Question about ASUS K8V-SE Deluxe Motherboard
USB 2.0 Tried alot of things, but i still cant get it to work, this is my problem. This mobo has usb 2.0 right? Well i get speeds that are close to usb 1.0 to my ext harddisks. I reinstalled the 2.0 drivers, it "said" it was usb 2.0. But still, my speeds are so slow that a few gb takes 2-3h to move. Anything i can do?
  • 66 Answers
Dude try to change your USB Partition in drive....maybe it was a Fat32 not NTFS
Posted on Sep 01, 2008
How to install a sd card reader on a Dell Dimension 8200 PC Desktop? no 4 pin usb on motherboard?
I managed to install a card reader on my Dell Dimension 8200.
The main problem is that the Dell motherboard does not have the correct USB pin. This is a 9-pin MoBo USB header.
The quick answer is I installed a USB card with an internal port.
http://www.amazon.co.uk/Unbranded-USB-2-0-PCI-Card/dp/B00066LPA2/ref=sr_1_6?ie=UTF8&s=electronics&qid=1264968643&sr=1-6
Secondly I reverse mounted a powered 4-port USB hub in the spare 3.5" bay.
http://www.cablecity.co.uk/product_info.php?products_id=1149&ref=6
Third, I purchased 2 USB 5 pin male to usb leads...
http://www.amazon.co.uk/v2-0-Male-Motherboard-Header-Connector/dp/B000QC7NKM/ref=cm_cr_pr_pb_t
You cannot buy a USB card with 2 internals and do away with the 4 port powered USB hub because the card reader does need to be connected to a powered USB port.
for more info see this...
http://www.mods-n-clocks.co.uk/?p=181
Jan 23, 2010 | Dell Dimension 8200 PC Desktop
I am using an older PC with a ASUS CUSL2 AGP Pro/4X Motherboard as a intra-offfice server devise. I'd like to add USB 2.o or change out the 2 rear USB prots to 2.0. I've tried doing this witha USB 2.0 PCI...
You have two options
One is to replace the whole motherboard but that would probably also entail new ram, cpu, cooler, graphics card, even maybe a new PSU.
Two is to fit a pci usb 2.0 card.
You said you did TWO but it didnt work. I am not sure why without more details but if you are using windoes 95 or less than that would be a major problem.
Only the later windows 98 and above can really make full use of USB 2.0 and even with 98 and win ME you would need to make sure he correct drivers were installed too.
Nov 09, 2009 | ASUS Intel 815E Chipset CUSL2 Motherboard
Worked out F_PANEL connectors.
Every motherboard has its connections manual, also case has marks and signs at its connectors, if your case has more then your motherboard it can be front panel audio and usb jack go to your motherboard manufacturer web site and search for manual for your model. Also there will be upgrades of your bios and also CPU types your motherboard supports. If you CPU is correctly inserted and when power on it ons and then automatically offs may caused because you dont have CPU fan installed and it cant cool so automatically powers off.
Jul 28, 2009 | Computers & Internet
L1932TQ Fails on Desktop, works on Notebook
it simply means that your cpu is not giving back signal to your monitor to process, in fact, it is a cpu problem that is why there is nothing to display in your monitor.
Your cpu froze because of that usb thing. the only way to unfreeze it is to manually reset your hardware in this order.
1. RAM modules. If you can unplug your RAM (memory modules) connected in your motherboard, please do it. Just unplug the modules and then plug it back in. if you have 2 rams, then interchange them when plugging it back. this will force your mobo to refresh its resources.
2. CPU. if you can pull out your cpu chip, then do it. this will refresh your cpu setting in your mobo. (mobo = motherboard)
Regards!
Jul 12, 2009 | LG L1932TQ LCD Monitor
No high speed usb port
Hi Delvin!
The 2 usb-ports on the front and the 3 back of your Dell is high speed ones, at least the manual says so, they are all USB 2.0.
If you cant get them work properly with the 2.0 usb speed, you can buy an high speed pci add-in- card and install it on your pc.
Here you can read about the "high speed usb" :
http://www.usb.org/developers/usb20/
And here is the manual and avalible drivers for your Dell:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
Good luck to you M8!
Please take a moment and rate my help for you
Nic
Feb 23, 2009 | Dell Dimension 1100 PC Desktop
SOYO USB lock up must reset PC before accessing any USB
I have had alot of problems with soyo mobo's.  Seems the drivers that they provide for the USB are crappy.  Best stick with windows default drivers.
Nov 28, 2008 | Soyo P4VTE (SY-P4VTE) Motherboard
Dell XPS 400 no power to usb or pci slots
I have had the same problem with my dell xps 400. What I did was purchased a usb power hub and that solved the problem for me. SAved me from buying a new mother board.
Sep 09, 2008 | Dell (002TR) Motherboard
USB ports not working DV 1000
I just fixed this problem on my dv1000. The problem I found was apparently the USB ports on lower right and left side only mounted on the mobo with light soldering and no soldering on the other side of mobo. Due to heat I guessed, they came loose. I opened the mobo (using guide from a pdf file on the net, sorry i forgot the exact guide but you can ask uncle google).
I took the mobo out and resolder those two ports with plenty of solder from the top surface only of the mobo as I unable to access the other side. Now they work again like charm.
The top right USB is different beast. It is on different card along with S-Video port and apparently in permanent damage.
Dec 06, 2007 | HP Pavilion dv1000 Notebook
Dell precision not recognising usb 2.0
sounds not,  some of the older systems only have 1.1, Usb 2 is not all that old (about 2-3 years).
you can upgrade to USB2 bu adding a USB2 PCI card to your system, this would give you some ports on the back and it may be possible to link the ports on the front to the new PCI card to upgrade those as well (depending on how they are connected to the mobo)
you can get USB2 cards with a Pin header which would allow for a pin block connection.
Oct 25, 2007 | Dell Precision Workstation 670 PC Desktop
ASUS K8V-SE Deluxe Motherboard Logo
75 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
