Question about Brother XL-6562 Mechanical Sewing Machine
Top thread wont pick up bottom thread
I have a xl 6562 brother sewing maching and after a needle broke it now will not pick up the bottom thread. Also where can i get a manual sent to me?
I'm having a problem threading my brother sewing machine model XL 3010
1. Clean up any loose thread in the bobbin area.
2. Pull on the bobbin thread while it is out. It should give a tension that is equal to the top tension of three. You'll have to approximate. Adjust the screw tension on the bobbin. It is the screw nearest to the thread exit hole on the side.
3. Put it back in.
4. Now, the top tension should be at about three. If it still allows a little wad on the bottom of the fabric you can adjust the top tension by tightening a small amount and monitor each time you adjust. The wad should go away.
Oct 05, 2016 | Brother Sewing Machines
The thread guide by the needle has come off and the whole piece holding the needle won't stay on
go to brothers website and look for your sewing machine
see if atolls you if that part is replaceable
Mar 28, 2015 | Brother XL-6562 Mechanical Sewing Machine
The top and bottom threads won't connect, to make a stitch.
Replace the needle with a brand new "Schmetz" needle..
If it still won't pick up the bottom thread, take it in for service.
May 13, 2014 | Brother XL-2610
Brother xl-6562
Check the clamp for a crack it sounds like it may have been broken. Good luck
Jul 21, 2012 | Brother XL-6562 Mechanical Sewing Machine
I have an xl2230.today the needle broke so i replaced with new one,and now the machine wont sew properly,its banging sometimes when it sews and the thread keeps breaking at the needle end and the fabr
try another needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or threads
if none of these things help then I suggest the machine get's serviced just
incase the timing is messed up
May 31, 2012 | Brother XL-2230 Mechanical Sewing Machine
My top thread isn't picking up the bottom thread, and my needle is inserted right and not bent, i dont know what else it could be?
if you are sure needle is right then the timing could be off, sequence between needle going down and hook rotating around tocatch the needle thread. usually a tech repair.
Oct 13, 2011 | Brother XL-5500 Mechanical Sewing Machine
My needle holder will not hold the needle in tightly what could be causing this problem?
The threads of the screw that holds the needle clamp could be stripped or worn.
The needle clamp can be replaced. You can get this from a sewing machine dealer who does the repairs or, order from the Internet.
Stretching a piece of Teflon tape (a plumbing product and not expensive) around the threads of the screw can provide a short-term fix.
May 02, 2010 | Brother XL-6562 Mechanical Sewing Machine
Sewing machine tension?
Hi! This might be a tension issue, but it also could be caused by the needle. For stretchy fabric you need to use a stretch needle or at the least, a ballpoint needle. (see my tip about which needle to use).
Let me know if this solves the problem, ok?
Happy Sewing!
Robbie
Mar 03, 2010 | Brother XL-6562 Mechanical Sewing Machine
Lower thread problem
are you still looking for an answer? if so I can help but I don't want to type all day if you already fixed it.
Sep 14, 2008 | Brother XL-6562 Mechanical Sewing Machine
Brother XL-6562 Mechanical Sewing Machine Logo
286 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
