Question about Troy Bilt 5.5hp Self Propelled Mower
My lawn mower doesn't start and when it does, smoke comes out of exhaust
After the lawn mower sits a few days in my garage, it doesn't start. I pull the start chain and nothing happens for quite a few tries.
After a while, it will starts up but a lot of smoke come out of the exchaust. Not sure why or what needs to be done to fix this.
Please answer me fast
Please pleasseee
  • bgreen7 Sep 13, 2008
    Recently, while cutting the lawn, I noticed the mower was running very erratically. I stopped to empty the grass catcher and after that the mower would not start again. What gives?
  • melodyusanto May 11, 2009
    i chaned the gas, cleaned the filter, hit the primer button too many times, i suppose, then i saw gas leaking out of the filter .
    the engine still didn't start.
    there was a faint sound but it won't turn over.
I used my mower two weeks ago. Now it won!t start, I check the air filter,change the gas, check the
spark plug and it was soaked with gas. I clean the plug and set the gap and it still won!t start. It
sound like it wants to start but it will not start.
please answer me fast
Thank you very much
Posted on Sep 17, 2008
You may need to change the oil and/or empty the old gas and replace it with new.
This thing happens when you don't take care of your lawn mower for too long.
Posted on Sep 01, 2008
4 Suggested Answers
  • 211 Answers
SOURCE: My lawn mower doesn't start
Hi Every 2 stoke engine needs three things to run:Fuel+oil/air mixture in correct proportions,compression and ignition.Remove the sparkplug and see if the spark appears when the piston in the cilinder is at top death point(almoust),if not check the flyweel key(not to be sheared).Check engine"s sealing(crankcase gasket,cilinder gasket,seals-crankshaft,carb gasket).Also the mufller(not to be clogged),disassembly the carb (check and clean it),fuel lines and fuel filter (check and clean them),gas cap tank vent(not to be clogged),the air filter.Please let me know. best regards savumihai71
Posted on Dec 22, 2008
SOURCE: Mower smoking and sputtering.
Sounds like the engine is getting flooded because the carburetor float needle is not seating. Let me know if this helps.donnyb60
Posted on Mar 23, 2009
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
Toro 22" recycler lawn mower, Briggs & Stratton engine. Engine low on oil, would not start after a few pulls. 20 oz oil added, mower started after a few pulls. Finishing the lawn when a white puff of...
Hi michael, You have most certainly put in too much oil. Try draining a bit off and then clean the spark plug with some paper towel. Leave the mower level for a few hours and then try it again.
Sep 22, 2013 | Toro Garden
Lawn mower oil leak
is the engine smoking out the exhaust or by the filter if it is coming from exhaust sounds like a ring problem
Jun 05, 2013 | Honda Garden
Gas Blowing Out of Exhaust
Hi Haley
Here are a few suggestions
May 02, 2013 | Cub Cadet Garden
Oil and white smoke out through exhaust?
smell the oil if it smells like gas change the needle and seat inn the carb and change the oil the valve in the carb doesn't seat and the gas drains into the oil
May 24, 2012 | Yard Machines Garden
I have a craftsman 6.5 push mower. I was trying to start it by pulling the string (after i primed it 3 times like it read to do). But i forgot to hold down the handle part. When i did realize i had to hold...
You did no harm. Try pulling a few more times and if that doesn't work, prime it 3 more times and if that still doesn't work, prime it 3 MORE times. It should start.
Gary
Aug 07, 2011 | Craftsman Garden
I leaned my lawnmower forward (on its front wheels) when I stored it. Now the lawmower is sputtering when I start it...There is smoke coming out the side of it. It only runs properly if I lean it on its...
most likely you have oil on top of the pistons and to much has gotten into the intake and exhaust valves. remove the spark plug, clean it or replace it, than pull the starter rope several times to exhaust some of the oil inside. install plug and start the mower. it might smoke some but should clear up.
Nov 20, 2010 | Mtd 22" Yard Machine Push Mower
Lawn mower runs and then putters down, won't die but runs slow.
clean the air filter,wash out in turps if foam type,then wash in soapy hot water,then rinse,let dry,then put litle bit of clean engine oil in it,squeeze.drain all fuel,and put fresh in.may have to pull carb to bits and blow out,and reassemble.put new spark plug in.is it a briggs engine,or tecumseh?
Jul 11, 2010 | Garden
White smoke and some oil coming out by exhaust
check your oil level in mower. probably too much.
Jul 04, 2010 | Toro Lawn Mower With Toro Power Tools
Toro lawn mower
ethaanol in fuel...happens when gas sits too long...especially in a gas can in the garage
Apr 10, 2010 | Toro Lawn Mower With Toro Power Tools
Troy Bilt 5.5hp Self Propelled Mower Logo
1,732 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
