Question about Dishwashers
My dishwasher has stopped filling with water. I have checked the inlet lead is not blocked. Can you help?
SOURCE: IE error message
Hi, had the same problem on a LG LD 12aw5. (No water entering). Check the inlet solonoid. There should be 220V over the solonoid. I replaced the solonoid, at first, just to have the same problem. The problem was a bit more serious, the Triac driving the solonoid burnt out, and the solder on the mainboard keeping the transformer were shot to. I replaced the Triac, soldered the Transformer - and wolla - working. If water enters - but you sill get the IE error it could be the float(checks the water level). This device tells the machine when there is enough water. If this is stuck, the machine will think no water is entering. conrad_dot_dewet@gmail.com - replace "_dot_" with "." to email me.
Posted on May 06, 2007
jsrock516
  • 5911 Answers
SOURCE: noisy kitchenaid dishwasher during filling
Fill valve replacement should be fairly simple. Most dishwashers are constructed in a similar manner, so although these steps are generic, it should lead you in the right direction: 1. Remove the lower kick panel right below the dishwasher door. The fill valve should be located in the front of the dishwasher on the left hand side. 2. Turn off the water supply line. 3. Turn off the circuit breaker to the dishwasher or unplug the unit as necessary to secure power. 4. Carefully remove the two wire connectors going to the fill valve solenoid. These wires are delicate, so be careful with them. 5. Leave the fill valve attached to the mounting plate in order to loosen the supply line. Once you have the supply line loosened you can remove the valve from the mounting plate by removing either one or two screws. 6. With the supply line disconnected, wires removed and the valve removed from the mounting plate, you can now remove the secondary water line that goes into the wash tub. It is usually behind the valve and easier to access if you can pull the valve out far enough the reach it. 7. Make sure you put teflon on all your threads BEFORE you re-install. 8. Installation is in the reverse of what I just explained to you. You should not have to remove the dishwasher from under the counter, but you can if it makes access easier. It's that easy. Just make sure you check your water lines for leaks BEFORE re-installing the kick plate. And, make sure you reconnect the wires properly. Good luck. I hope this helps you.
Posted on Jul 10, 2007
  • 16 Answers
SOURCE: Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
Posted on Feb 10, 2008
SOURCE: Bosch SHU 4000 series dishwasher; Water keeps on filling
Follow-up: I was able to fix the problem on Bosch model # SHU 4002UC. Purchased water inlet valve (part number 425458) from Sears Parts Center. I required the Sears unit number from the original invoice as Sears computer system apparently cannot identify the Bosch model number. The valve is as described by meyerjr above; however it is located at the bottom front of the machine so could be replaced (not so easily) without removing the machine. Cost of part was $30.50 Cdn including tax.
lwou
Posted on Apr 20, 2009
marka19
  • 1430 Answers
SOURCE: dishwasher will not fill, water supply checked OK,
Check the float switch. Sometimes you can jiggle it around to get it working. Also check the leads going to the water inlet to see if you have power unit must be started to check this. If you have power to the valve it has failed if not check that float switch for continuity. One of the leads from the water inlet goes to the float switch.
Posted on Mar 03, 2010
I have smeg built in dishwasher. Acts like running cycle but i don't think it's getting enough water. the soap tables are not dissoved. before if opened door during cycle lots of water but now none
Check water inlet filter, check for blockage at the stop valve .
The rubber washer does come loose and blocks/limits the flow into the dishwasher. The fill cycle is on a timer and any restrictions in the water connection will under-fill the unit.
Hope this helps?
Jun 24, 2017 | Smeg Dishwashers
GE dishwasher model gdf570ssf0ss will not fill.
Check to make sure there isn't something holding the flood switch up. It is a hat shaped tube in the bottom of the dishwasher that can be blocked up by soap an kept in the upright position. If it moves freely check to make sure your water valve has stopped working or has a block screen.
Dec 08, 2016 | GE Dishwashers
The dishwasher starts and then fills up with water and then starts coming out the front door. I then have to move to the end of the programme to drain the water
There is a water level sensor which usually consists of a tube leading to a diaphragm sensor. Either this tube is blocked or the sensor has failed.
Another possibility is that the solenoid water inlet valve has failed open, but that is rarer as they usually fail closed.
May 19, 2015 | Dishwashers
What does F6 mean?
The dishwasher can't take on water. Check that the water inlet is properly connected, the stop tap valve is open and that water supply is otherwise available to the dishwasher. Also check for kinks or blockages on the water hose.
