True vector continually has problems and has to shut down
    Scholar:
  • 133 Answers
True Vector is a component of Zone Alarm.
I reccomend in this case to update to the most absolute version of ZoneAlarm to avoid any problems.
Recently there have been a flurry of problems caused by Windows Updates release which may have the potential to break the program or make it close to inoperable.
Posted on Sep 01, 2008
2006 vector get flashing oil light twice then shuts down
Maybe its trying to tell you something. Low oil or no oil flow, try replacing level sensor.
Feb 15, 2016 | Yamaha 2006 RS Vector GT
I keep getting the message The data file 'personal folders' was not closed properly when I open Outlook, how can I prevent this from happening?
The underlying reason why Outlook displays this "data file" check is very simple. There is a single flag in the header of the data file that is a Boolean value (True or False). While you use Outlook the value of this flag is constantly changing as the data file is updated. When the update begins the value is changed to False and then when the update completes the value is changed back to True (implying the update is finished and successful).
So, the key to the problem is the shut down process because once the Outlook.exe process is exited this flag value cannot be changed. If the Outlook.exe process was terminated prematurely or a 3rd party add-in did not properly set the flag value to True then the flag value can be left at False. If you start Outlook with a data file where the value of the flag is False you are guaranteed to see the "data file" check. If the value of the flag is True then you will not see the "data file" check.
Right now, there are a few known common causes for this issue:
- Shutting down Windows before the Outlook.exe process has exited
- 3rd party add-ins improperly "closing" the data file
- Outlook crashing
- Non-Outlook process accessing the data file
http://support.microsoft.com/kb/954642/en-us
http://support.microsoft.com/kb/948733/en-us
Regarding the post advised by Rod, I would like to explain more detailed:
When you shut down Outlook, the Outlook window goes away, but the Outlook.exe process can continue to run for some time. That's why you can see Outlook.exe sitting in Task Manager for a few minutes after closing the Outlook window. If you shut down Windows while the Outlook.exe process is still running Windows will not wait for the Outlook.exe process to exit. So, you increase the likelihood of encountering the "data file check" issue the next time you start Outlook (because the Outlook.exe process was not able to "close" your data file(s) completely before Windows was shut down).
On the other hand, if you leave Outlook running when you shut down Windows the Outlook.exe process will continue to run and exit on its own. When Windows is shut down, it sends messages to all visible window frames telling them to quit, and will wait for those programs to quit before shutting down. Not until all processes with open windows have exited will Windows finally shut down. This is somewhat counter-intuitive to most people as traditional training has always advised manually closing applications before shutting down Windows.
Mar 10, 2011 | Microsoft Computers & Internet
I have a Vector HID Spotlight Power on Board SLH100P and I'm trying to recharge it. When you plug in the charger the led lights flash and click really fast. What could be the problem? Thanks for your...
The battery needs replaced. In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. Or, you can order a replacement battery from: www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Aug 04, 2010 | Vector 1 Million Rechargeable Spotlight
When I switch the power on the inverter, it squeals briefly and then shuts down.
Two possible problems; input voltage too low, or the output load too high. If input remains at 12v or higher and it shuts off with no load, then the inverter is bad.
Mar 19, 2010 | Vector 750-watt Power Inverter Power...
I'm trying to reset the altimeter and sea pressure but the watch. I've followed the instructions but the watch more often that not reverts back to default settings or does not respond to the calibrations...
http://www.suunto.com/en/Products/Outdoor_Sports_Instruments/Suunto-Vector/Suunto-Vector-black/#Manuals
If you continue to have problems with your watch, and the instructions in the user manual don't resolve your problem, you may have to return the watch to Suunto.
Your watch must be registered with them, you'll need the serial number of the watch, which is located on the back case. You'll have to get an RMA from Suunto in order to send it back to them.
Here's their warranty info: http://www.suunto.com/en-us/Support/Warranty-information/
Oct 11, 2009 | Suunto Vector Wristwatch
Running Windows XP Home, SP2, Thunderbird and the latest Firefox. Am getting the occasional error for True Vector Service when online and the application shuts down. I note that this is part of ZoneAlarm...
You can clear the registery files associated with this ZoneAlarm but if you do so you may happen to loos eyour internet connectivity altogether. My thought is that ZA is not at all harmfull so you try to install it again and you may evade this error. Sometimes it may slow down your computer but it can be recoverd by restarting the application. Rate me if it is helpful!!
Aug 19, 2009 | Zone Labs ZoneAlarm Pro 5 (1313618SF)
Internet Explorer wont connect to the internet
Try putting in https://www.microsoft.com
Or www.filehippo.com where you can download a copy of the latest IE to re-install it is case you have a corupted file in the old installation
Finally were you using Zone Labs as a Firewall if so then you may still have their True Vector Monitor running in the background , you need to go into "Search" put in True Vector and delete any files it finds with that name)
Ps
You really wasted your money on Norton , it slows the machine down big style and is a pain
NOD32 Anti Virus is a much better product and a combination of a router with its built in Firewall and the standard Windows Firewall give you as much protection
Jun 17, 2009 | Acer Aspire 5100 Notebook
Error messages on Vista Home Premium
uninstall the old Zone Alarm and install the latest version.
Mar 18, 2009 | HP Pavilion dv2000t Notebook
What is the effect of increasing the angel between two vectors to be added on magnitude of their resultant?
Resultant of addition of two vectors A and B is calculated as the square root of (square of A + square of B + 2AB cosx) where x is the angle between the two vectors.
If the angle between the vectors increases, we need to keep in mind the behaviour of cos for different values of x. The resultant be maximum for x=0 and continue to decrease till x=180 but will again increase to a max value for x=360; the same as for x=0.
Feb 03, 2009 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
