Question about Mag Innovision 19" LCD Flat-Panel Monitor LT916S
Lt 916 monitor
Hello
I have the same problem with the monitor going black after sometime.
i found if you put fan on the edge. it will keep cool and not go black.
I had some time this weakend to open the monitor to inspect. the capaitors
and found them all ok. i put the monitor back together and now the monitor
comes on white and displays nothing. opened it backup and inspected all connection and the look good, HELP
Thank You Richard
kb8vyc@yahoo.com
    Champion:
  • 293 Answers
Richard,
Open the back cover again and check the AD board connection it a wide flat cable, one end plugged to the panel with tape. Check that for lose connection, used your 2 thumbs put it all the way in... Now plugged all the cable in... tilt it up and turned on... if still come on with white screen...then you need a new AD board instead.
Posted on Oct 08, 2008
When i turn On my PC this thing shows in the monitor. <300 XT BIOS P/N 113-A33437-102
Open the case, loosen the 2 screws holding the black plastic casingon the cooling tower over the CPU. Carefully remove, or tilt back to reveal cooling tower radiator and coil.
If there is a layer of dust built up (like there was on mine); carefully vacuum clean the radiator, cooling tower unit, fan and all other surrounding areas. Clean any residue from tower-to-CPU contact area.
Vacuum entire PC inside and out. Remove, reseat, vacuum video card. Reseat storage drive cables reseat the memory sticks, close it up and plug it back in start computer.
Jun 05, 2014 | Dell Dimension 5100 (D51L1) PC Desktop
Compaq WF1907 monitor keeps going to sleep every couple minutes..
Sounds like the backlight may be on its way out.
Put a large font single word onto the screen in a high contrast such as white on black. Get the monitor near a window if possible, and the next time the monitor seems to go off, see if you can still feintly see the image using natural light.
The backlight can be replaced, but it is somtimes so expensive, it's easier to buy a new monitor.
How old is it?
Apr 30, 2010 | HP Compaq WF1907 Monitor
My Samsung monitor 244T blinked several times and went black. A few days later I rebooted my computer and it blinked twice and went black. Now power light doesn't even go on. Help!
1).check your monitor cable and power cable.search google for how to check if you do not know...
2).change your RAM into another slot and check if u have 2 RAM interchange it and check..i prefer this must be the RAM problem..
normally when u insert any new RAM..sometimes it does not matches.. in this way the blinking can be happened...
3).disconnect all the cables of CD drive and DVD drive and any other except harddisk cables...and start the system with harddisk and without connecting the CD and DVD drive..
4).clean your processor cooling fan..search google for cleaning cooling fan..this makes the processor to reduce heat or apply cool paste to processor..
let me know that your computer monitor works fine with the above steps...."rate"
Feb 02, 2010 | Samsung SyncMaster 244T Monitor
Hello, my iiyama routinely displays the Contrast menu and won't go away. I can click the Exit button on the monitor which only temporarily removes it.
15sunnybank, Did you try swapping it to a different PC to make sure that the problem is in the monitor and NOT in your PC? Sometimes when the DC voltages (which power up the electronic circuits in these LCD displays) become marginal due to age of unit, then weird stuff like unexpected/uncalled images/menu's could appear. First have a TECH type friend verify if all dc voltages are within specification. One more thing!! Don't post here without letting us know some history on the unit you hope to get help with. Age of unit?? Approx total # of "on" hours??
What happens if you put a 10 inch fan blowing cool air into the monitor?
I'm louie12fix on fixya or lmistyrel @aol.com Bye for now
Sep 25, 2009 | iiyama ProLite H481S (Black) 19 inch LCD...
Nothing happens when turn comp on
firstly i personaly would not use a magnetic screwdriver pc components are delecate did you use an anti static wristband? static from you can fry components. however you may have just pluged somethig in wrong can you upload photos to a web server or something so i can see whats pluged in were?
May 16, 2009 | CTX S762A 17" LCD Monitor
My laptop keeps crashing
try replacing the tower cooling fan(s)
Sep 30, 2017 | Gateway 40G / 40GB for laptops /...
Possible video card problem
Have you check the temp of your computer, might be a problem with the video card heating up. try to put more fan or cooling system on your video card
Jun 07, 2008 | Nvidia Computers & Internet
Computers & Internet Logo
76 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
