Question about Fuji FinePix S1 Pro Digital Camera
Card Format I just got this Fuji S1 pro as a backup digital camera for an Ebay business, and it's not like the Nikon D1 I already have, where you access the format option through the main menu. I haven't even been able to record one image! Can anyone give me a lead?
    Sergeant:
  • 255 Answers
Try pushing the play button. It will either show an image or say "No images". Then press the menu button. The option should be right there to format the card. Just press the control pad "up" to format and press "menu/ok".
Posted on Sep 12, 2005
SOURCE:
Fujifilm S1...after taking a picture, the camera will not transfer the image onto the microdrive??
First check with another Memory card. If you have the same problem with another one, remove the card, then check the card contacts inside the camera. They might not conduct properly, if you don't see anytihg out of the ordinary here, then I recomend you contact Fujifilm directly.
If the problem is on one card only, try to format it while inside the camera, then if It doesn't work try to format it on a computer.
If by doing this the card is still not working, it is certainly dead.
Hope this helps.
May 19, 2011 | Fuji FinePix S1 Pro Digital Camera
I am getting a FEE error on a Fuji FinePix S1 Pro Digital, the 300mm lens seems to be connected correctly. please help thank you.
I don't know if you have a manual fir this camera so I'm giving you a "Google" search link for a manual in PDF format. It the fourth one down.
http://www.google.ca/#hl=en&source=hp&biw=1303&bih=818&q=Fuji+S1+Pro+PDF+manual&aq=f&aqi=&aql=&oq=&fp=a5556ef3492e88b9
Okay, I've had several Fuji Pro cameras including the S5 Pro and these cameras had dual memory card slots it's listed in section 6 page 24 of this PDF manual
Okay what can happen and happened to me several times (didn't learn the first time) was that I had the camera set on the Compact Flash card and filled it up but the camera needs to be manual set for the next card it's not automatic. So I'm going to assume that the media card you are trying to write the new picture files to is full.
You can download the pictures and then format the car (in the camera) then continue or switch to the other card in the card slot. This camera used a Smart Media and a Compact Flash Card.
Cheers
Apr 12, 2011 | Fuji FinePix S1 Pro Digital Camera
Displaying FEE
This problem is usually seen on Nikon models, but as your camera is basically a Nikon/Fuji hybrid it's not surprising that it's occurred on yours.
FEE usually means that you have not set the lens aperture ring to it's smallest (highest number) setting. Your camera needs this to happen in order for it to automatically control the lens aperture as it then allows the camera to utilise any aperture between the maximum and minimum settings.
If this doesn't fix your fault then try another Nikon AF lens; if the problem remains then you have a faulty camera body, usually a broken AI (auto indexing) post on the body which senses when the fitted lens has been set to minimum aperture.
Mar 08, 2010 | Fuji FinePix S1 Pro Digital Camera
How to erase pictures stored in my camera, finepix s1pro
one by one is dificult and time taking
just bring them on any pc thru cable select and keep them for future
now it better to format the card and then later on if u want u can copy them on the card the selected one's
compact flash u can format thru connecting ur cam to pc and then select ur removable drive from my computer and simply format it by right clicking the drive
Nov 20, 2008 | Fuji FinePix S1 Pro Digital Camera
Fuji s1 pro problems
ps sorted manual downloaded free from fuji uk
problem still persists after being sent to fuji they informed me repair costs would be £389 and thats it no breakdown of what the problem is just
FAULT
great service NOT.
so they think i would pay £389 for an 8 years old superseded many times s1 pro against the cost of fuji's latest s5 pro being less than £450.
******* jokers
Nov 02, 2008 | Fuji FinePix S1 Pro Digital Camera
Fuji FinePix S1 Pro Digital.
I strongly recommend you use a memory card reader to solve this problem.
The cause is likely a bad USB cable, USB port on the Camera, or low battery.
A USB memory card reader will work around any of those causes.
Jul 20, 2008 | Fuji FinePix S1 Pro Digital Camera
Hello guys fuji film s1 pro problem
From the Fuji S1 Manual:
F-- (Flashing) or (lit in M Mode)
Cause:
The lens mounted is not a Nikkor lens with built-in CPU or no lens is mounted on the camera.
Solution:
Use a Nikkor lens with built-in CPU (excluding IX Nikkor lenes). (Note that pictures can still be taken in M mode.)
Jun 06, 2008 | Fuji FinePix S1 Pro Digital Camera
Err message
This problem is caused by the plastic memory card door.
There is a door that hides the memory card on the back of the camera.
The door has a small plastic part on the left side that when the door is closed fits inside the camera.
When the door is open this part is exposed. It is right next to the "^" in "^ PUSH TO EJECT"
If you place one drop of superglue on the top of this little plastic part of the door(when open) and let it dry overnight(LEAVING THE DOOR OPEN OVERNIGHT.)
This will slightly build the plastic up about .05-1mm.
The problem is caused by the plastic part being about 1mm too small, liking resulting from normal wear.
I have tested this, and it seems to have resolved my issue with the S1 Pro I bought on e-bay
John C. Vincent
yellowcaseartist.com
May 01, 2008 | Fuji FinePix S1 Pro Digital Camera
Nikon Coolpix S1 won't read card.
I am confused. If you can FORMAT the SD card when it is in the camera (FORMAT is successful) you SHOULD be able to use it.
Mar 29, 2017 | Nikon Coolpix S1 Digital Camera
SD Card not readable in Nikon Coolpix S1
Try to reformat the card from your MAC.
Apr 26, 2008 | Nikon Coolpix S1 Digital Camera
Fuji FinePix S1 Pro Digital Camera Logo
80 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
