Question about Cuisinart DCC-1200 Coffee Maker
Problem with coffee maker cuisinart
You said on Fix Ya that you fixed your coffee maker. How did you get to the orange tubes to unclog the hose??
Thank you!
--J.
    Problem Solver:
  • 5 Answers
Use a Torx T-9 tamper resistant tool to remove the screws on the bottom and access the inside of the machine.
Posted on Jan 10, 2009
My Cuisinart series 1200 just stopped working and the on light will not turn on
That specific Coffee maker has had a few problems most of the time the it happens to be a burnt out motor, or a clogged line, if you purchased at a Bed Bath and Beyond you can take the coffee maker back even if you have had it for more then the warranty and tell them it stopped working and they will replace it you don't have to have a reciept or even a box. jsut take it in and tell them it stopped breewing and they fix ya up.
Nov 13, 2012 | Cuisinart DCC-1200 Coffee Maker
The coffe maker is leakingout the bottom when the
Same problem here. The hose has a one way valve in it as well. I slid the hose part way off the reservoir connection and used the extra length to make up for the portion I cut off at the cut (you may have to move the on one way vlave further down the hose). This was intended as temporary fix while mywife bought a new coffeemaker. The new coffeemaker has been itting here six months as my temporary fix continues to hold.
Jul 04, 2010 | Cuisinart DGB-600 Coffee Maker
It leaks from the bottom of the coffee maker
The heating element in these is underneath the hot plate. The water gets to the heater through two short pieces of hose, and sometimes this hose leaks. Sometimes the connection between the hose and the heater leaks also.
If you are so inclined, you can take off the bottom plate and replace the hose pieces, or try to tighten the connections to the heater.
Mar 19, 2010 | Cuisinart DCC-1200 Coffee Maker
We cleaned our DCC-1200 cuisinart coffeemaker twice with vinegar and water however, when brewing coffee now it takes almost 45 minutes for the cycle to complete. When it does complete, the pot is half...
I had the same problem and just finished fixing mine. The problem is very likely that you have coffee grounds in the water hoses in the bottom of the unit; this gets worse over time, constricts the flow, and can lead to all sorts of woes. Cuisinart will void the warranty if you open your unit, and they neither sell replacement parts (e.g., hoses) nor provide any guidance on how to fix it (I found this out when I called them today). If your unit is less than 3 years old it is still covered by the warranty and they will send a replacement unit; if it's more than 3 years old you have nothing to lose!
Here are the steps:
  • First, thoroughly clean, scrub, and rinse every part of the coffee maker that you can access. Make sure to remove the black plastic cover inside the top lid (snaps off easily). You'll be disgusted by what you find and there may be oily caked-on sludge inside the cover. You want to get any stray coffee grounds you can.
  • Get a Torx type screwdriver, size T-10 (this looks like a starburst pattern; a hex driver will not work). You can buy a set with different sizes for about $6 at Sears, Lowes, Home Depot, etc.
  • Turn the unit over and you'll see 4 small screws deeply recessed in the bottom; remove each of them. You may want to use a flashlight to locate which holes have screws, as some don't.
  • Pull the bottom cover off, making sure not to lose any screws.
  • You will see 2 rubber hoses, likely orange, each about 6" long. 1 end is attached to the metal heating element and held in place by a clamp; the other end goes into the coffee maker.
  • Remove the end of each hose that goes into the coffee maker by simply reaching in and pulling gently. They should slide off fairly easily. Do NOT try to remove the clamped ends. Trust me--I tried and they are fused to the metal; they shred very easily and won't budge...
  • Pour a little water in the left hose (with both loose ends facing you it's the one on the left). While holding a cup to the right side hose end blow hard into the left hose. Water will squirt out into the cup and you'll almost certainly see some coffee grounds in the water. Repeat this step 4 or 5 times, making sure there are no more grounds.
  • Re-attach the hose ends to the coffee maker, replace the screws.
  • Run 2-3 full pots of plain water through the unit to remove any stray grounds and you're good to go
Mar 07, 2010 | Cuisinart DCC-1200 Coffee Maker
My cuisinart cofee maker is clogged. Water goes
OK, I Fixed it. Overcame mutiple issues. Here's the deal.
1. Call Cuisinart. If your in warrenty, they will just ship you a new one.
2. The issue is that ground overflow the basket and clog a check valve in the water line.
3. instructions assume coffee maker is positioned upside down and with water chamber closest to you.
