Question about Soyo SY-5SSM Motherboard
Audio problem Whenever I plug in my NC100 Network Everywhere v2.1 network card into any pci slot my audio crackles whenever a wav file is played including window2000's bootup theme song (that's how I know the problem is there initially before any drivers are loaded for the card). I unplugged all peripherals except the hard drive and the problem is definitely caused by the card only. I remove the card and the audio is fine. Other than that everything works fine. I can connect to the internet with the card. CD audio has no problems coming from the drive using an analog audio cable plugged directly into the on board sound card. When I checked the resources used by all the devices it looks like many devices are sharing IRQ 11 including the network card and the on board audio.
  • Ed Isak Sep 02, 2008
    It's a soyo 5ssm with on board video and sound card
  • 535 Answers
Can u give me the model no of *********** bord
Posted on Sep 01, 2008
Why hp laptop speakers crackle?
goto your control panel and click on the speaker icon and see if its all set right.
May 26, 2014 | HP Pavilion 11t-n000 x360 - ENERGY STAR...
Need Driver For NC100 ethernet card for WINDOWS ME
Please go to this site and download the following driver. Hope this helps.
May 22, 2011 | Linksys Network Everywhere NC100 Network...
Hi, My Saffire LE is making a crackling sound. I have check this on both the monitoring channel and the second out put on my HS80's and also on the headphones out put on my AGK's, the crackle is...
Power sound amplifier output transistor push n pulls are dead and the q point is off the scale.
Either it is a modular amp or discreet top hat xistors
Aug 23, 2010 | Focusrite Saffire LE FireWire Audio...
Hello! I am loooking for a network card to a 9 year old Compac 8455EA, The prblem is that I bought a network card without looking how it is done in this computer. It is an integrated card containing...
Not sure what you are looking for. You can get a simple network card
BELKIN F5D5000 10/ 100Mbps PCI Desktop Network Card 1 x RJ45 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16833314101&cm_re=network_card-_-33-314-101-_-Product
From what I can tell, your computer uses PCI slots so .... you want to make sure you get a PCI network card and that it comes with drivers for your operating system.
Mar 12, 2010 | Computers & Internet
I have an old emachine it has a regular phone connection and i want to update it to ethernet connection can you help me?
This is a PCI Network Card. It plugs into a PCI expansion slot on your computer. You will need to install the drivers for this network card to work properly.
How to install a network card Some newer computers come with network interfaces built in - your machine carefully for a socket that looks like a large telephone socket with a network_symbol.jpg next to it. These are sometimes hidden behind a flap or on the corner of your laptop next to the modem socket.
If you haven't got a network interface already on your machine you will have to install a network interface card. These are available to buy from the IT Service Desk.
  • USB Adaptors simply plug into a USB port.
  • PCMCIA Cards for laptops slot in a free PCMCIA slot on the side of your machine.
  • PCI Cards are a bit more fiddly and require you to open up your machine.
  • We advise that you use a USB adaptor for ease of installation
Instructions on how to fit a PCI network interface card.
  1. Shut down Windows and then turn the computer off and unplug it. Never work in your computer's insides with the power on or the power cord plugged in!
  2. Remove the cover from your computer. There are normally a number of screws on the outside of the case to remove. Put the screws someplace where they won't wander off.
  3. Find an unused expansion slot inside the computer. The expansion slots are lined up in a neat row near the back of the computer. All new computers have at least three or four slots known as PCI slots.
  4. Many older computers also have several slots known as ISA slots. You can distinguish ISA slots from PCI slots by noting the size of the slots. PCI slots are smaller than ISA slots, so you can't accidentally insert a PCI card in an ISA slot or vice versa. Figure 2 shows the different types of slots. PCI slots are white, ISA slots are black
  5. When you find the right type of slot that doesn't have a card in it, remove the metal backplate from the back of the computer's chassis. A small retaining screw holds the backplate in place. Remove the screw, pull the backplate out, keep it in a safe place in case you ever want to remove the network card.
  6. Insert the network card into the slot. Line up the connectors on the bottom of the card with the connectors in the expansion slot, and then press the card straight down. Sometimes you have to press uncomfortably hard to get the card to slide into the slot.
  7. Ignored the little cable that came with the card, you can chuck this in the bin. It is a Wake-On-LAN connector and isn't required for your card to work.
  8. Secure the network card with the screw that you removed in Step 4.
  9. Put the computer's case back together. Watch out for the loose cables inside the computer; you don't want to pinch them with the case as you slide it back on. Secure the case with the screws that you removed in Step 2.
  10. Turn the computer back on.
Please give a 4 star rating. we do this for free, the only reward we get is your approval.
Dec 04, 2009 | E-Machines etower 566i PC Desktop
Trying to install a logitech rj45 network adapter (ethernet card). I have xp. BUT (a) the computer does not list it under network adapters (i already have one which i think is integrated on the motherboard...
Dear sir,
Welcome to once again Fixya support
According your problem it seems to be your try to install faulty Network card. So better is check with new good card.another possibility is some time pci slots fail to recognise a hardware, so try it with another pci slots of mother board.According to you onboard network card is dead, means motherboard fails to work when connect to a network,after successfull installation of network card also the possibility of motheboard not allow you to work with new network card ,same situation may arise,i am also managed same problems in several customer place while working as an computer hardware engineer.So try with new network card it may solve your problem
good luck
Jul 23, 2009 | Computers & Internet
My network adapter " broadcom 802.11n newtwork adapter" is experiencing driver or hardware related issues
I think it needs dusting. do the following:
1.Open your computers cabinet and plug out the LAN card from the PCI slot.
2 Clean the PCI slot and LAN with brush
3. Insert it again in some other PCI slot if your motherboard have .
4. Install the drivers after the windows found the hardware.
Hope it work.
Jul 14, 2009 | HP Broadcom 5751 (DZ556A) Network Adapter
Audio Problem on Soyo mother board
remove & reinstall driver of your sound
Sep 03, 2008 | Soyo SY-5SSM Motherboard
Soyo SY-5SSM Motherboard Logo
83 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
