Question about Nokia N95 Cellular Phone
Can't see a thing on screen
Hi, my n95 isn't working, its turns on but the screen is dark can't see a thing, you can only see the light. it doesn't turn off either.
    Genius:
  • 1,239 Answers
Hi sir
please remove the battery and memory card.. and after inserting the battery first for saffer side go to tools>settings>phone> restore factory setting . after restart insert memory card it work,s sir..
if doesn.t work mite memory card may be corrupted..
Posted on Sep 01, 2008
I have sound on my tv but no picture
This sounds like the back-lights have quit working. This is made up with an inverter (ballast) and fluorescent lamps. I want you to try something. In a very dark room turn the tv on and watch what happens to the screen. There is three things that can happen. first the screen will stay completely black. This means the inverter never fired, and this is usually a failed inverter, but sometimes the power supply may fail. there is also a rare time the main module never outputted the signal to activate the inverter, but this is rare because you can hear the audio. So obviously the main is working at least 90%. The second thing that can happen is the screen will light for a split second then go black. This usually means that you have a bad lamp. These lamps are physically locate inside the LCD panel, and the replacement cost exceeds the price of a new unit. You may even see a dark area in the screen. The slight glow will not be uniformly lit through out the screen. Finally the last thing you may see is the screen has a slight glow. This means the back-lights work, but the video portion isn't showing. This usually means the driver board (T-con) has failed. This is probably not available separately, so you must replace the panel to fix it. And like before, the replacement cost exceeds the price of a new unit. One more thing to do when the set is on and in the very dark room if the screen is black, point a very intense flashlight into the screen. Put the flashlight against the lcd screen and see that you have video moving around the glow of the flashlight.
Sep 12, 2012 | RCA 22LA45RQD LCD TV/DVD Combo
My nokia n95, screen just lights up & makes noise. u can call & recieve calls but nothing on screen except white back ground???I down loaded new face book has been updated & loaded google....
Hi you will need to replace the flex cable running from your main board to the screen, if this does not work then it is a Software issue and will need to be flashed with latest firmware, good luck
Aug 22, 2011 | Nokia N95 Smartphone
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
Nokia n95 dark hazy negative like display on & off after pressed
your phone need a general service. please contact service technician
Sep 22, 2009 | Nokia N95 Cellular Phone
I dropped my n95 and now it will not switch on it makes a noise but nothing happens ie screen doesnt light up
May be you display is with a problem. Visit the nearest Nokia care and the service personnel should help you out..
Thnks - billa
Jul 07, 2009 | Nokia N95 Cellular Phone
My phone works but without lights
Hi. The backlight is part of the LCD screen, so if you replace the LCD screen you'll fix the problem. Have a look here for a guide to replacing the screen and to buy the parts http://www.formymobile.co.uk/n95disassembly.php
Nov 21, 2008 | Nokia N95 Cellular Phone
Backlight on the screen not working
there is dim light on the screne
Nov 12, 2008 | Nokia N95 Cellular Phone
Power shot SD 110 dark screen
CCD failure but u are LUCKY just contact canon they will repair free of charge even if u are out of warranty dont worry and i deserve FIXYA rating for this
see these links below
http://www.imaging-resource.com/badccds.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
pls dont forget to rate me FIXYA
Jun 29, 2008 | Canon PowerShot SD110 / IXUS IIs Digital...
Nokia n95 screen problems
Try a hard reset on the device. Pull the battery out whle the device is on. Then put back in.
If that doesn;t work, try reloading the OS.
Jun 02, 2008 | Nokia N95 Cellular Phone
N95 nokia
you may need to update the software on the phone!
Mar 25, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
