Not recongiting the 750 Gb Hard drive
The hard drive will not appear on the computor even after i put out and then re install the usb lead
  • 796 Answers
Go to device manager and try to scan for new hardware changes..
even then if your hd doesnt show up check in bios setting if your hd is detected or not..if not there is some internal problem in your hd
thankyou
Posted on Sep 01, 2008
Does it need to charge first? Before I can access it?
external hard drives get their power mostly from the usb connection
you will however need to download a driver after you plug the usb lead into the computer
it is even possible that when you connect the usb up you will get a balloon in the bottom right of the task bar referring to looking for a driver for installed hard drive
Sep 04, 2015 | SimpleTech SimpleDrive 160 GB External USB...
Seagate freeagent goflex 750 put some movies onto it no problem ,but my tv, or bluray usb doesnt recognise it .any ideas?
Welcome to Fixya. Can you pleae provide the make and model of the blueray device so that we can check if the file format of the blueray device is NTFS or FAT32. By default external hard drive is set to NTFS. A good example of this one is a PS3. Ps3 can only detect a hard drive that is a Fat32 fotmat so incase you connect a NTFS hard drive it wont detect it.
Thanks
Jul 16, 2011 | Seagate FreeAgent GoFlex 750 GB USB 20...
My laptop is not working so i've taking the hard disk (fujitsu MHV2060AT 60GB hard drive) out and fixed it in a case so i could use it as an external usb hard drive, but my windows 7 couldn't install the...
if your computers motherboard is older than 5yrs and does not have 2 gb of ram it will not support windows 7 also since you have removed your hard drive you must have moved the leads attached
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
Mar 25, 2011 | Fujitsu (MHV2060AT) 60 GB Hard Drive
I registered my seagate GOFLEX 750G portable drive on my MAC, but it does not work on my school MAC and pc, even after I registered, please help me
You dont need to register the product to use it. Please make sure you have admin privileges at both computer in order to install new hardware.
Mar 22, 2011 | Seagate 750GB FREEAGENT SATA/USB 2.0 750...
Hard drive not showing on my computor, power connected, small light on the back of hard drive flashes when usb is connected to computor. Model 4910B
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 24, 2011 | Western Digital Computers & Internet
I have a Hi-Speed USB 2.0 750 GB hard drive. I cannot get it to open from the desktop, start, or from the program files. There was no installation CD that came with the device - only a "one...
Hi hourston,
Not sure what you mean by "remove" but this is what I would try if it were me.
I would disconnect the drive from the computer. Go to the Device Manager (start > right click "My Computer" > click on Device Manager > click the + in front of Disk Drives. When you find the drive, uninstall the drivers. Shut your computer completely off. Boot the pc back up, and shut it down once again. Plug the HDD back in and reboot. It should be plug and play and reinstall.
Just checked Microsoft's website, says it is Windows compatible with no action required (Plug and Play)
Hope that helps...
Dec 29, 2010 | LaCie Hard Disk 750GB with Hi-Speed USB2.0...
Hard drive not recognized by my computor . When you plug the drive into the USB, you hear the upload tone but the icon does not appear in the "My Computor" screen. Therefore I cannot access the files...
Hello
Follow these steps and you should be able to fix your problem.
Go to:
Start
control panel
Administrative tools
computer management
Storage
Disc management
Now you should be able to see your drive in the schematic below. Right click the drive you cannot see in My computer and choose the option to change drive letters or paths. Now if there is no drive letter that is assigned to the drive it will not show in my computer, now just assign a letter, restart, and it should work.
Hope this can be of help.
Best regards
Andrea
Oct 28, 2009 | Western Digital External USB 2.0 80 GB...
How to setup 750 gb drive usb. two disks which one is first. no manual came with it
your question is bit confusing.. but if you have Winx Xp you need not setup anything. just plug in the USB cable & you will have the Drive showing in mycomputer
Jul 29, 2009 | Kanguru 3.5 QS2 SATA Ext HD 750GB 750 GB...
Computers & Internet Logo
128 people viewed this question
David Payne
David Payne
