Question about HP Jornada 567
Memory If I have a Jornada with a compactflash wireless LAN card in it, is there ANY way to have more than 64Mb in it, or is the CF slot the ONLY way to upgrade the memory?
    Master:
  • 450 Answers
There is the extended battery pack adds an MMC slot and leaves the CF slot open... So you could use the CF for the Wireless LAN and the MMC for extra memory...
Posted on Sep 12, 2005
Is thare a sim slot in dell axim 51v
Musaji Ahmed Hariff,
Your device has two slots located on the top of the unit. The larger slot supports CompactFlash Type II cards. The smaller slot supports Secure Digital (SD) memory cards, Secure Digital I/O (SDIO) cards, and the MultiMediaCard (MMC). All three memory card types are available in sizes from 64 MB to 1 GB or 2 GB. CompactFlash Cards Your device supports CompactFlash Type II cards. Some common types of cards include: • Modem - Connect a telephone line for modem data communication. • Wireless communication - Data communication without the use of cable connections. You can use cards, such as internal cards with Bluetooth wireless technology and 802.11b wireless LAN. • Storage - Save data or install programs on a storage card
You can click the link below to download the online manual for the Axim51v
http://dell.to/1WKDE1W
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Oct 05, 2015 | Dell Axim X51v Pocket PC
It wont read the cards
A: Make sure you're using a supported memory card. See the table below for specifications:
Memory Card Type Maximum Capacity CompactFlash Card
(Type I and Type II--3.3V only) 8GB Microdrive (3.3V only) 4GB SD (Secure Digital) 2GB MultiMediaCard 1GB
If you connect a compatible CompactFlash (CF) adapter that can read 8GB memory cards, you can also use the memory cards listed below (with a capacity up to 8GB):
  • Memory Stick
  • Memory Stick Duo
  • Memory Stick PRO
  • Memory Stick PRO Duo
  • xD-Picture Card
  • SmartMedia Card (3.3V only)
Mar 26, 2014 | Epson PictureMate Photo Printer
Message "card slot not initialized
The HP Color LaserJet 4650 printer also has three flash memory card slots for printer firmware, fonts, and other solutions. The HP Color LaserJet 4610n does not include any available flash memory card slots.
■ The first CompactFlash slot is reserved for printer firmware.
NOTE Use the first flash memory card slot for firmware only. The slot is marked “Firmware Slot.”
■ The two additional CompactFlash memory slots in the HP Color LaserJet 4650 printer enable the user to add fonts and third-party solutions, such as signatures and personalities. The slots are marked "Slot 2" and "Slot 3."
--- These card slots are located inside the Formater unit. Most likely you either are missing the firmware card or it's defective.
Hope this helps!
good luck!
Aug 31, 2009 | HP LaserJet 4650 Color Printer
Sdio Wireless Lan Card Wlan 802.11b
The blank plastic is NOT to be used while other cards. I am assuming you are talking about the SD card slot on the side (black plastic filler) There should be no movement of the SD card when in place.
If you are talking about the CF card slot on the top of the Axim, again the blank plastic is a dust cover when no card is in place and is not used with cards inserted. There is a bit of open area on one side of the card. Carefull with the pins at the bottom and be sure to insert correctly. Again there should be no movement of the card once inserted fully.
Don't know what you are quoting from the manual. I still have mine and the only thing I see similar to your quote is to "align the tab on the back of the CF card with the notch in the CF slot.." This is to make sure you have the front and back correct and for removal of the card (by grasping the ridge/tab)
Jul 29, 2008 | Dell Axim X5 Pocket PC
I recently purchased 2nd hand a HP ipaq hx2000 pocket PC. It all appears to function ok apart from it will not recognise any compact flash card when I insert it into the slot. I have tried several CF...
Have you tried using an SD card? The hx2000 is supposed to support SD cards and CompactFlash Type II memory cards. If it doesn't respond, it's possible that your second-hand device simply has a faulty card slot.
May 10, 2008 | Computers & Internet
SD wifi
I would rather go for CF wifi card, because Panasonic doesn't states that this one has SDIO type slot. If you use CF slot you will have to find WIFI card cover - it's different one - it will allow to close top cover with the card inside.
There was also two models:
  • CF-P1P1CDZ6J - Bluetooth / wireless LAN built-in
  • CF-P1P1CZZ6J - Built-in wireless LAN-model
Apr 28, 2008 | Panasonic Toughbook CF-P1
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
What else can I do with CompactFlash
You can copy images to a CompactFlash card from the camera's internal memory or copy images from the CompactFlash card to the camera's memory. Also, if you have a PCMCIA adapter and a computer with a Type II PCMCIA slot, you can access images stored on a CompactFlash card directly from your computer.
Sep 13, 2005 | Epson PhotoPC 600 Digital Camera
Compact Flash 802.11b card?
just a guse but the batery looks to have enouth mA to run a CF 802.11b card and an sd blue touth card i think if you will be connected to a network or a wifi connection i would invest the money in the 3400MAH insted of the 1440MAH.
Sep 13, 2005 | Dell Axim X5 Pocket PC
CF for Jornada 525
The only advice that I could offer is to try those 2 Compact Flash cards on someone elses PocketPC. If they don't work then there must be something wrong with the cards. However, if they both work then there must be a problem with the CF slot on your Jornada. Try to test out some CF cards from an electronic store if they will let you. Yes, you do not need drivers for CF cards. A preferred CF list? Whomever told you this is blowing you off. People use all brands of CF cards from Viking, Scandisk, Lexar, Mr. Flash, etc. Sometimes there is a bad card and other times the CF slot is bad so check both of those out...
Sep 12, 2005 | HP Jornada 525 Pocket PC
HP Jornada 567 Logo
67 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
