Question about Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum
Clogged vacuum Rather stupidly, my boyfriend 1) were vacuuming without a bag and 2) vacuumed up a big piece of cotton from a sofa cushion. And now it's making a horrible noise and I see it vibrating where the tube connects to the machine. When you look inside there's a white thing sticking out but it looks like it's part of the vacuum. If it's a clog, how do you fix it? I tried unscrewing the tray the bag sits in but it won't budge.
  • 1 more comment
  • minan Sep 02, 2008
    It is model # 35922.
    Hi - the model no. is 116.35922500.
  • minan Sep 03, 2008
    Thanks for your help!
    President:
  • 1,673 Answers
You can start by taking off the bottom plate or top cover, which ever comes off, that is where the inlet starts going in and hopefully the clog is there. Could be in the hose also. But without the complete model number I can't look it up to see a picture of it.
Posted on Sep 01, 2008
  • Lauren Junge
    Lauren Junge Sep 02, 2008
    35922 is not the complete model number. For example:
    116.35922****. It will either be on the back or the bottom of the vacuum.
  • Lauren Junge
    If you pull the hose loose from where it goes in near the noozle, look down that tube, you can maybe see down to the brushroll, if this is where you see that white thing, that maybe the cotton that was sucked up, you wil have to pull it out. From there it would go thru the hose to where it goes into the vacuum.
    If you want to see a pic, go to sears.com, click on the parts link, put in you model number, scroll down and you can view the noozle and dust compartment, and maybe give you an idea as to what to take apart.
    Wish I could help more, but would have to see it to know for sure,
I've replaced the bag, but the machine will not pick up dirt; there is no suction.
Hey, this is Jeremy with Crucial Vacuum,
I am sorry to hear that you are having issues with your Miele Vacuum. There are a few things you can check to restore suction to your vacuum.
1. Your suction setting is too low or the automatic setting is not registering properly.
2. The filters are too clogged. They need to be cleaned or replaced. Without proper air flow, your vacuum will have either decreased or no suction.
3. Vacuum hose is not air tight. If the hose or any other portion of your vacuum is leaking air it will diminish or completely abolish all suction.
4. The roller is clogged. If everything else has failed, flip over your vacuum and check the roller. If it is too clogged with hair and debris your vacuum will not be able to pick anything up. Simply remove the gunk and try starting up your vacuum again.
You can purchase replacement parts for Electrolux direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/miele.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 18, 2015 | Miele S7260 Cat and Dog Upright Vacuum...
The spinning brush underneath the vacuum had stopped turning and so when I inspected it, it was totally clogged up with hairs / pieces of cotton that had wrapped around the spindle. I removed the plate at...
most of the time the motor is what dose the sucking as well as driving the brush i think you should take closer look at the belt it might not be on the spindle correctly or it could be streched
Oct 01, 2011 | Dyson DC33 Bagged Upright Vacuum
My Dyson Animal vacuum smells horribly of dog. It's worse than my dog has ever smelled - even at his worst. How do I take apart the Animal to clean it properly? Can I use a weak water/Chlorox solution...
hi Donna.
Complete removal of pet hair from the home is a quandary many pet owners face. The Dyson Animal series vacuums use centrifugal force to remove animal hair from carpets, floors, curtains and upholstery. The high-powered vacuum is bagless, allowing you to extract pet hair from surfaces without worrying about running out of vacuum bags. As your Dyson Animal vacuum is exposed to pet hair and dander, a smell can develop. Similar to other small appliances, a vacuum needs periodic cleaning to keep it looking and smelling clean. When you use basic cleaning and deodorizing techniques, you can get the smell out of your Dyson Animal vacuum.
Step 1
Remove the bagless receptacle for pet hair according to the directions provided for your Dyson Animal vacuum. Hold the receptacle upside down inside a trash bag and tap the bottom to remove pet hair and dirt.
Step 2
Mix 1/2 tsp. of dishwashing detergent with 1/2 gallon of warm water in a bucket. Dip a clean cloth into the soap solution and wring it out.
Step 3
Wash the inside and outside of the receptacle with the cloth to remove dirt and dander that cause odor. Rinse the receptacle with a cloth dampened with water. Dry it thoroughly with another cloth.
Step 4
Remove the HEPA filter from your Dyson Animal vacuum. Pick visible clumps of pet hair off the filter and discard them. Flush the filter with cool water to wash out dirt and hair. Rinse the filter until the water runs clean. Gently squeeze the filter and allow it to air-dry for up to 12 hours to ensure it dries completely.
Step 5
Moisten a cloth with undiluted vinegar. Wipe off the exterior of the vacuum with the vinegar. Deodorize the receptacle and interior areas, where the bagless receptacle and filter go, by wiping them with the vinegar-moistened cloth. Dry the vacuum with a clean cloth.
