VCR Won't accept tape, (keeps ejectong).
    Sergeant:
  • 300 Answers
Carridge needs alignment or replacement or cleaning.
Az.
Posted on Sep 17, 2008
Red light blinking won't accept tape
If a tape "hung" up and it won't accept one you have a loading issue.
The unit may use a belt to drive the tray or a geared mechanism.
In any case someone needs to open the unit up to "see" what is happening. Most of these a tape can be inserted with power off and manually cycled into the unit to see the issue---we usually use a old cassette with the tape inside removed to avoid issues.
If you cannot do that consider looking for a shop who will (some no longer work on this type of equipment.)
Dec 05, 2012 | JVC BR-DV3000U DV/Mini DV VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
I have a Sony Handycam DCR-HC-48 and the tape door won't close along with a 32.11 error code.....HELP
Try these steps:
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Keep us updated.
Jun 06, 2011 | Sony Handycam DCR-TRV140E Digital...
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
Go-Video VCR Problem with accepting/ejecting tapes
As with any VCR, there are rubber parts inside that have become slick. This is a simple repair for any shop. The mechanisms are Samsung ones if I remember correctly. Expect a parts cost between $20-$40. Add in the local labor rate for the total cost. This is worth the repair cost as any replacement would not last anywhere near as long. This is also a normal occurrance as rubber parts harden with age. I have repaired many of these over the years.
Dan
Jan 05, 2009 | GoVideo Go Video DVD/VCR Combo
VCR won't accept new recording tape
I asked earlyer but i can't find my questin that was submitted earler today i gave you my email address with no results. I want to know where the nearest tv vcr reparemand is to Spencer okla my email is davidcurle@sbcglobal.net and my phone No.is 580-782-2888 My mother is moving to Spincer Okla. and needs her vcr forward and reverse fixed,in her emerson tv/vcr combo
Apr 02, 2008 | Emerson EWC1902 19 in. TV/VCR Combo
VCR won't take tape
Is it ejecting the tape when you set up for timed record, or any record mode for that matter? If so, check for the presence of the record lockout tab in the tape. If tab is there, machine should accept it. If machine ejects tape with the tab present, then the sensor which detects tab present or absent is probably afoul. this sensor is often a small switch. This tab, by the way, is on the backside of the tape, on the left, looking at the tape from the back.
Apr 14, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Machine not accepting tapes
Just a thought : check if the head isn't blocked ! It should rotate freely (without any friction). I had more or less the same phenomenon (my VCR wouldn't accept any tapes and nothing was activated if I "pushed " a tape in). The reason was here that the VCR wasn't used for a long time (a few months), but it was plugged in all the time (heated up the interior). As a result the head was a-kind-of-blocked. Nothing serious, since I rotated the head manually my VCR works fine.
Feb 08, 2006 | Panasonic PV-V4611 VHS VCR
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
