Question about Kenmore 62702 Microwave Oven
Model 72180883400 Oven runs for few seconds then stops. F-9 failure code is shown on the display. Power cycling the unit did not help. You help is greately appreciated. Thanks.
    Genius:
  • 3,422 Answers
F-9 error code indicates a defective control board, inverter or line voltage too high. f the microwave runs for about 7 seconds with a ticking sound..then stops and shows "F-9", it is the magnetron that has failed. The fact that the unit starts and runs with the TICKING SOUND means the control board is sending signal to inverter board and the inverter board is sending signal to magnetron. Magnetron is covered by full 5 year warranty, inverter board is only 3 years.
Posted on Sep 01, 2008
I have a whirlpool microwave oven over the range. Model GH 5184xps-4 when I press start, it comes on for one second then it shows a code -F7- and stops
TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
The microwave oven may be provided with a self diagnostic routine that can be operated
through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "O" (square) is displayed...
POWER FAILURE & FAILURE CODES
Power Failure: After a power failure, the WELCOME screen will be displayed.
F2 Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3 Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 Microwave Relay Failure: Check the microwave relay.
F7 Microcomputer Board Failure: Change the microcomputer board.
Hope helps.
Apr 12, 2011 | Whirlpool Microwave Ovens
Model 72180883400 Microwave Oven F-9 Failure Code
If the unit is less then 5 years old i believe it is still covered it may be the inverter board or a grounded Magnetron tube. If you need any further assistance let me know. I would contact kenmore directly.
Thanks,
Lee
Sep 01, 2008 | Kenmore 62702 Microwave Oven
My Kenmore Elite over the range microwave model 85293 will only run for a few seconds and then it atuomatically stops and says F-9 on the display pad. It does not heat anything. What does F-9 mean?
Just had this happen - the repair guy says it is the inverter. And they have stopped making the part so it cannot be fixed!!! When did you buy your unit?
Jul 03, 2010 | Microwave Ovens
Power to microwave but does not cook food
You didn't mention your brand or model number, but I'll assume it's a Panasonic since you posted this under a Panasonic category.
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
May 26, 2010 | Panasonic NN-H264 Microwave Oven
Microwave stopped heating, evenything else works
Jan 03, 2009 | KitchenAid KCMS1555RSS Stainless Steel...
Unit makes a loud buzzing sound whenever the unit has power.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 23, 2008 | GE JVM1860 Microwave Oven
Microwave stops after about 2 seconds, also have to reset the clock each time
Sadly, we hear of this over and over.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit. The parts kit is similar to this one.
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
They may even send you a replacement magnetron. GE Customer Service is here.
Good luck.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 21, 2008 | Microwave Ovens
Controls go haywire
Sadly, we hear of this over and over. This is usually due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying for the repairs.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown here: http://207.234.249.73/mwd/wb27x10489_ge_mag_stir_kit.jpg
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 09, 2008 | GE JVM1660 Microwave Oven
Keypad on microwave wont work
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "—" is displayed...
POWER FAILURE &FAILURE CODES
F2 —Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3H —Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 —Microwave Relay Failure: Check the microwave relay.
F7 —Microcomputer Board Failure: Change the microcomputer board.
Oct 18, 2007 | Microwave Ovens
Shuts down after running about 8-9 seconds.
We'd need the full model number to be sure, but it sounds like an inverter failure. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. I would call Sears for service. See http://www.sears.com
Sep 15, 2007 | Kenmore 80883 Microwave Oven
Kenmore 62702 Microwave Oven Logo
207 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
