Question about Tomtom RIDER GPS Devices
Tomtom rider 1 not charging when on bike
Hi I have a rider 1 and when its fitted onto the bike the connection is so poor that it often stops charging.
Is Tomtom awaire of this fault and have they produced a better bracket?
Is there anything that I can do to make the original bracket better?
Regards
Steve G
  • 3 more comments
  • steve220 Sep 18, 2008
    I have a similar problem. When I attach the TT to the cradle it switches itself on which I assume it is meant to do, meaning it is connected. However, 3 or 4 hours of riding later I get a battery flat warning. Therefore it isn't charging. Cable looks OK and connections also OK. I'd be interested if anyone has a solution.
  • Anonymous Apr 09, 2009
    i called tomtom, they repaired my tomtom and sent me a new bracket, 2 weeks later, same prioblem and now i am not warrantied any more. I'm so glad these cost 4 times as much as regular tomtoms now, wonderful.
  • Anonymous Apr 20, 2009
    Connect it to the cradle and it switches on, but seems like the power is intermitent and after a few hours it is discharged. I keep charching it overnight at home, so i can get some use out of it.
    Any help will be appreciated.
  • Anonymous Apr 26, 2009
    I have the same problem and it has been this way for 12 of the 18 months I've owned it. I tried filling in the mounting slots with epoxy so that it would get a better connection when mounted but it made no difference. They apparently want nothing to do with the problem. Ever notice how there is no warranty section in the manual? I can't even get them to reply to my questions.
  • gngtownsend May 22, 2009
    I had the same problem with my Rider1 and TomTom replaced it with a Rider2 after I supplied all of the puchase info that I had. My problem now is that the Rider2 uses a diferent Bluetooth adapter and I am trying to find an adapter for the Rider1. Can anyone help?
  • 3 Answers
TOMTOM are VERY aware of this problem. but deny it is an issue!
I had the same problem, they sent me a new shoe after weeks of emails. I told them that the shoe is not the problem, it's the connector on the back of the TT1. Because of the springloaded pins fitted to the shoe and the poor quality connectors on the TT the normal vibration on a motorcycle causes the pins to wear holes in the connectors on the TT causing intermittant connection.
As the cost of repairing or replacing these connectors is very high and there are a large number of units that would require this repair TT are ignoring it.
I'm now looking at a way of bypassing the connector altogether.
A temporary solution appears to be to smear the contacts on the back of the rider with a little petroleum grease or WD40 - seems to work for a couple of weeks at a time.
Posted on Sep 21, 2009
  • sjf167 Sep 21, 2009
    Update:
    I've now taken my tomtom rider apart, desoldered the wires on the back of the connector, removed the connector and reinstalled it after rotating it through 180 Deg. This means that the pins on the cradle now press against an unused part of the connector pad. Should be okay for another 18months use.
I know several people with Tom Tom Riders and they all have the same issue. Tom Tom are denying that this is a general issue, but they clearly know that it is universal.
Posted on Apr 03, 2010
I suggest this
Call TomTom.
1 866 486 6866 (available 8:30AM to 7:00PM EST Mon - Fri and 9:00AM to 5:00PM EST Saturdays)
Posted on Sep 28, 2008
TomTom Rider unit wont charge. Tried mains charger, USB connector and bike charger. Swapped out the battery and the unit boots up but that is just the charge in the new battery. Any help appreciated.
Power board is faulty, repair or replace. Workshop repair required. Oh, stop plugging a charger into the USB socket. It doesn'tlike it, thats for data transfer only. The round pin socket is the charger port
Oct 30, 2013 | Tomtom RIDER GPS Devices
My tomtom rider 2 will not turn on
My tomtom rider 2 will not charge on my bike and will not charge from mains electric, when i use my tomtom in the car it works.
Cheers Tim
Mar 23, 2011 | Tomtom RIDER GPS Devices
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
DAFIER RIDER 50QT-6 OR YLYING YY50QT-6 Been in the garage numerous times. New parts fitted but same problem. Rides well for a few miles than stops. Will run again after cooled down, but stopped 9 times in...
What new parts were fitted? Were there the same issues before the parts were fitted? There may be a compression isssue due to a poorly fitted part. This will become evident as the bike becomes warm and parts start to expand with heat.
Nov 01, 2009 | 2004 Factory bike Chrono SM 250
Rider 2 Bike Dock no longer charges, needs repairing or replacing?
call tomtom to get the dock replace, after you insure that the dock is getting power. check with ohm meter, should have abut 13.5 volts to the base.
Aug 21, 2009 | Tomtom RIDER 2nd Edition GPS Receiver
Tomtom Rider GPS won't turn on
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
Jul 14, 2009 | Tomtom RIDER GPS Devices
Tomtom rider will only switch on whilst under mains power and on
If it will switch on when connected to mains or car charger then perhaps your battery has had it. My battery no longer retains charge even when not in use. Suggest try new battery.
Feb 10, 2009 | Tomtom RIDER GPS Devices
Tomtom rider1 connection problems
Put two pieces of tape on the bit of the unit that slides onto the bike mount thus bringing the unit closer to the pins. Worked for me.
Mike
Jan 01, 2009 | Tomtom RIDER 2nd Edition GPS
Tom tom rider version not charging via bike cradle either via direct connection to the bikes battery or when connected to an aux power socket. There is also no sound while attached to the car cradle /...
I recently had a bit of success with TomTom. My TomTom Rider 1 did not charge on the bike cradle, there is a known problem with the early cradles. TomTom have developed a TomTom Rider 1 replacement cradle (updated) and if you push hard they will wend you one in the post free of charge.
Jul 27, 2008 | GPS
Blank screen
To reset your TomTom device:
1. Charge your device.
Charge your device for at least 2 hours. Make sure the charging light on your device is on (except RIDER which has no charging light).
2. Remove the SD card.
If your device uses an SD card, remove it.
3. Reset your device.
Use a straightened paper clip, or something similar, to push the reset button. For a visual representation of the reset button, see below.
4. Turn your device on.
Press and hold the On/Off button for at least 4 full seconds.
5. Insert the SD card.
If your device uses an SD card, insert the SD card.
images of where to find the reset button can be found here.
Sep 04, 2007 | Tomtom ONE Regional Car GPS Receiver
Tomtom RIDER GPS Devices Logo
1,625 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