Step 6
Place two drops of vanilla extract on a cotton ball. Drop the cotton ball into the receptacle before securing it to the vacuum to prevent odor from building up. Vanilla extract is an effective natural odor absorber.
hope this helps you out.
Nov 28, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
Can I shampoo a couch?
Yes<br /> <h2 class="Heading1a Underline header"><span>Instructions</span></h2> <!-- google_ad_section_start() --> <div class="thingsYouNeed"> <h2 class="Heading5a">Things You'll Need:</h2> <ul> <li> <span>Vacuum and its hose attachments</span> </li> <li> <span>Shampoo specific to the couch's fabric</span> </li> <li> <span>Rug shampooer</span> </li> <li> <span>Steam cleaner, possibly</span> </li> <li> <span>Rag and cotton swabs</span> </li></ul> </div> <ol id="intelliTxt"> <h4 class="Heading4a">Preparing the Sofa</h4> <li id="jsArticleStep1"> Vacuum the sofa, its pillows and its cushions with the hose attachments. Do not forget the arm rests and backing of the couch. This will clean loose dust and dirt.<br /> </li> <li id="jsArticleStep2"> Dust the wood areas with a soft rag and a cotton swab for the area between the material and wood.<br /> </li> <li id="jsArticleStep3"> Find your warranty. If it is still in effect, the warranty may be null and void if you apply any cleaning solutions. Call the company for cleaning instructions.<br /> </li> <li id="jsArticleStep4"> Determine the sofa's fabric. This tag is typically found under the cushion area.<br /> </li> <li id="jsArticleStep5"> Buy shampoo specifically for your sofa's fabric.<br /> </li> <li id="jsArticleStep6"> Rent a rug shampooer.<br /> </li> <h4 class="Heading4a">Cleaning</h4> <li id="jsArticleStep1"> Assemble the shampooer according to its directions.<br /> </li> <li id="jsArticleStep2"> Test a small area of the sofa. The best place may be the back of the couch or under the couch if possible.<br /> </li> <li id="jsArticleStep3"> Clean the entire couch. This will prevent watermarks.<br /> </li> <li id="jsArticleStep4"> Allow it and all its parts to dry before reassembling the cushions and pillows.<br /> </li></ol> <div style="overflow: hidden; color: rgb(0, 0, 0); background-color: transparent; text-align: left; text-decoration: none; border: medium none;"><br /></div><br /> <!-- from fixya rte -->
Jun 12, 2010 | Kirby G6 Bagged Upright Vacuum
Bag is not full but little vacuum at hose end. Why?
You can have one of several problems:
(1) A clogged hose, or
(2) A clogged filter or bag.
If the filter or bag is clogged, it restricts the airflow to the hose end.
Mar 09, 2010 | Vacuums
I took the filter assembly apart, now I can't get it back together. There's a silver medal ring, a big cotton back, an inner plastic seal and an outer plastic seal. Somehow, they all fit back together....
The cotton bag wraps around the hepa filter - the blue plastic part will not be visible once the bag is in place. The silver ring sits inside the cotton bag to hold the sides of the bag against the sides of the vacuum top-half. DON'T pull the plastic inner seal and outer seal apart. They snap together and snap onto the lip of the vacuum top-half. It's a bit of a struggle snapping the seal back onto the lip.
Jan 11, 2010 | Vacuums
Vacuum clogged. Can't figure out from where.
Follow the air path: brush, handle, tube, bag, inlet filter, exhaust filter. Run the vacuum without these , in that order, to identify where the plug is.
Oct 26, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuum just stopped working.
is there a filter in it if so clean the filter.try it without the bag in it.make sure the bag is in correctly.does the bag expand when you turn it on.you might have something caught up in the hose.take the hose off and blow througfh it.if you can't its clogged.also check the inlet where the dirt goes into the bag.the inlet might be clogged.please leave feedback
May 04, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Clogged vacuum - Kenmore 35922 Slate Blue
35922 is not the complete model number, it will be on the back or the bottom of the vacuum. Example: 116.35922****
Sep 02, 2008 | Kenmore 31912 Progressive Direct Drive...
Your instructioons do not say how to get the sweeper to move so that you can sweep under the sofa.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=682948
Generic problem for all Vacuums
Your instructions do not say
Posted by ohmizes on Jun 18, 2008
Your instructions do not say how to get the sweeper to move so that you can sweep under the sofa.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. there are not too many sweeper that actually get under the sofa when most sofas go almost to the floor and some uprights go flat and some sweepers but if the height of the sweeper or vacuum exceed the height of the sofa underneath then either one or the other cannot clean under the sofa if the height exceeds the sofa height limit without leaning your sofa back or lifting it up to clean.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 18, 2008 | Vacuums
Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum Logo
140 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
