Question about SanDisk Sansa E280 MP3 Player
My sansa disk is on the charger but not charging this is the forst time it has every done this it hooked up but nbot charging what do i do
    Genius:
  • 1,239 Answers
Hi sir ,
it's may be a charger problem.. please verify.. at pin of the charger see in muiltimeter vg is showing.. and reply me.. sir.
Posted on Sep 01, 2008
Looking how to charge the batterie on a Mountfield 1840h grass tractor please-no instructions manual, please help xxx
buy a battery charger
take the battery out of the mower
hook the charger up to the battery
when the charger shuts itself off you are done.
you may also just remove the wire from the positive battery post and charge the battery
while it stays in the mower.
you may well find you have a bad battery and you are wasting your time trying to charge it.
May 06, 2011 | Garden
My cordless HDR 130 Sennheiser headphones no longer charge. I have only had them for about four years. What do you think is going on?
The batteries are at end-of-life OR your charger has failed.
Forst replace the batteries... they are MOST likely bad. Charge the new ones before using.
Feb 02, 2010 | Sennheiser HDR 130 Consumer Headphones
My Sansa c250 won't charge properly. Initially when I bought it, I used it with a Windows XP PC, no sweat. That computer died and I began charging it with an OSX instead. It worked for a while, but after a...
I had a similar problem. My Sansa c250 would charge, when plugged into the computer. It would read that it was writing but the computer did not recognized that the Sansa c250 was connected. I switched to a different USB port and got the same results. I then realized that the two ports I was using were 1.0 port and idmedeatly when inserted in the 2.0 port it began charging and the computer recongized the Sansa c250. I know this won't solve every charging problem one may have. Changing the battery would be easier in some cases. Especially if they were sold like the AA or AAA.
Jun 08, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Mp3 player shows that battery is dead even though its charged and the screen only works if i hold the on off switch the whole time
try inserting the charger to a different socket until it works. if not you might be having problem with the charger. not the mp3 player and if you already triedto change the charger you might be having problem with the battery of your mp3 player ok send me a message for more concerns.
May 04, 2009 | SanDisk Sansa m240 MP3 Player
My SanDisk Sansa Clip won't charge, it say's it's connected with the charging bar moving quickly back and forth
If you've used the player while hooked up to the charger this often kills the battery and you will need a new one.
Never use a phone or battery operated device through the charger. Always just let it charge!
Has it held a charge before?
Jack
Mar 08, 2009 | SanDisk Sansa Clip MP3 Player
Charging the Sansa Clip player
If you leave your Sansa plugged into your charging source (wall charger, computer, car etc.), your player might still remain fully charged and just on. If you can, you may want to just leave it plugged into your charging source until you want to use it, so it stays fully charged.When its done, it will say fully charge...it should take a couple hours to charge the device....
Also, does your player have an auto power off or idle sleep setting? You can use this setting to set the amount of time you want your Sansa to automatically turn off after you don't use or listen to music on it.
Jan 01, 2008 | SanDisk Sansa e250 MP3 Player
Screen black
Try to get a firmware upgrade done..once you have that done you should be able to use the device without having any problems..
Dec 30, 2007 | SanDisk Sansa e260 MP3 Player
I don't know how to charge my mp3
The cable that came with it to connect it to your computer is the charger. It does not plug into an outlet..it charges while hooked to your computer.
Dec 29, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa E280 MP3 Player Logo
50 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
