Washing machine the drum does not go around does not spin either all other thing work fine
  • 4 Answers
Is this a general electric model:WWSR3090T8WW
Posted on Sep 01, 2008
  • hhart Sep 01, 2008
    I recently repaired this no spin problem for my sister
    The bearing above this clutch ***'y need replacing...ing
When the machine is on spin it has left the contents around the drum and they are titley clamped to the drum an take some effort to release them it has happened four times
The centrifugal force of the spin forces everything in the drum to the outer most limit, that is how the spin dry part of the wash works,by forcing the water out of the clothing through the holes in the drum,but if it bothers you, you can either add a bit more washing or reduce the spin speed of the machine
Feb 09, 2017 | Washing Machines
Washing machine tub is banging into the side of the walls..what's the problem here
There are two possible causes for when a washing machine jumps and bangs on spin. Either the load is a bad one and unable to be balanced, or a fault is preventing the machine from balancing the load (or causing the motor to surge into spin when it shouldn't). This causes the laundry to be flung around inside. The occasional jumping around may not be anything to worry about, but regular or severe occurrences should be a cause for concern and can cause expensive damage to your washing machine if ignored.
Both these faults are less common these days because manufacturers have built in certain protections, but it's still something that can happen. To differentiate between the two, observe when the problem occurs, if it's during a wash cycle, maybe at random parts of the programme, it may have a fault which really needs an engineer to diagnose as these faults can be intermittent and tricky to diagnose. If it happens when it kicks into the fast spin the chances are it's related to the load inside.
Am I overloading my washing machine?
By out of balance I mean when the washer jumps or bangs quite violently. If the washer is just rocking about on most spins make sure it's on a level floor and that it is properly level.
If a load is out of balance you can often observe the inner drum swaying about or even thumping the sides of the casing a few times whilst it's trying to distribute the load prior to fast spin. Before a proper spin the drum should revolve slowly for a couple of minutes. This is called "distribute" and at this stage you may see large flashes of metal drum on each revolution where all the laundry has settled around the drum but there wasn't enough to cover all of it. If this happens the drum will be out of balance and either refuse to spin, or if allowed to spin may cause the drum to thump around and hit the sides of the casing.
The best way to avoid unbalanced loads in a washing machine
If you try to wash a bulky, heavy and absorbent item, the washing machine is unlikely to be able to get it to balance inside the drum. Or if you put just a few large towels or a heavy item in amongst some very light fabrics the heavy items could bunch to one side of the drum and the lighter ones won't be able to counter-balance their weight effectively. There should be enough items to fit all around the drum. If there's only enough to fill most of the drum, but a section is empty, then it can get out of balance on spin. If the items are all light, then this may not cause a problem. However, if some items are heavy, they may cause violent banging, or the washing machine out of balance detection may just refuse to allow a spin.
Make sure you fill the drum well. Counter to expectations, the worst violent spins are caused by under-loading - not overloading. Heavy bath mats are notoriously difficult to balance and should ideally be washed with other items or they may gather on one side of the drum. However, some people (understandably) don't want to mix the bath mats in with normal washing. If this is the case and you do get problems with the bath mats getting out of balance I suggest you use old towels or sheets to even the load up. With most modern machines though, a heavy bath mat is more likely to just not get spun rather than be allowed to spin out of control and wreck the machine.
Sometimes you can get an unbalanced load by sheer chance, with loads you have successfully washed many times before. The occasional bad load is inevitable but constant bad loads and violent banging on spin should be looked into. [ Related: loading the washing machine properly ].
Modern washers have built in out of balance protection
Most modern washing machines now electronically monitor the motor during the slow distribution section leading up to the spin. If the load is out of balance, the motor shouldn't be allowed to spin. Typically, a modern washing machine will attempt to balance the load a certain amount of times, or for a certain passage of time, but if it can't, it will either reach the end of the program without spinning, or it will abort spin and turn off. (both scenarios leaving the clothes wet through). Some washing machines may allow a slow spin if the clothes are reasonably balanced, but then unless they settle down, it will not allow a higher spin thus leaving the clothes spun, but much wetter than normal.
Some will indicate a failed spin due to being unable to balance the wash load so check your instruction book to see if your washing machine has this function and what happens if a spin is aborted. Unfortunately some washing machines do not adequately inform the user that it failed to balance the wash load and aborted spin. As an engineer, I have been called out many times because a load was washed but not spun, but there was no fault on the washing machine, just an aborted unbalanced load.
