Question about Philips 5-Device Universal Learning Remote Control
Programming dvd i can't program my dvd player to the dvd button,the vcr is programmed
    Problem Solver:
  • 6 Answers
Firt of chek ur dvd remote near by ur mechanic then go 4 prog
1.chek the batteries
2.check weather remote is working r not
Posted on Sep 01, 2008
4 Suggested Answers
  • 833 Answers
SOURCE: codes for my dvd player and zenith vcr
Most remotes use the same code sets. Here's what Radio Shack says for your brand:
dvd: 0503,0539,0646,0675,0821,1268,1914
vcr:0000,0039,1137,1479
let me know how you made out.
Posted on Dec 18, 2007
bubba10560
SOURCE: programing rca remote for dvd/vcr combo
all you have to do is press and hold code search when the light shows up let go of code search then press VCR and it will blink onces and let go of VCR and press OFF/ON about 50 times and then press enter onces and there you go
Posted on Mar 07, 2008
SOURCE: Need a code for a VCR/DVD player for my universal remote
Magnavox VCR. The Phillips universal remote lists the following codes:0330, 0430, 0534, 0324, 0224, 0124, 0247, 0230, 0125, 0093, 0598, 0830. Doesn't seem they have much control of which code gets used on which model. Start in the middle and work both ways to the ends. Make sure to post back which one you find that works.
Posted on Jan 15, 2009
Can't find how to program remote to dvd
if the remote came with the player it does not require any programming by you .just add batteries
Feb 13, 2016 | Toshiba Televison & Video
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it.
http://remotecodelist.com/remotes/magnavox/magnavox.htm lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | Televison & Video
How do I program an apex ad 1110wm DVD player with a RCA universal remote?
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR,DVDor Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Sep 16, 2011 | Apex Digital AD-1110W DVD Player
We need to program our rca rcu800x so we need the dv5500 code
hi,
Code for Samsung DVD players are,
394, 395, 396, 506, 507
Procedure for entering codes to RCA RCU800X
1: Press the "CODE SEARCH" button until the indicator light illuminates, then release.
2: Press and release the device (VCR, TV, Cable etc.) button. If programming for AUX, press and release AUX button first, then press the device type to be programmed. The indicator light blinks and then remains lit.
3: Enter the 3-digit code number. After you enter a valid three-digit code, the indicator light turns off.
4: With your device on, press a button (ON/OFF, "PROGRAM UP/DOWN" OR "VOLUM UP/DOWN") to test. If your TV doesn't respond, repeat the steps above, entering the next code for your brand.
ok
Jul 22, 2011 | Samsung DVD-V5500 DVD Player/VCR
Instructions on how to program
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn't work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thank You
Sep 18, 2010 | One For All URC4220 Remote Control
I have URC3220 remote and a Magnavox TV How do I program it?
PLease follow the steps below
1.Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
6.You are set
thanx
Jul 24, 2010 | One For All URC4110 Remote Control
Sanyo dvd/vcr combo
Your universal remote would have seperate selection buttons for VCR and DVD. If you don't have a VCR button, use AUX. Try programming each function seperately - DVD code for your manufactirer on the DVD button and VCR code for your manufacturer on the VCR button.
Sep 12, 2009 | Sanyo DVW-7100A DVD Player/VCR
MWD2205 remote stopped working for DVD functions
not sure but it sounds like you need to push the dvd button itself before dvd functions will work-it's to the left of the pause button. same thing happened to me and when i try that it works. remote seems to default to vcr i guess ....
Mar 23, 2009 | Philips MWD2205 DVD Player/VCR
Coding to VCR and DVD
IF not then you should be able to program in Emerson 0591, 0675 for the DVD player
Emerson 0037, 0184, 0000, 0121, 0043, 0209 for the VCR
THe problem arises however, that the vcr and the dvd function buttons are the same, so you can only program one or the other. You need A different remote. I would suggest the 15-2142 made by radioshack. It is the Family 4 in 1 remote, and it has all the functions you need. THis remote is also backlit on some buttons to make it a little easier to see in the dark.
Mar 12, 2008 | Radio Shack (15-2147) Remote Control
Turning on VCR for 2nd time recording
Have you fixed your problem?
If not, just try pressing the dvd/vcr button, so the vcr becomes the primary device. Now you can press setup and go back into the vcr menu.
Nov 11, 2007 | Toshiba SD-V394 DVD Player/VCR
Philips 5-Device Universal Learning Remote Control Logo
102 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
