Question about Frigidaire Refrigerators
Model @FRS26H7C has 2nd time stopped cooling in refrigiderator side only. Makes ice but cannot cool the other side. The first time husband checked settings and made sure "hole" was not blocked. After a while it worked. This was last week. Worked fine until last night. Bonner
    Genius:
  • 1,011 Answers
Sir/Madam,
Remove the back panel in the freezer (#10 on the cabinet break down diagram) and check how the evaporator coil (#15 on the system break down diagram) is covered with snow. If the fridge is running for a while then the evaporator coil should be about 100% covered with thin snow.
or else it may be faulty defrost system. If the evaporator coil is still frozen up, locate the defrost timer and using a flat screwdriver, slowly turn the shaft in the middle of the timer CW until it clicks. The compressor should stop and the refrigerator is in the defrost mode now.
Wait about 10 minutes and check if the defrost heater is hot or (if it's covered with ice) for the sizzling noise from the heater area.
If it's heating up, then the problem is a bad defrost timer.
If it's not heating up, check the defrost heater for continuity. Replace if it's open.
If the defrost heater is fine, replace the defrost thermostat.
thanks
good luck
Posted on Sep 01, 2008
    Brigadier General:
  • 3,614 Answers
Have you check if your control switch is still functioning.
Amana side by side not cooling
What is the complete model number of your unit?
Dec 04, 2012 | Amana Refrigerators
I have a new Frigidaire whirlpool 3 month old . stop cooling and makes a lot of ice
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 28, 2010 | Frigidaire FRS26R4A Side by Side...
Whirlpool refrigerator not cooling freezer seems to be working
my icemaker makes ice and water but the ice doesn't come out when pushing the button what is the problem?
Aug 30, 2009 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer problem
Have you checked the Heater element for the defrost to see if it's good? It sounds like the coils inside your freezer are freezing over into a solid block of ice which in turn will cause it to stop cooling.....efficiently. When you leave the unit unplugged, it gives the unit a chance to thaw and it work properly until the coils freeze over again. If heater is not the problem then Defrost Thermostat probably is. Both located in back of Freezer.
Nov 23, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
Aug 07, 2008 | Jenn-Air JSD2789GES Side by Side...
My Waring Pro Ice Maker is not cooling. The water pumps through the system but the machine does not freeze. The machine is 18 months old.
JUST SWITCH ON YOUR ICE MAKER AND TOUCH THE COOLING SIDE HOT OR COOL ,
1st . COOLING SIDE IS HOT THE MACHINE COMPRESSOR IS FAULT REPLACE THE COMPRESSOR
2nd. COOLING SIDE IS JUST COOLING CLEAN MACHINE CONDENSER COIL
Jul 19, 2008 | Refrigerators
Refrigerators Logo
55 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
