Question about Troy Bilt 5.5hp Self Propelled Mower
The bag from my lawn mower keeps coming off. How do I prevent this?
Every-time that I mow for like 10 to 20seconds, the bag of my lawn mower unhooks off my lawn mower. If anyone has a solution please help me 'cause that is sooooooooo annoying!!!!
You can call the company for help, or even make sure that the screws that are attached to the strap that goes around the bag are really tight.
But THE best solution there is duct tape! It works on everything!!
just roll it until it is secure, it may look poor or whatever, but it should keep it secure for ages!
Posted on Sep 01, 2008
Mower starts but if it stops then it will not start for the rest of the day????
Mowing the lawn is a necessary chore throughout the growing season. It prevents your landscape from looking unkempt and keeps your home looking nice and neat. How well your lawnmower works can make a huge difference in how you perceive this task. If the mower runs well and does what it is supposed to, then the job might not seem too onerous, but if your mower stops every time it gets hot, then it can turn a job that should only take a little while into an all-day affair. There are a few reasons why your lawnmower might stall after warming up
Jul 29, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Tip
Preventing lawn mower rust
To prevent rust, make sure you get wet grass off of the lawn mower every time you mow. Once every 3 uses, apply a light oil with a rag on every metal surface that comes in contact with moisture. If your paint chips, paint over the spot immediately to prevent corrosion.
Moisture is the biggest enemy for outdoor equipment. Lawn mowers can last decades if you protect and prevent.
on Sep 10, 2015 | Garden
Toro 20022 grass buildup
at tractor supply has a paint called slip
May 25, 2012 | Toro Power Lawn Mower
Bits of burnt stuff coming out of lawn mower
that was burnt carbon coming out and you did overwork that lawn mower not dangerouse but keep mowing long grass you will end up buy anew one soon
Dec 04, 2011 | Briggs & Stratton Briggs Stratton...
Why do grass get stuck in lawnmower than it starts to turn off
This can be happening from a couple of reasons, first if your grass is too damp this will happen with almost any mower, wait till the lawn dries out before cutting, you may be cutting the lawn when it is too high, try cutting it twice a week maybe this will help, you may try to raise the cut setting eliminating the amount of grass clippings that you have accumulated, if you are mulching or using the bag be sure the chute is clear, and lastly be sure you are running at a higher speed to push through the terrain.
Happy Mowing!!
Jul 14, 2010 | Mtd 22" Yard Machine Push Mower
To mulch my grass clippings, do I have to use the side discharge or can I simply remove the bag and insert the rear plug?
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Jun 10, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
22" Rear Bag Rear Propelled High Wheel Lawn Mower (): I can't find the manual -- how do I start the mowe...
Fully depress primer bulb only 3 times, then pull starter cord. Ensure air filter is clean and gas is fresh before attempting to start.
May 16, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Toro lawn mower choking on mulched clippings multiple times
there is a product called mowease that you apply to the blade and mowing decked after a good cleaning. it helps keep the grass from adhereing to the deck
May 13, 2010 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Riding lawn mow
give as the model so we can help.
Apr 15, 2008 | Black & Decker 19" Electric Lawnhog...
Troy Bilt 5.5hp Self Propelled Mower Logo
243 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
