronics, i just suggested a few things that might cause the malfunction you described.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Audio Technica AT-PL50 Turntable
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Belt is off my audio-technica turntable at-pl50
WASH YOUR HANDS FIRST! Any oils on the drive belt may cause slippage.
This is from the manual:
A) Remove the record mat from the turntable platter
(Fig. 10a). Through an opening in the
turntable platter, visually inspect to see if the drive belt
is around the motor pulley (Fig. 10b).
B) If the drive belt is not around the motor pulley: Lift
and remove the turntable. Place a thumb into each of
the left and right openings on the turntable platter; and,
using the fingers to press down on the turntable housing’s
surface, pull the platter straight up (Fig. 10c).
Avoid pressing on the tone arm.
C) With the turntable platter bottom side up, place the
belt along the outside wall of the turntable platter's
drive rim, making certain that the belt is smooth and
flat all the way around (Fig. 10d).
D) Put the turntable back on the center spindle, make
certain it is fully seated, and align one of its openings
over the motor pulley position.
E) Through the opening, carefully hook the turntable
belt with a finger or with the original red ribbon (never
use a sharp object) and pull the belt over the motor
pulley (Fig. 10e). Make certain the belt is not twisted
between the pulley and the platter’s drive rim.
F) Put the record mat back on the platter.
G) While holding the tone arm in its rest position,
slowly turn the platter by hand clockwise at least 10
rotations to clear the mechanism’s automatic cycle.
Apr 24, 2009 | Audio Technica AT-PL50 Turntable
Turn table set up
NCH software has what you need
good stuff, free trial
Dec 24, 2007 | Audio Technica AT-PL50 Turntable
Audio Technica AT-PL50 Turntable Logo
538 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
