Question about Whirlpool Dryers
Hi my whirlpool AWG200 nno longer gets hot... is this fixable
  • 5,911 Answers
I'm assuming your dryer is still running, correct? That is, the drum spins, but the dryer doesn't heat? If this is the case, the following link gives you some great advice on how to troubleshoot these symptoms:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the portion of the write up where it discusses proper ventilation. In many cases, what appears to be a major problem, could be a need for a good cleaning. A dryer left in a condition where it is starved for air, will cause the heating circuits will actually over-heat. Over an extended period, the heating circuits will eventually fail. The most common failed item is the thermal cut-out. It is designed to trip in an overheat condition. Read through the write-up thoroughly and let me know what you discover. Hopefully, you will not require any replacement parts. If you do, post back with your COMPLETE model number and I can assist you with identifying part numbers. I hope you find this information helpful.
Posted on Sep 01, 2008
I have a whirlpool Gold quiet partner III that is about 14 years old. It is no longer getting dishes consistently clean.Is it something fixable or is it time to get a new one?Could it be cleaned out?
There are many places and parts for dirt to remain after washing. Clean all parts as per manual. Spray inside with vinegar and lemon juice, place tablespoon of bi-carb soda in dispenser and put through cycle without dishes
Feb 25, 2015 | Whirlpool Dishwashers
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Hi. I've just been loaned a Whirlpool awm 5125/4 washing machine (while mines gone for repair), but it has on the back of the machine, a hot inlet and a cold inlet. My machine only requires a cold water...
Your machine can be connected for cold fill only but, you will need to connect a "Y-Piece" for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine. The wash cycles will take longer when connected this way as the machine has to heat the water internally. It will also be less energy effecient.
Please post back if you need further assistance.
Regards,
BElectric
Dec 11, 2010 | Whirlpool AWM5125/1 Front Load Washer
I have just moved into a new house with what looks like quite an old ADG7540 dishwasher. The detergent dispenser doesn't open during the cycle - even though I have cleaned it. There also doesn't appear to...
Hi jo..... many of the old dishwashers did not have an upper arm. Regarding the detergent dispenser there are a couple of reasons why it no longer operates but rather than spend money on a repair I recommend that you simply purchase the 3 in 1 tablets and toss one right into the floor of the dishwasher and turn it on. That said, always run the hot tap water into the kitchen sink until it is as hot as it will get BEFORE turning on your dishwasher.
AND since this is an older model always rinse any food or debris from the dishes before placing them into the machine. Joe
Thanks for choosing Fixya!
Dec 04, 2010 | Whirlpool 24 in. ADG7540 Built-in...
I have a Whirlpool Gold dehumidifier that's about 5 years old. The motor sounds and runs just fine, but it's no longer collecting water. Is it fixable?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 02, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Fridge Freezer is blowing out hot air, is this fixable and cheap to fix?
is this under warranty? not a year old? thermostat or low refrigierent in compressor.thermo replace price ok.comp refrig can be expensive. hope this helps
May 21, 2009 | Whirlpool Freezers
Whirlpool MH7140XFQ-1 microwave no longer heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
kggk
Apr 24, 2009 | Whirlpool MH7140XF Microwave Oven
HELP DESPERITE DAVE?
the 2 outside ones and the middle is the ground
Jul 15, 2008 | 1996 Dodge Avenger
Dell Inspiron 5160 screen
The only way to fix it is to buy and install a replacement LCD.
LCD's are available for about $100 on EBay, but the you have to know the size a resolution of the screen before buying a replacement. (14.1 or 15 inch, XGA, SXGA+ or UXGA resolution)
May 15, 2008 | Dell Inspiron 5160 Notebook
Dryers Logo
63 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
