Question about Nintendo DS Lite Console
Power problems with DS LIte
I have a DS Lite That wont power on. Battery and charger are good, tested in other units. When power button pushed screen flases and unit turns off. Please advise on options.
  • sophie6j Sep 01, 2008
    i charge my ds lite all night. when i next plays on it it lasts for about 3 minutes and then just turns off my it's self. when i keep trying it eventually dosn't even turn on. please could you help?
    Problem Solver:
DID YOU TRY A DIFFERENT BATTERY SOPHIE6j?YOUR BATTERY COULD BE DONE
Posted on Sep 02, 2008
  • martinoggie Sep 02, 2008
    HELLO MATHISHVAC,YOUR PROBLEM COULD BE THAT YOU NEED YOUR TOP SCREEN REPLACED OR THE RIBBON CABLE CONNECTING THE TOP SCREEN COULD BE LOOSE,IF ITS NOT THAT,IT COULD BE THE BOTTOM SCREEN THAT NEEDS REPLACING
My DS Lite wont charge! Help!
Try another charger, yours may be faulty. Alternatively,the battery may need replacing as it is no longer holding charge, these can be obtained very inexpensively from Ebay and you will just need a small cross head screwdriver to remove the cover on the back of the DS lite, then tap the unit in your hand to dislodge and remove the battery.
Dec 22, 2013 | Nintendo DS Lite Console
DS Lite
The green light is blinking, no red lights or anything else? The fuse is good as well correct?
Thanks,
Lee
Jul 19, 2008 | Nintendo DS Lite Console
Ds light green,dim green, amber then off when power is turned on
Sounds like you need to send it in for repair. I had sent my console to VideoGame911.com and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
May 04, 2013 | Nintendo DS Lite
Please Help! my nintendo ds lite wont charge?? i replace the battery from another ds and my ds turns on. i take of the battery an plug the charger directly an i get no power?
remove and re plug the new battery,connect the power cord, let it for few minute and then power on.
vote me if found helpful.
Aug 05, 2011 | Nintendo DS Lite Console
My sond ds lite wont turn on and the charge light
Yes, this problem is normally caused by one or both of the fuses have blown on the logic board.
Feb 17, 2010 | Nintendo DS Lite Console
Wont power on.
to/ Japiering
all you have to do is re-charger them with the plug.
p.s.the re-charger comes with a set.
from hannah .l
Aug 02, 2008 | Nintendo DS Lite Console
Ds lite charging lite comes on but when i press power button nothing happens
Are you leaving the DS charge until the light comes off? Remember that there are two likes too, one for charging and one for power. If you're just charging for some random period of time (lets say... One hour) then your Battery isn't going to be fully charged. The best way to ensure that your DS Lite is charged is to leave it charge until the charge light turns off. You can play your DS Lite while you are charging (I do it all the time), but it just means that you're just running off of the outlet.
A good test is to charge it fully (until the charge light comes off), unplug the charger cord (Make sure it's secured tightly to your DS while charging), then play for a little bit, your light should be a normal color (green).
If you cannot even play by using the outlet, then you need to
find a charger cord that actually works (You may need to send in the charger for replacement). If the same thing happens with 2 different batteries (assuming that you have two official Nintendo batteries).
TIP: Also run your fingers across the Charger cord. You're going to get a slight friction burn from the rubber, but you're going to get all of the kinks out of the wire in the cord. My charger cord had a similar problem (did not charge all the way, only charged until I moved the DS) but when I ran my fingers across it (pinching) it worked again.
Also check the pins in both charger cords, charging will not work if one pin is missing, nor if any are bent.
May 12, 2008 | Nintendo DS Lite Console
Nintendo ds lite power fault
I would think you have one of 3 problems, the entire unit is bad, the battery is bad, or the cable is bad. The easiest thing to check is the cable, if you have another DS lite just try the cable, otherwise most walmarts and targets have them. If its just the battery, then you can purchase a new one at http://store.nintendo.com/webapp/wcs/stores/servlet/ProductDisplay?lastAction=setCurr&jspStoreDir=NOASTORE&languageId=-1&catalogId=10001&categoryId=62206&productId=108205¤cy=USD&storeId=10001&ddkey=SetCurrencyPreference Lastly, if neither of these solutions work, try contacting Nintendo about warranty work. Nintendo is usually very good about fixing problems like this. Here is a link to get the process started on warranty work. Good luck with your DS, its a great system
Aug 27, 2007 | Video Game Consoles & Games
Nintendo DS Lite Console Logo
69 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
