the fans are running and the compressor is very warm almost hot to the touch. i can hear liquid moving in the compressor and it does turn on and off but i am not geting cold air coming out i am getting a cool air. do i need to replace the compressor or does it just need a recharge?
Comments:
Sep 01, 2008
- it is a refidgerator only no freezer no frost on the coils at all. the cool air is not very cool at all. the fan in the unit is blowing there is no other fan.
First, please re-check to see if both fans are running, the condenser fan by the compressor and the evap fan in the freezer. Next, empty the freezer and remove the evap cover. look at the evap coils. Are they completly frosted up -- if so, you have a defrost problem - this will cause the condition you describe- IF they are not frosted, are only a few of the passes of coil frosted and some just wet with no frost? Then that means you need some freon. The fact that you have some cooling means that the compressor is probabaly OK.
Comments:
Sep 01, 2008
- Ok, see what you mean, No you not have a condenser fan, only an evap fan. Makesure the compessor is running and not clicking. if it clicks then most likely the relay is bad. tunr the unit off for about and hour to let the comp cool and see what happens. However, if there is no frost on the evap coil it will need a charge, I still think the compressor is ok as these usually don't fail to mich with the Whirlpool units. Are you able to charge this unit yourself?
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Whirlpool EL7ATRR Refrigerator
I am not sure of the model # but our Whirlpool refridgerator / freezer always pools water under the...
(More)
I am not sure of the model # but our Whirlpool refridgerator / freezer always pools water under the crisper. The drip pan is always dry. We have taken wire and fed it up the drain hose the runs up but inside the back panel. That didn't work and we are thinking it is blocked somewhere.
My question is the back panel is creased on to the sides and can't see how we can get the panel off it inspect the pipe. We also can't see and entry from inside. Our fridge is approx 5 years old. Soory could'nt find the model #. Any suggestions as to how to get the back off to clear the drip pipe.
Thank you
David Sherk
Toronto
I have an all fridge model with water accumulating under the vegetable/crisper bins. Like other I...
(More)
I have an all fridge model with water accumulating under the vegetable/crisper bins. Like other I have read about here, I have to sop up the water at least twice a day. I have had this refrigerator for less than a year. The problem started just this summer. I have already tried adjusting the temperature. Please help me :(
