Question about Samsung SV5000W VHS VCR
Tape stuck, no indicators lit
Device stopped working when playing  tape. Now the tape is stuck. When plugged in, he device lights power-on button, but pressing it does not put the VCR to life. No indicators light up. Instead, it looks like a faint horisontal strips glow across the indicator panel. Eject does not work a well as all other buttons.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Check the tip in my profile
Posted on Jul 18, 2010
How to dub tape to tape
Hi Dale,
You're kind of light on details of the equipment you're going to use - so the best I can do is provide generic instructions. You'll need two devices - one must be able to perform playback for source media and the other for recording or copying duties. Inspect the jacks provided on the rear of both units. Most provide standard RCA type "Phono" jacks for left and right audio channels. Connect a stereo patch cable (with plugs that match the jacks of the playback and recording devices) between the left and right OUTPUT (or "PLAY") jacks on the source device and the left and right INPUT (or "RECORD") jacks on the recording device. Insert the source tape, cd, album, etc. in the device that will playback the original and insert a high quality blank media into the device that will provide recording capabilities. Begin playing the source. Set options such as tape bias, Dolby Noise Reduction, etc. on both source and recording devices to match media in each. Advance the playback source to a point that contain the loudest sections. Set recoding levels by monitoring the VU meters on the recoding device and vary the input adjustment levels so that only the loudest prortions of the program just begin to briefly "flirt" with the 0Db or red zone of the meter. Signals that cause the meter to indicate into this area and beyond begin to overload the amount of information that can be recorded on the blank media and often result in muddy audio quality during playback, later. You should also record the same section repeatedly with differnt options (bias, noise reduction, etc.) to actually hear the difference to determine which sounds best to you. Once levels are set, queue the playback device and start recording. In the case of tape, allow enough recording time to let the leader section of the tape to pass beyond the recording heads for several seconds or more. Once the desired amount of silence has elapsed, play the source program. Allow it to run to completion using both sides in the case of tape and then playback the entire new recording to make sure it recorded without any issues.
Apr 09, 2015 | Televison & Video
We had this machine in storage for two years, since then I can set the clock, but that's about it. the front panel indicates commands from the remote but the tape drive ignores these?
Sometimes when a device has no power for some time, certain parts can malfunction. Generally these are electrolytic capacitors, who won't charge up anymore.
Aug 11, 2014 | Televison & Video
VHS tape is running at high speed when insert it to VCR. no playback..buttons doesnot work.
Check if the fast forward button is more inside than the rest of the buttons. May be its stuck in the ff position. After all they were just micro switches below the plastic buttons strip. The specific ff micro switch may be stuck, if I were you I would try some switch cleaning spray to loosen it. But be prepared that the control ic is busted.
Jun 21, 2014 | Panasonic Televison & Video
Govideo DVD/VCR combo, vcr side not playing properly and won`t release the tapes.
MAKE THIS TEST AND FIX IT. God bless you
1.
    • 1
Make sure the device is plugged into the household power supply and is switched on if no indicator lights are illuminated on the control panel. Watch for any power-saving technology that can shut the recorder down when it's not being used. Try the "Power" button again.
    • 2
Verify that the media you are using is compatible with the device. Most combos record to DVD-RAM/-R/-RW/+R/+RW Discs on the disc side. VHS cassettes can have erasure tabs, so check that the tab is still there if you can't record to the cassette. Watch out for copy-protection technology on either the tape or disc. Often it's indicated on the packaging. Copy protection is designed to stop illegal reproductions, so may block many recordings of copyrighted material.
    • 3
Connect a television to the "Video Out," "S-Video Out" or "Component Video Out" jacks on the DVD-VCR combo if you can't see video from the combo playing on the television.
    • 4
Forcibly eject a disc if it is stuck in the combo. Often, manufacturers will create a sequence of buttons to use that accomplishes this. On a Panasonic, you force the combo into "Standby" by pressing "Power" for 10 seconds. Then press and hold "Stop" and the "Channel Up" button together for five seconds, and the disc should eject.
Oct 30, 2013 | Televison & Video
Have a Sony HVR M25U deck and put in a mini-dv tape and the tape played fine but not able to play, ffwd, rwd or stop. So I unplugged power cord on deck. Plugged power cord back in and now the tape is...
DO NOT , UNPLUG THE POWER CHORD, DO ONE THING SWITCH ON THE VTR AND THEN HAVE AN ALL PIN .. THEN RESET THE MACHINE ... WITH THAT PIN .. AND THEN PRESS EJECT ... YOUR TAPE WILL COME OUT ..
Jul 14, 2011 | Sony HVR-M25U HDV VCR
Tape won't play, FF, or eject.
sorry to say that none.no trip button for that.i assumed that the magnetic strip of the tape is already wind up inside.you'll need to open the unit up and gently rotate the flywheel of the tape player until you can open the door of the tape compartment.no need to force or it will just break.
Jun 22, 2009 | Sony EVC100 Hi8 VCR
Eject light comes on after I start playing the tape
ksmitheram,
I had the same problem with my camcorder just awhile ago. This can reflect a low battery. Try plugging in the camcorder for a couple of hours without using it. Then try recording or playing back the tape with it plugged in. Unplug it and check again. If this does not work you may have to replace the tape head.
Dec 25, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Sony DVD/vcr combo stops
This is an indication that the tape sensors may be dirty or going bad. It could also be due to tape tension (the lack of). Do you have the service documents for this device?
Sep 21, 2007 | Televison & Video
Samsung SV5000W VHS VCR Logo
111 people viewed this question
Henry  Thomas
Henry Thomas
