Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Dvd audio fix
What did you do to get your dvd audio to work>?
    Sergeant:
  • 336 Answers
I need more detail in order to help, like software you are using, what you are trying to burn onto dvd, and what type of DVD burner you have
RCF
Posted on Sep 03, 2008
I got a new vitz, when i insert the a DVD to my NDDN W56 player, the audio is working but video is not working? How can i fix it? please email me the solutions? Arun_kandyguy@hotmail.com
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 24, 2012 | Toyota Toyota Cars & Trucks
Tip
Standalone DVD player with DivX why does the VBR encoded Audio lag the Video
DivX or XVid encoded MP4 Video codec or AVI will almost always have either the Dolby Digital AC3 Codec or the MP3 encoded audio codec see the following links; Fraunhofer MP3 Decoder or LAME MP3 Encoder
This fixed audio lag can sometimes be caused by VBR audio encoded files and starts part way through the playback as opposed to CBR audio some standalone DVD players will exhibit sound lag in this case. It is a good idea to re-encode the VBR to CBR audio this usually solves the problem.
I suggest that you convert/encode all your DivX AVI files into CBR audio to avoid any such errors; all commercial DVD Video Audio is encoded in CBR (constant bitrate) which also reduces the audio filesize unless its encoded in LCPM which will give a much larger audio component.
Check the audio bitrate type open the AVI in GSpot the example below shows an AC3 audio already in CBR so can be left alone and should work fine.
MANUAL CONVERSION PROCESS
This audio MP3 conversion process it a bit of a long way around I know, but it does work!
  • Open video in VirtualDubMod or VirtualDubMP3 (if there is an index error this can sometimes fix it for you.
  • Ignore the error warning that the video contains VBR audio.
  • Extract audio as MP3 ("demux" in VirutaldubMod or save as WAV, then rename to MP3 in VirtualdubMP3).
  • Convert audio to WAV with CDex
  • Open original video in VirtualDub,choose "direct stream copy" for video and "WAV audio" with "Full audio processing" with CBR MP3 compression (and interleaving with appropriate delay if out of sync) for audio.
SEMI-AUTOMATED CONVERSION PROCESS
You could also use several other easier methods including AVIDemux which uses VirtualDubMod or scan in the DVD-Video using TMPEnc v4.0 Xpress and applying a time lead OR lag however this does not solve a progressive lag *** but can be used to re-author a fixed audio lag error in milliseconds you can use either Windows Media Player Classic or KVM Player in real-time to find this lag or lead error and then adjust accordingly
If you can't work AVIDemux then AVIrecomp will be your best solution this is a bit more user friendly
NOTE> always keep a Backup copy of the AVI before you make any drastic changes as you could make the file unplayable the above process will only work on FIXED AUDIO LAG AVI files.
Progressive Audio Lag (starts in synch and runs fast or slow throughout the AVI is almost impossible to remove with re-encoding the AVI using the above methods.
*** Feel free to comment if you know of a foolproof way other than performing a full re-encode from the MPG2 or DVD VOB file.
on Feb 08, 2010 | Philips DivX DVD Player
Clarion's VRX765VD player - Radio works but Audio in cd/dvd ?
Yes I do. I have a similar problem with my 2000 Chevy Suburban. I need a fix!
Jun 17, 2009 | Clarion (VRX765VD) Car DVD Player
Yamaha RX-V3800 receiver zone two audio problems
To get audio with this set up also hooked up analog audio RCA cables for the audio for each piece of equipment for 2 channel out put. Zone 2 will not out put a digital signal and this receiver will not down convert a audio signals to analog if using digital audio hook-ups.
Mar 15, 2009 | Yamaha RX-V3800 Receiver
Lenoxx DVD-1000 Audio does not work
Check for the capacitors around output amplifier.Easy to fix
Mar 11, 2009 | Lenoxx Electronics DVD2003 DVD Player
Have picture, no sound
I've had this trouble too. Not sure how to fix it, but I've found a work-around:
Remove DVD.
Insert Audio CD.
Wait for audio to play.
Remove audio CD.
Reinsert DVD.
Sound should work again.
If you power off the unit, you may have to try this procedure again.
Sep 27, 2008 | Cyberhome CH-DVD 300 DVD Player
Denon AVR 1705-no audio on TV
I have had the same problem and was told that it is a "board" inside. Essentially it has lost the surround sound ability and can only play things in Direct/Stereo. Mine is just over 2 years and I originally thought my kids had hit a button on the thing causing the issue...ended up paying $100 to trouble shoot it and confirm that it is internal and more expensive to fix than replace. Can't say that I will be buying a Denon again.
Jul 09, 2008 | Denon AVR-1705 Receiver
No sound thru dvd player, but fine for tv and vcr
Just had the same problem and it is fixed for me. With NO DISC in the player go to the System Menu. Next Navigate to Preferences on the top of the screen.
You will set an option titled "Default". Select that and it seems to reset the player to default settings and fixes the sound.|
Jan 03, 2008 | Philips MDV460
Sound lags picture
This can some times be caused by VBR audio encoded files as opposed to CBR audio some standalone DVD players will exhibit sound lag in this case. It is a good idea to re-encode the VBR to CBR audio this usually solved the problem.
Although this is usually with DivX (AVI) files that have been re-authored to DVD-Video I suggest that you convert all audio to CBR to avoid any such errors.
this conversion process it a bit of a long way around I know, but it does work!
1) Open video in VirtualDubMod or VirtualDubMP3 (if there is an index error this can sometimes fix it for you.
2) Ignore the error warning that the video contains vbr audio.
3) Extract audio as mp3 ("demux" in VdubMod or "save as wav", then rename to mp3 in VdubMP3).
4) Convert audio to wav with CDex
5) Open original video in VirtualDub, choose "direct stream copy" for video and "Wav audio" with "Full audio processing" with cbr mp3 compression (and interleaving with appropriate delay if out of sync) for audio.
You could also use several other methods including AVIDemux which uses VDub Mod or scan in the DVD-Video using TMPEnc v4.0 Xpress and applying a time lead OR lag however this doex not solve a progressive lag but can be used to reauthor a fixed error.
Feb 12, 2007 | Philips DivX DVD Player
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
