Question about HP Jornada 568 Pocket PC
How to activate daylight saving mode on Jornada 568?
Hi, I have a project with 300 568 units. We went few weeks ago to summer time (daylight saving), but the Jornada has no menu to set it. I've downloaded a registry editor and looked for somethink, with no success. Any edvice? BTW - MSDN gave few links to API level calls to set/clear it, but no more than that.
3 Suggested Answers
adib
  • 450 Answers
SOURCE: How to Change Pocket PC language in jornada 568
Hi, You need "localization" software: it translates system commands as well as provides virtual keybord layout, handwriting recognition. I am using PenReader and Polish Localization done by Paragon Software ( avaliable on Handango) ; they have Spanish version as well. Thaer are other companies which do same sort of software.
Posted on Sep 12, 2005
adib
  • 450 Answers
SOURCE: Jornada 568 Sync Problems
All you have to do: Select Device Manager, select "Universal Serial Bus controlled". Re-install the USB driver from Active-Sync CD. That's it.
arturheise
  • 230 Answers
SOURCE: windows media player for hp jornada 568
It's built into the system...
Posted on Apr 21, 2008
0 characters
1 Points
System upgrading
You cannot upgrade the OS of the Nino 300. There are however some patches available (bugfixes). btw ... struck by lightning??
Sep 14, 2005 | Philips Nino 320
System upgrading
Sep 14, 2005 | Philips Nino 312
Upgrading the system
Sep 14, 2005 | Philips Nino 301
Sep 12, 2005 | HP Jornada 568 Pocket PC
Active sync and Outlook xp
Maybe i should help, because i was solving similar problem with C-Series handheld from Compaq, which is almost the same. I am using Active sync 3.0 as the newer versions didnt work properly and i got no problem...
RESOLUTION
Maybe he's using ClearType and you aren't?
Operating system upgrade?
The Jornada 568 has its OS in masked ROM. There is not an upgrade available.
Clock out of control
I have a Jornada 568 but I've never seen the behaviour you describe. Is it possible that you damaged or caught a small part when you installed the new battery? Your new battery, was that the small round battery or a battery pack on the back of the unit. "Resetting to Factory defaults" suggests that there is no power at all, doesn't it? If the small round watch battery is dead then that might effect the clock.
HP Jornada 568 Pocket PC Logo
20 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
ka4iup
ka4iup
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
