Question about HP Computers & Internet
My laptop HP Pavilion is saying every time i try to open "Checking file system on C:" The type of the file system is NTFS. One of you disk needs to be checked for consistency. you may cancel the dis check, but it is strongly recommended that you continue. It tell me i can skip the disk check but it wont allow me to. what needs to be done?
  • 66 Answers
Dude u can also try scan this...first click my computer then right click drive C: then properties then tools then check now....same procedure in drive D:
Posted on Sep 01, 2008
  • 71 Answers
You need to finish that disk check on all drives on your system to check for corruption. Its the safest thing to do.
After that is done, defragment your drive for extra safety.
From the desktop, select My Computer, right click each installed hard drive on your computer, select Properties, Tools and run both error checking and defragmentation one after another.
If you have corrupted removable drives like USB dongles or floppies, they can be checked later separately.
Trouble with Transcend 640Gb external harddrive; chkdsk does not work.
You will have to format it. Format it in NTFS mode since it is high capacity drive. I think you are trying to use it for the first time. This also occurs if you have problem in hard drive but it is rare. Let me know after formatting, it is working or not. I will help you further.
Increase Engine Horsepower
Jul 23, 2012 | Transcend Computers & Internet
Im booting my new HDD on my HP DV1000 and the windows setup says that no HDD detected but the HDD is properly in place what should i do to fix it
you need to format your HDD before using it. Windows uses NTFS file system, so use some disk utility to format HDD.
Jun 22, 2011 | HP Pavilion dv1000 Notebook
I have an HP Pavilion dv6500, and while I was working on my laptop it suddenly shut down by itself and restarted. When it rebooted, a message came up saying "Operating System not found". I...
Your hard drive may have failed.
I suggest you remove your hard drive and re-connect it to your laptop to make sure it is make proper connection. Boot up and go into the BIOS to see if the hard disk is detected.
If the hard disk is not detected then most likely the hard disk has failed.
To get your laptop working, you will need to purchase a new hard disk and install Windows on the new hard disk plus the Pavilion device drivers and your programs,
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Dec 18, 2010 | HP Pavilion dv6000z Notebook
I have an hp pavilion dv6...i know how to open my webcam and it usually works just fine when i take pix or when i use it to video chat on skype. today it stopped working. when i open my webcam it says that...
Windows Vista and 7 ( can't remember about XP ) come with native drivers for the webcam so it may be a problem with these. You could try running a system file check by browsing to all programs, accessories, right click on the Command Prompt and select 'Run as Administrator'. Type in the following command and hit return. sfc / scannow
If that doesnt work download and install the software driver for your webcam on the link below. http://www.downloadsource.net/d16952/HP-Pavilion-Webcam-Driver-Windows-Vista-x32-x64/ i hope this works for you.
Dec 12, 2010 | HP Pavilion dv6000z Notebook
I turn it on and it goes to a screen that says: "Checking file system on C: The type of the file system is NTFS. volume label is s3A5802D002. one of your disks needs to be checked for consistency. You...
the time it takes depends on the hard drive size but you push esc or enter as these are primary keys or let it start go have a coffee then come back to it.
Oct 06, 2010 | Toshiba Qosmio G25-AV513 Notebook
How do i get my boot mgr drive back on my hp dv9000 laptop? I backed up all ym files and when I start my pc up it says the boot mgr is missing.Please help
http://vcic.com/vault/bootme.exe Copy the files to a floppy disk, OR Use a XP/Vista install disk. Boot into repair mode and type "fixmbr" without the quotes.
Jun 06, 2009 | HP Pavilion dv9000z Notebook
My dell 8400 displayed this error message 00f0: 136c and 00f0: 0242 What can I do. Thanks
This message is likely to be due to a segment error on your hard drive.
Checking /correcting disk errors
You can use the Error-checking tool to check for file system errors and bad sectors on your hard disk Open My Computer and then select the local disk you want to check.
  1. On the File menu, click Properties.
  2. On the Tools tab, under Error-checking, click Check Now.
  3. Under Check disk options, select the Scan for and attempt recovery of bad sectors check box.
To open My Computer, click Start, and then click My Computer.
  • All files must be closed for this process to run. If the volume (drive) is currently in use, a message box will appear prompting you to indicate whether or not you want to reschedule the disk checking for the next time you restart your system. Then, the next time you restart your system, disk checking will run. Your volume will not be available to perform other tasks while this process is running.
  • If your volume is formatted as NTFS Windows automatically logs all file transactions, replaces bad clusters, and stores copies of key information for all files on the NTFS volume.
Mar 31, 2009 | Microsoft Windows XP Home Edition
How del bad sectors in hard disk
Detecting and repairing disk errors You can use the Error-checking tool to check for file system errors and bad sectors on your hard disk. Open My Computer, and then select the local disk you want to check. On the File menu,Right click>> click Properties. On the Tools tab, under Error-checking, click Check Now. Under Check disk options, select the Scan for and attempt recovery of bad sectors check box. Notes To open My Computer, click Start, and then click My Computer. All files must be closed for this process to run. If the volume is currently in use, a message box will appear prompting you to indicate whether or not you want to reschedule the disk checking for the next time you restart your system. Then, the next time you restart your system, disk checking will run. Your volume will not be available to perform other tasks while this process is running. If your volume is formatted as NTFS, Windows automatically logs all file transactions, replaces bad clusters, and stores copies of key information for all files on the NTFS volume.
thanks.
Mar 07, 2009 | Acer Computers & Internet
Checking file system on C: The type of the file system is NTFS. I turn on my hp pavillion ze4400 and get a blue screen with this message: One of your disks needs to be checked for consistency. You may...
You got a bad disk
Get an external hard drive.
Reboot and Cancel the disk check for you to log-in to Windows.
Back-up all important data.
Once data is safe, open My Computer and right-click on you C: drive then choose Properties.
Click on the Tools tab and click the Error Checking button then select all options and follow on-screen instructions.
Nov 12, 2008 | HP Computers & Internet
Computers & Internet Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