F6. means "Water valve (WV1) is switched on but flow meter (FM) senses no impulses" (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
Jul 25, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
Letter F appears on screen, and dishwasher does not start. Sounds like pump runs for a bit then stops. Door is closed. What is wrong?.
Hi
Error code F indicates that dishwasher control has detected a fault with dishwasher filling. This is due to faulty water inlet valve. Please check for clogged water inlet valve. Water inlet valve part#35
You can buy it from this link---
Bosch SHU531 water inlet valve
Hope this helps... Please post back if you need more information
Daniel
Nov 10, 2010 | Bosch SHU5315UC Dishwasher
On whirlpool dishwasher on litle screen we get notification "F6", what should we do, what does it mean?
This is what it means:
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
The above info is pretty self explanatory but the bottom line is the dishwasher either is not filling fast enough or... is sensing that it is not filling fast enough. Check your inlet water line for flow by first turning off the power and water supply line then remove the line .... open the wall connection valve and check the flow. Also take a flashlight and small mirror if need be to check the hole of the inler to the water valve.
Thanks for choosing FixYa.
Kelly
Sep 02, 2010 | Microwave Ovens
Dishwasher not getting enough water in either drawer, although top drawer gets more. Dishwasher keeps beeping during cycle and reads not enough water and then stops running until you press the start...
This sounds like a hard water deposit problem.
Check your water inlet valve for a screen and see if its clogged. Also it may just be a water valve/solenoid problem. As in, it's too crusted up to float up and down.
Some models have a water fill timer, while others use a water fill/pressure switch. This may also bear inspection.
The beep you hear during your cycle is indicating that your water level is too low to cover the heating element, which can cause cracking and lead to a short.
Mar 07, 2010 | Fisher and Paykel DD605FD Stainless Steel...
Dishwasher will not fill, water supply checked OK, inlet filter checked OK
Mar 03, 2010 | Bosch 24 in. SGS43C12 Classixx...
My dishwasher will drain but will not fill up with water ?
Hello there
Specific symptoms include: Little or no water enters the tub . To find the cause, first check to be sure the water is ON.
always “zero” the ohmmeter before making any continuity checks on dishwasher components. . When making continuity checks with the volt/ohmmeter, always turn the electricity OFF at the circuit breaker panel. Live voltage checks will damage the meter movement.With the water ON, remove the lower panel. Place a towel or shallow container on floor to absorb water. Loosen the nut that secures the dishwasher water tubing to the inlet port of the water inlet valve. If water collects immediately in the towel or container, it can safely be assumed that the water pressure is adequate and the plumbing system is not clogged . If little or no water collects in the container, the water line gate valve could be defective or there is a problem in the plumbing system.
Turn the water OFF. Remove the lower panel. Loosen and remove nut that attaches water tubing to water inlet valve inlet port. With tubing removed, check for corrosion and debris that has accumulated inside the tubing and inlet valve inlet port. . Turn the water supply ON. Select a cycle on the timer dial where the dishwasher starts to fill with water. If it starts to fill with water — you fixed it. The problem was corrosion inside the water tubing or inlet valve water inlet port. If the dishwasher still does not fill with water, an additional electrical check will have to be made.Next, test for electrical power to the water inlet valve from the dishwasher timer assembly. Using the volt/ohmmeter, set the meter on the 150-volt scale and attach the two test leads of the volt/ohmmeter to the two terminals of the water inlet valve solenoid coil to be checked. Turn the water ON. With the test leads attached to the solenoid terminals, select a cycle on the dishwasher timer dial where the dishwasher starts to fill with water. Push in or pull out the timer dial. You should get a voltage reading of 110-125 volts A/C on the volt/ohmmeter scale. If you get a reading, this would indicate that electricity is available from the dishwasher timer assembly to the water inlet valve.However, the absence of water flow means the water inlet valve is defective
Dec 31, 2009 | Maytag Dishwashers
Fault 11 - inlet or outlet blockage
THIS TYPE OF M/C PERMIT WATER TO FILL IN LONG TIME IF THE PRESSUR IS LOW
I THINK AFTER ABOUT 3 MINUIT YOU CAN OPEN THE DOOR AND CHECK OF LEVEL OF WATER TO ASSURE IS LEVEL OF WATER IS SUFFISUNT OR NOT
Jun 14, 2009 | Miele Incognito G658 SCVi Built-in...
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
