Question about EliteGroup P4VMM2 Motherboard
Beeping my pc have 3 beeping sound and the cpu fan is moving but cannot start up
  • succeed_2 Sep 01, 2008
    I have the same problem - 3 long beeps. I'm guessing it has to do with memory - I'm trying to use PC2100. I downloaded the manual (v5.0a) and set the CPU clock jumpers for 100mhz and 133mhz but neither worked. I've changed CPUs, I've changed memory sticks, I've changed video cards, I've changed power supplies. I've disconnected all the non-essentials. Nothing helps. Last time it worked, I was in the middle of formatting a hard drive. Please help !
Long beep
Posted on Sep 01, 2008
Long beep or short beep
Dell VOSTRO 460 beeps during startup and will not startup.
many times if the fan over the cpu chip on the motherboard fails to run or blow, an beeping alarm will begin and PC will not start. the cpu has to be kept cool so if fan fails the startup is stopped. have found lose wire connections from fan to motherboard terminal, or power supply may be blown, try checking those first. if nothing lose then wiggle those wires to see if the fan starts.
Jan 30, 2014 | Dell XPS 200 PC Desktop
How to stop the beeping sound
Beeping sounds when you try to boot up? Is your system booting up all the way? Beep sounds help the technician isolate the problem with your computer booting. Beep sounds normally indicate a problem with the memory, cpu, keyboard, fan, motherboard, etc. The number of beeps can be looked up based on the motherboard brand or bios and it will tell what the problem is.
Mar 18, 2012 | Dell Computers & Internet
Power on screen blank.. fan on
Did you hear a sound beeping. If you can hear a sound beeping it is a RAM problem. But if there is no sound beeping that is a processor problem. You can disassemble or remove the processor and clean make sure that the processor fan is spinning so that it will control the temperature of the CPU to avoid overheating.
Jul 31, 2010 | HP Pavilion dv6704nr Notebook
Monitor does not light up. Computer has power.
Did you hear a sound beeping. If you can hear a sound beeping it is a RAM problem. But if there is no sound beeping that is a processor problem. Remove the processor and clean make sure that the processor fan is spinning so that it will control the temperature of the CPU to avoid overheating.
Jul 31, 2010 | HP Pavilion DV7-1232nr Notebook
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
WHEN I TURN IT ON, THE COPUTER STARTS BEEPING
that sounds. are memory problem related :
Beeps Meaning 1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU
May 10, 2010 | Computers & Internet
Ultra m923 mid-tower case won't stop beeping
The problem is the board on the case's display. It has temp alarms for your components(video card, hdd, cpu), there are temp probes for you to set so you can monitor these temps. However the board that controls these functions, or at least mine and many others I have read about, is defective. It will change display constantly and sometimes have garbage display. It is setting its own limits for what is considered a hi temperature. The limit it has set for one of your components is < room temperature so it thinks you are having an overheating problem. You can manually set the limit for overheat and it will fix it for a while, but it will prob happen again.
Jul 03, 2009 | Ultra Products Ultra M923 Full Tower ATX...
My pc is a destop. when i press the power button the fans and the lights comes on.the pc beeps all the time until you turn it off can you help me please
I believe it to be a CPU problem. Ram problems are usually 3-4 quick beeps. Cpu is usually over and over beeping.
May 21, 2009 | EliteGroup ECS 915-M5 LGA...
Constant beeping
I would first check that all the fans are turning when you first power it up. It may have fan speed sensors on them, and one or more fans aren't coming up to speed. I would check the CPU fan(s), as they are usually smaller, and tend to go bad before the other larger ones.
Feb 22, 2008 | Gateway 960 Series (gtwy960) Server
EliteGroup P4VMM2 Motherboard Logo
122 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
