Question about KitchenAid KUDMO1FK - Multiple Color Dishwasher
Kitchen aid dishwasher
My kitchenaid is 20 years old. It worked fine until recently. The detergent holder opens up during use but the dishwashser powder detergent doesn't dissolve as it used to and the dishes don't get clean.
  • Rob Schmidt Barracano
    Rob Schmidt Barracano Feb 05, 2017
    We own a kitchenaid dishwasher kdfe104dbl. Was not dissolving soap. Tried everything suggested. Then called repairman. He said it was the control board, which he said was damaged because the garbage disposal was on the same circuit. $350 repair. Still did not dissolve detergent. After much googling discovered the switch for the detergent dispenser was faulty. It was dropping the tablet at the end of the cycle, or dribbling the liquid out at the end of the cycle. I put the tablet directly at the bottom center of the dishwasher and it dissolved and cleaned the load. For now adding detergent manually, in two weeks we will replace the dispenser, OEM Whirlpool Dispenser W10409521, although there is a newer part number we could have purchased...hoping this older part number was not replaced because it fails regularly?
  • 375 Answers
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Posted on Sep 11, 2010
Leaves a white soap residue over the dishes, the dishes are scratched. New Kitchen Aid model KUDS50FVSS4 just purchased one month ago and it's performance was not as good as my old ( 15 years) GE. I have...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101;'
Apr 25, 2011 | KitchenAid KUDS50FVSS Builtin Dishwasher
Detergent is left undisolved in bottom of washer when cycle is completed. Water pressure is correct. No cloged pipe. What is happening? No excess detergent. Kitchen Aid dishwasher. Imperial 21 series
I have the kitchenaid KUDK03CTSS3 dishwasher with the same problem, it doesn't take the detergent. Have you been successful in finding a solution?
Jul 07, 2010 | KitchenAid Dishwashers
Have a hotpoint dishwasher full of little black
I have a Bosch SMS 4012 works fine till cycle finished. when I turn it off it trips the power safety switch at the switch board. To prevent trips happening I have to switch off at the power point and unplug .The washer is 20 years old and the problem started around 3 months ago.Is it a major problem.
Frank. C
Feb 15, 2010 | KitchenAid Dishwashers
Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Aug 24, 2009 | KitchenAid Dishwashers
Dishwasher detergent "pacs" dont disolve anymore
Try reversing the bottom dish rack, it's likely blocking the dispenser door because it's put in the dishwasher incorrectly. Also check if there is anything in the back of the rack preventing it from going all the way in.
Apr 05, 2009 | KitchenAid KUDU03FT Built-in Dishwasher
Kitchenaid KUDS02 Rinse Aid dispenser does not work
I don 't know how to fix the dispenser; however, there is a jet dry product that is sold in stores that is in solid form, you just clip it to the upper rack. I have seen it in Wal-Mart in the detergent aisle.
Sep 28, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
KitchenAid KUDR01TJ Dishwasher Cleaning Problem
Sinder...this sounds more like a water temperature issue than anything else. First, turn on your hot tap. If you can't hold your hand under it after it fully heats (over 125)...you should be okay. If not, raise your water temp or use the sani cycle to raise the temp. Change brands of detergent. Salt...I don't think so. You're using detergent...not soap...which would have been affected. Pressure should not be an issue...once the unit is filled, it makes its own pressure recirculating with the wash pump.
Oct 13, 2007 | KitchenAid KUDR01TJ Dishwasher
Dishwashers Logo
379 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