Solution: Dissasemble and flush grounds out.
1.Remove botoom plate.
They intentially made it impossible to get into There are custom 10mm torx screws with nipples in the middle (like compaq computer did to prevent us from opening computers). Answer DRILL them out. Extreme sounding but really pretty easy on the cheap soft screws.
Drill out four (4) screws and Remove bottom piece.
2. Free up Bottom plastic base. (hoses and wires will prevent true removal)
Next issue is getting long (4 inch) size #0 screwdriver and removing 5 phillips screws. I had to got to home depot because Target and walmart didn't carry anything small enough and long enough.
3. Remove left silicon hose (Orange).
Lots of stuff here.
a. pull BOTH hoses off the plastic (not aluminum) nipples down inside the coffee maker. No clamps, just pull up.
b.Move LEFT metal clamp back off alum tube on the left hose.
c. work LEFT hose off tube (know that it is full of grounds,,,)
4. Flush
CAUTION: Don't force this next step with water pressure. THere is a check valve which is supposed to stop flow one direction. You can feel the checkvalve and see it once grounds are out.
a. Clean hose out. Logic says use sink, but I just used water in my mouth to gently go back and forth and grounds flowed into waste glass. flush FROM metal clip to water chamber. Get all grounds out.
b. you can validate check valve working again because you can feel flow only goes one way as you swish water back and forth (again mouth works great)
b. Re-attach hose to alum tube
c. Flush from left hose through tube through right hose into waste glass.
5. Reinstall.
a. know that circuit board has to be seated in slot
b. position base on and install 5 screws
c. THEN attach hoses to plastic
d. put on base plate. Mine kind of snapped in place, but I put clear tape on it to hold it there. A real mechanic would of drilled out the screws and installed larger ones. Meh.
Dec 08, 2009 | Cuisinart DCC-1200 Coffee Maker
Discolorization(orange) inside coffee maker.
Try mixing in some vinegar with your water (about a cup) and run it through a cycle, this may clean it out.
Tom
Oct 04, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
My cuisinart coffee maker leaks
1. Purchase (1) a couple of feet of 3/8" ID by 5/8" OD temperature resistant silicone tubing from a beer/wine-making supplier, or online through Ebay, and (2) a couple of hose clamps big enough for the tubing.
2. Unplug the coffee maker and turn it upside down on some old newspaper.
3. Using a T10 Torx screwdriver, remove the 4 screws that attach the the bottom plate of the coffee-maker, and remove the bottom plate.
4. Unclamp the two orange/red hoses from the C-shaped heater, and carefully pull/remove the other end of the two hoses. One hose is a water intake hose from the water tank to a C-shaped heater element, while the other hose is water outlet hose that goes from the C-shaped heater element to the sprinkler assembly.
5. Carefully remove the small plastic stop check valve from the water inlet hose end close to the C-shaped metal water heater; and take care to not drop/lose the little round plastic ball inside the plastic stop/check valve, while noting which way the stop-check valve is oriented in the hose.
6. Cut two pieces of your food-grade / temperature resistant silicone tubing that are the same length as the old hoses.
7. After reinstalling the stop-check valve in the new inlet hose/tubing, reinstall the two sections of hose/tubing, and use two hose clamps to attach the new tubing to the C-shaped water heater.
N.B. Remember that the stop check valve s/b oriented such that hot water in the C-shaped heater element can't go back to the water tank.
7. The ends of the hose that attach to the C-shaped metal water heater s/b clamped, while the other ends just push onto the water tank and sprinkler assembly with a with a little pushing and twisting.
See http://www.cocosvariety.com/2011/11/fixing-cuisinart-coffee-maker-alternate.html , as that is the original information source for this posting and the image below. i.e. Credit goes to Coco's Variety !.
Also, in the image below, the hose on the left is the water inlet hose, while the hose on the right is the water outlet hose.
Dec 14, 2008 | Cuisinart DCC-1200 Coffee Maker
See post on Cuisinart customer service. The tube can be purchased at Lowes. Clear vinyl 1/2" O.D., 3/8" I.D. The compression clamp will have to be replaced as well.
I used a 1/2" hose clamp available at any auto parts store.
Aug 19, 2008 | Cuisinart DCC-1200 Coffee Maker
Water leaking from bottom of coffee maker
The water hose on the bottom of the coffee maker is worn, due to the heat. It needs to be replaced. this is the second time for mine.
Mar 24, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
478 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