Extra large drums make balancing loads harder
These days you can buy washing machines with much bigger drums. The average drum size was at one time a mere 4.5Kg but is now 6Kg. You can buy washing machines with 7Kg, 8Kg and even 10Kg drums.
These washing machines can be more prone to refusing to spin some small loads because they need even more items to fill the drum. For example, my 7Kg washing machine will not spin 3 large towels. Last week my wife was extremely frustrated with our 7Kg drum washing machine as she had just washed our son's hoody-top and wanted to spin it in the washer. It simply would not spin, so I advised her that it needed something to balance it out. She put in a couple of towels but still no spin. Eventually 5 towels were needed to balance out the absorbent top and allow a spin. This is a minor inconvenience compared to the benefit of being able to fit more washing in (even our king sized quilt) but it highlights how if you have a very large drum it could be more prone to not spinning small loads [ Washing machine won't spin just one item or very small loads ].
I'm loading the washing machine correctly but it still bangs and jumps on spin
This is unfortunately a difficult fault to diagnose. It could be various things including a faulty connection somewhere on the motor or pcb, especially if intermittent. It can be caused by a part overheating, cutting out and then cutting back in causing loss of control. If this fault isn't caused by the loading you really need to get an experienced engineer to look at it. Find a washing machine repairer on Washerhelp
If a brand new washing machine is jumping around on spin
Make sure you have removed all of the transit packaging before using a new washing machine. The transit packaging stops the suspension from working so without the tub being able to bounce up and down on the suspension all the movement created on spin will be translated to side to side movement and the washer will move about and shake.
Loading washing machine White Goods Help washing machine jumps and bangs on spin Washing machine won spin just one item Book washing machine repair
Aug 02, 2015 | Washing Machines
On spin cycle sounds like change or rocks spinning around in drum.
Could be a bad bearing or something loose on the drum that doesn't rattle until you get up to spin speed. Look for something like pins, nails or screws stuck in the holes of the drum, or possibly under the protuberances (fins) inside the drum. Does the sound occur all through the spin cycle or only at top speed?
Jul 08, 2015 | Washing Machines
Why washer moves and vibrates all over when spinning
There must be the correct weight in a washing machine. If it is under loaded then the drum will spin out of balance because the weight is trapped to one side. regualar use like this will break the drum bearings.
Weighty things like towles & sheets have to be balanced around the drum prior to spining, that's why the drum does slow and quick spins to even the load out. apart from that one of the drum supports need attention.
Oct 03, 2014 | Washing Machines
Front loading washing machine makes loud knock on spin cycle
Move the empty drum by hands upp and down listen for noise, drumbaring my have been worne. Or is there some loose outside drum?
Feb 08, 2018 | Kenmore Washing Machines
Noisy on spin cycle
It's very difficult to advise on a noisy washing machine because you can't describe noises accurately enough. People often describe the same noises quite differently.
Generally though, if a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
It's very tempting to ignore noises while the washing machine is still otherwise working. Some noises can be ignored as they will not develop into serious faults. Other noises, if left, will cause extensive damage and can end up costing considerably more than if tackled early or these days writing the washing machine off. Of course the problem is that you can't tell which of the categories a noise falls into - so ignore them at your own risk.
Jul 28, 2012 | Roper Washing Machines
I have a SIMPSON ENCORE 555 heavy duty washing machine. It will do a normal wash cycle, but when it comes to the spin cycle, it doesn't distribute the washing around the drum and hence won't spin. any...
Hi just read your posting.Now does the washing tangle around the agitator?In your posting you mentioned the washing not distributing around the drum.Could you confirm that your machine is a top loader for me,because the word "drum and distribute" are terms for a front loader.If your machine is a top loader which I think it is then the problem could be your brake arm or spin coil is not operating.Please reply and let me know if the clothes are tangling around the agitator.Looking forward to your reply.
Sep 07, 2010 | Washing Machines
Washer drum feels like its
HOUSING CONNECTED TO DRUM IS CRACKED. MADE OF WHITE METAL, CANNOT BE REPAIRED.
Jul 25, 2010 | Whirlpool Washing Machines
Makes clunking noise when changing modes--does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Drum is not moving
It sounds like the drum drive is broken ... could be a belt at the back of the machine or it could be gear driven ... most likley a belt... take off cover on back of machine to see if the belt is broken and replace if necessary. Also could be pump but that is probably the last thing to go wrong pumps rarely ever fail.
Apr 28, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
Top Washing Machines Experts
