Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Scrolling diagonal lines
I get scrolling diagonal lines on my mitsubishi DLP when I use the cable box thru the component video inputs. I do not get this with other component inputs or with the blu-ray HDMI input. Moreover, I tried another tv on the same cable line and there was no problem although a repair person said the cable line was the issue. Please help.
  • 1 more comment
  • bohram Sep 01, 2008
    I can try that. However, besides RCA, what "alternate" inputs can I try? Also, is this problem particular to this TV as I don't have this problem on other TV's hooked to similar cable boxes thru component?
    No, its thru the cable box.
    the other tv is the panasonic th37px50u (plasma)
I have the same problem on my TV. I switched the input to the TV from the component video cables to the HDMI USB input.
Posted on Aug 09, 2014
  • 2,071 Answers
Just click below;
Mistubishi 50803 HDTV Upgrade: It works! [Archive] - High Def ...3 Jul 2008 ... Now, I get diagonal lines running across the screen and I can see a ..... For all of you first generation Mitsubishi HDTV, I have come up ...
Hope this may help;
VOTIT
Posted on Sep 01, 2008
  • 1,879 Answers
What's the other tv's make & model
    Top Expert:
  • Mitsubishi Master
  • 69,199 Answers
Do you have a coax input to the TV from the cable box? use that. The to high of refresh rate is the correct answer I think
  • yadayada
    yadayada Sep 01, 2008
    Use the coax connection.
    Master:
  • 763 Answers
Try to see the input connection of it. it must have a loosen the connection everytime you put it. see also the settings or the menu it must have been out of tuned.
did you try to watch any dvd or vcd using your tv. see if still persist the problem.
cheers
CHARCOIS
    Genius:
  • 1,847 Answers
IS NOT CLEAR IF YOU ARE USING CABLE BOX OR THE TV TUNER . BUT IF ITS THE TV TUNER IN USE WHEN THIS HAPPENS , MORE LIKELY TO BE A BAD ANTENNA CABLE CONNECTOR
  • Mitsubishi Master
  • 19,396 Answers
The cable box signal on the components video have a too high refresh rate frequency, that is the reason for the lines.
Use RCA cables or an alternative connection.
Other solution is changing the display out settings for cable box (from PAL to NTSC etc.)
  • Ginko
    Ginko Sep 01, 2008
    Your cable set does not have HDMI, and connection through scart is not a good solution, therefore RCA can be a good choice if you have signal problems on composite cable connection.
    Try first dinding video settings on your cable box settings menu, it will have NTSC PAL SECAM etc. try changing the signal format, often this solve the problem without replacing cables.
Wd65738 blue screen
blue screen means no video signal, if the source is on hdmi ensure the cable is rca or in simple audio video jacks which u will have to connect in the dvi input of the tv reason is hdmi means high definition interface and transmits by hdcp like the data of an internet meaning its digital platform which the tv can only process thru the dvi inputs or component y,p,b
Jul 17, 2013 | Televison & Video
Mitsubishi 62725 lines scrolling in picture
Try first a DVD etc connected to a rear audio and video input, that may rule some things in or out.
Set does have a soft reset but it is unlikely to help for this issue
Dec 23, 2012 | Televison & Video
I see red dots on screen of dlp samsung tv. Not sure why. Could be a bad lamp? When I watch tv thru regular tv cable between cable box and tv , the tv is loosing signal.Thru s video signal is ok.
optic block failure is the dotty appearance use your model number to shop around for a new one and the coaxial input's are easy to break loose so use s-video if at all possibly ok
Dec 31, 2010 | Samsung DLP HL-P5663W 56" TV
TV only works on HD stations
Your TV has an SD/ED component input and an HD component input. You are using the HD input. It can only accept HD signals. You need to correct the settings in you cable box. You need to "fix" the video output so that it converts everything to HD. If you have a motorola box, you can usually turn the box off and press the menu button to access the cable box setup menu. Set the 4:3 override to Stretch or Full. If you need more help with this, post back with more information: cable provider, cable box used. I hope this was of some assistance.
Mar 28, 2010 | Samsung DLP HL-P5663W 56" TV
Wavy diagonal lines only with component cables, not hdmi
You have a bad format board which is no longer available. the DM chassis can be sent in for repair by an authorized Mitsubishi servicer Call mit at 1 800 332-2119 they might help with cost of repair have receipt and purchase date available.
Jan 12, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Random flashing streaks on screen
Check multiple inputs and multiple sources. Check your dvd player; does it happen there? If not, you are probably right to suspect the cable box.
When you are checking multiple inputs, you want to make sure that if your cable box uses component or HDMI, that you check your DVD player on the same style input.
The reason for this is that your electrical chassis treats the analog (composite, s-video) inputs different from the HD and digital inputs (component, DVI, HDMI).
If you try your DVD player and cable box on the same input and experience the same probelm, you probably need to have the electrical chassis rebuilt in order to fix a problem on the tv's FMT board.
Cost: $800+
Wait time: 4-8 weeks.
Sep 23, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Video distortion
Only thing I can suggest would be:
A. Look for any magnetic or other interference on any of the cables if there are bare wires somewhere.
B. Get a separate video switcher or run all your video to TV. If you are using component, the signal is a low quality anyways, but the same can happen to any type of connection
Dec 11, 2007 | Onkyo TX-SR703 Receiver
Scrolling lines
Try using a DVD though the component input (need a 480P out ). If the pix si ok I wouldsuspect the cable box. If the problem is still there I would suspect a video switching IC or a Leaky regulator.
Oct 15, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Sony with diagonal lines
Is it a composite(yellow plug)video input? an HDMI input? What if you switch the output of the cable box to another input, Make sure its not the cable box first. If it happens on another input then the cable box or the connection wire to the tv from the cable box is bad.Good Luck Ps Please rate this thread
Oct 18, 2006 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
401 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
