Go by the auto parts store, buy fuel line disconnect tools.you take the fuel line disconnect tool, place it on fuel line push tool in the fuel line connector to seperate fuel lines.make sure when you get ready reconnect fuel lines back together you should hear fuel line snap back in place.make sure fuel line in place dont come apart. to be on safe side dont crank car first just turn ignition to the on position for few seconds check for fuel leaks.
Loosen the union pipe bolts slowly.
When removing the delivery pipe, take care not to drop it as damage to the injectors may result.
If the injectors don't rotate smoothly, the O-rings are probably not installed correctly or the injectors are not installed evenly. If this is the case, you will have the pull the delivery pipe off the intake manifold and look at the O-rings to make sure that they are installed correctly. Adjust the O-rings and, if damaged, replace them.
