Question about DeLonghi Pinguino PAC-GSRU Air Conditioner
Delonghi FX400eco error code
I Have the above air con unit 18 months old the cooling fan appears to be off all the time and an error code "LT" appears on the display after a few mins. I would like to know what the error code is before I continue to check the functionality of the fan any thoughts? thought it might be Low Temp
    Scholar:
  • 61 Answers
I was trying to identify a error code, I found a manual online after a while
Posted on Sep 02, 2008
Error code e6 what does that mean air conditioner will not start
DeLonghi CF210 Portable Air Conditioner Error code e6 ...
www.fixya.com > ... > DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner, error code e6 related issues. Get free help, solutions & advice from top DeLonghi experts.
Error e6 displaying on single split model one - Fixya
www.fixya.com/.../t4492271-error_e6_displaying_single_split_model
Apr 5, 2010 - Question about DeLonghi CF210 Portable Air Conditioner ... then the code error display E6 and the error code is Communication malfunction.
DeLonghi fix e6 error Air Conditioners Questions & Answers ...
www.fixya.com > Forum > Tags > fix e6 error > Air Conditioners
DeLonghi air conditioners fix e6 error related questions and answers. ... DelonghiFX400eco error code I Have the above air con unit 18 months old the cooling ...
DeLonghi CF210 Portable Air Conditioner Error code e6 split
Jan 01, 2016 | DeLonghi Heating & Cooling
My air-con is not as cold as before. I tried to lower the temperature, but when i try setting the temperature to 18 degrees, the remote just shows 18 degrees for like 5 seconds before going back to 31...
These is because you have not service your air-con for a long time. The cooling fins are clotted with dirt & dusts accumulated for a long period of time, and the water vapour caught between the cooling fins turn into ice when you set lower the temperture for the air-con. Moreover cool air from the blower/fan cannot pass thru', the cooling fins to regulate the cool air into your room.
You have to get the professionals to do a service on your air-con.
Hope it clarify your predicaments.
Jun 15, 2011 | Sanyo Heating & Cooling
Hi On our portable DeLonghi air con, we have
Temp setting is very low. Raise it. And also service your unit frequently.
Dec 24, 2010 | DeLonghi PAC C100 Air Conditioner
Hi there i have a delonghi one split system air con. unit cools good for a minute or so then starts to struggle blowing warmer air. i have noticed the condensor fan on the unit out side does not turn on....
Either the fan motor outside is bad or the run capacitor for it is bad. One quick way to tell, you just have to be really careful, when the compressor turns on get a long screwdriver and spin start the fan. If it starts turning then simply replace the start capacitor, which more than likely will look bloated. If it doesn't start then you need to replace the motor.
Oct 06, 2010 | DeLonghi Heating & Cooling
Not Cool
Measure room and calculate btu's
Formula Length times Width times Height Times Eighteen divde by Five.
Example: 12 x 15 x 9 x 18 / 5 = 5832 BTU's
Jun 03, 2010 | Panasonic CS-A12C Air Conditioner
DE500P Dehumidifier: Does not dehumidify even though set to dehumidify. Fan will turn on when RH above setting, and stay on, since humidity doesn't drop. Filter is clean & pail empty.
Locate and touch the cooils located, usually, above the condensate collection pan, ("pail empty"). If the coils are not cold, or cool to the touch, the unit has lost its charge of refrigerant. This would explain why the unit fan is working, but there is no condensate, as there is no coolant (charge) to cool the coils and "pull" the hunidityout of the air.
Jul 07, 2008 | DeLonghi Heating & Cooling
RADEL CR 208 PORTABLE AIR CON UNIT
DOES ANYONE ACTUALLY ANSWER ANY PROBLEMS ON THIS FORUM?????????????????
Jun 24, 2008 | Heating & Cooling
FX-160 not working
Check your voltage in your area or check your outlet it may be loose. If your outlet is loose try using another outlet to test the unit.
May be the unit is tripping due to abnormal voltage or loose outlet.
Dec 29, 2007 | DeLonghi Pinguino PAC-02 Air Conditioner
DeLonghi Pinguino PAC-GSRU Air Conditioner Logo
467 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
