Question about Troy Bilt 5.5hp Self Propelled Mower
Problem mowing my lawn.
My mower continually leaves single, uncut blades of grass. I have tried mowing more slowly, had the blade of the mower sharpened. I am sure to mow when the lawn is dry, but still I am left with uncut blades of grass sticking up everywhere. My lawn is St. Augustine.
  • 2 more comments
  • Anonymous Mar 14, 2014
    Correct way to fix the blade
  • Anonymous Mar 16, 2014
    YTH 150
  • Anonymous Mar 30, 2014
    mower deck drops down when mowing
  • Anonymous Apr 01, 2014
    toro timecutter
I had the same problem and I already found those recommended solutions\ causes on the web:
1. The motor isn't on full throttle.
2. The blade is upside down.
3. The grass is too high when cutting it.
4. Overlap your cuts.
It helped my problem/ I hope it will help yours too!
Posted on Sep 01, 2008
I have a castle garden ride on lawn mower xd 140 hd it goes fine but when I cut the lawn there is a bit of uncut grass left in the middle of the two blades
sounds like the blades are worn out leaving a gap between them. clean the bottom of the deck to be sure there is no grass matted to the inside. if that dont work replace the blades
Jun 13, 2017 | BIT Garden
Why does it bog down in grass maybe 6 " high?
The likely cause of this is that the grass is too high for your mowers deck. You should try just mowing about 1/3 of the blade at a time (if you can) until you reach your desired length, so if you grass is 6" high, only take off about 2" at first to reduce the stress on your mower. Set your mower deck to it's highest setting and give it a shot.
Also, be sure that the blades are sharp, and if you don't have mulching blades, you should get some! Grass this high will leave long clippings on the lawn which can suffocate the grass, mulching blades will chop up the clippings into smaller pieces, which is beneficial for your lawn!
Finally, make sure you aren't mowing wet grass. If you mow when the grass is wet the clippings can stick together and clump up under the mowing deck which will cause excess strain to the mower and maybe even cause it to shut off.
If none of this works, you may want to use a string trimmer to remove the first two inches of your grass and then continue mowing as normal!
Hope this helps! Happy Mowing!
Aug 03, 2015 | Garden
I have a twin blade Toro riding mower. It leaves an uncut stripe in the middle. How can I fix?
Sharpen the blades on both. Dull blades will fold the grass down.
Nov 04, 2013 | Toro Garden
Why is my husqvarna zero turn leaving a strip of uncut grass on the left side of the deck
I have a 2014 HUSQVARNA RZ5424 that I just changed the blades on for the first time now 2017. I got new gator blades because of all the good reviews on them. They are about as good as a screen door on a submarine at 300 feet deep. There the same length as the original blades but leaves two rows of uncut grass about a inch wide regardless of how you try to cut it. Only 240 hours on mower, deck clean ,spindles kept greased . Went back to new Husquvarna blades like the ones made for it. PROBLEM SOLVED. HAPPY HAPPY HAPPY. REL.
Mar 24, 2013 | Husqvarna Rz5424 Zero Turn Lawn Mower...
During mowing grass will gather underside of deck leaving 2 streaks on r and l if you turn deck off grass will fall out of deck before restarting u need tgo move or mower will stall from grass build up...
There are a couple of things going on here. First, the blades are likely worn out and need replaced. As they wear and loose some length they can leave a trail. Second, if you have regular blades on a deck configured (by having discharge plugged) for mulching and you are using regular blades, then you can have a problem with build up. Third, you can have clumping problems if the grass is not dry when you are mowing.
I hope this is helpful for you.
Aug 24, 2011 | Ariens 48" Riding Lawn Mower Blade ...
When mowing with my John Deere riding mower, it leaves a narrow strip of grass uncut in the center.
try sharpening the blades on the mower. dull blades can sometimes cause a strip of uncut grass
Aug 19, 2011 | John Deere 22HP VTwin 48" Riding Mower
Toro 42 " Zero Turn; In tall grass and even in moderate grass it is leaving a double strip of uncut grass, that lines up with the division between the centre blade and both outsice blades, resulting in...
Your blades may be erroded on the edges? Or the center blade hub might be damaged or worn.
good time to inspect all the blades and spindles for wear or damage.
Jun 26, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
I have a MTD Pro riding lawn mower that I
the only way to fix it is fit the right blades
they have fitted the wrong blade's to it,,,
the blades should overlap when cutting the grass they cannot crash into each other as there are (timed up) not to do that the new blades they fitted are to short so you have no over lap on the gutters that leaves a strip of grass left uncut between the blades,,
call them out to put this stupid mistake right,,,
Oct 25, 2009 | Garden
I have a Craftsman Lawn tractor. Blade leaves grass uncut.
Hi Tom,
Check your spindle shafts for loose play. If your bearings are worn out and sloppy, the belts pull the spindle to one side and an angle cut results... close cut grass at outer edge and high in center will leave this grass trail you are describing. I'd replace the bearings next year for sure.
I hope this helps... Good luck!
Oct 04, 2009 | Garden
A row of uncut grass left between blaces when mowing
THE answer that FINALLY worked for me. Torque the bolt that holds on the blade to the recommended torque specified in your owners manual (for my Exmark this torque is 120 ft-lbs). When I first used the torque wrench, i was quite surprised by the amount of addional force I needed to apply to reach 120 ft-lbs Exmark blades have a round blade hole with a washer and therefore, relies only on friction provided by torquing bolt to the proper torque to prevent slippage so that the blade rotates at the same speed as the spindle. When slippage between the blade and spindle occurs, blade tip speed slows leaving uncut grass.
Note: this solution will NOT work for mowers with a blade and spindle design which uses a positive means (e.g., a star shaped hole on the blade) that assures the blade rotates at the same speed as the spindle with no slippage.
Jun 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Troy Bilt 5.5hp Self Propelled Mower Logo
924 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
